Acer ICONIA Tab A700-10k32u Logo
Acer a700 will not charge - Acer ICONIA Tab A700-10k32u
Azpen A700 tablet. Why won't it charge or turn on?
If your Azpen A700 tablet won't charge or come on, you got no result trying to reset it, you've got only one option: take it back to the shop where you bought it and ask for authorized repair service, to diagnose cause of failure You even may have still option to warranty service.
Problem is that it's a low cost 35$ tablet so repair service might not be worth to pay, looks rather as a disposable device..
1helpful
Wont load past android logo
Give it about 2-5 minutes , if that doesn't work try holding the power and volume button until it shows you a reboot option.
How do I factory reset?
1. Tap Settings
2. Tap Backup and Reset
3. Tap Factory Data Reset...
Acer iconia a700 tablet
Hi there if you follow this link http://www.acertabletforum.com/forum/rescue-squad-guides/5168-how-perform-factory-reset.html It will walk you through the reset process :)
Acer Iconia A110 won't charge what do I do to fix it?
Bonjour,
Il est probable que le souci vient de la batterie alors la meilleure chose ? faire dans ce genre de cas reste de demander l'avis d'un r?parateur.
https://www.distriphone.com/fr/8719-Pieces-detachees-Tablette-Acer
Acer tablet a700 manual
SO sorry to hear this. I have seen to many tablets go BRICK after they are left to charge and then either they stay on the android boot/battery screen or they stick on the logo screen. There is a few things u can try to rescue you tablet.
First is this a acer tablet a700 or is it a acer iconia a 700?
I will assume its the tablet since if it was the iconia phone you would of been more upset for the 300 dollars plus. SO here we go and by no means can i tell u the exact reason these tablets fail or brick after charging.
This is a upper end tablet and not the cheap china clone. so hear is your first thing to try.
DO a hard reset with the keys first. WARNING reset can wipe out all ur data and set it back to factory if thats what u had it set to do. So if u have a sd micro card in its slot.. remove it and disconnect it from the computer dongle too. There are several diff options in recovery settings..back to factory or restore you settings from a backup file.. or wipe it and start all over.
so be aware that by doing a hard reset u can end up reinstalling everything u had on there.
Factory reset is first done with keys. HOLD THE POWER BUTTON AND THE SOUND UP but make sure you have the sleep / lock button right. at same time until it powers off..if not try power/sound up..this is the most common android tablet reset.
If this fails, then
The right side of the tablet is home to a microSD card slot (under a plastic flap) and a micro-HDMI port. The power/sleep/unlock key and 3.5mm headphone jack are located along the left edge, while a volume rocker and orientation lock switch are found on the top edge of the tablet, .
The micro-USB charging and syncing port, as well as a pair of speakers and a reset button, are located at the bottom of the A700
If u have made sure u have the sleep /lock switch in correct position. U have only one option left..the dreaded reset button. its on botton next to the usb sync charge port. Use a paper clip NO SHARP OR POINTS that break off.ie PENCIL lead .
DIsconnect from power and remove any micro/usb bridges..hold it in until it powers on and off..then cross your fingers and push the power button and wait.
If this fails to reset it back to factory and revive it. There are some software tools..SDK ANDROID isnt for the weak at heart though..lots of info and things that you will pull ur hair out trying.
If the reset above doesnt work..and u made sure its not in lock/sleep.. u are best off contacting the help line first and then last.
good luck my friend..
I will follow ur case..so post what happens and i will get it
Top Acer Tablets & eReaders Experts
NOEL
NOEL
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
