Question about Dyson Dc 41 Ball
DC41 ANIMAL I HAVE FOLLOWED THE VIDEO TO RESET THE DC41 ANIMAL BRUSH BAR AND IS STILL NOT SPINNING????? HELP!!!!! HAS ANYONE HAD THIS HAPPEN? WHAT IS THE SOLUTION?
  • Official Brand Answer
  • 2,572 Answers
Hi Ashley, it's Jack at Dyson.
I'm sorry to hear you've had difficulty with your DC41 Animal's brush bar. Although I note you've already tried resetting it, I would encourage you to try again - please make sure that you've reclined the machine into the vacuuming position as the brush bar will never rotate when the machine is standing upright. Try pressing the silver brush control switch (next to the red on/off switch) twice while the machine is turned on and reclined.
If you do need further help after trying this, please contact us directly so we can confirm if we're able to help under the terms of your DC41 Animal's 5-year warranty. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Posted on Aug 01, 2013
SOURCE: Dyson 17 Brush Belt Broken
there is also an updated beater bar that accepts a wider belt, dyson sent it to us for free
Posted on Jul 03, 2008
DAZ4161
  • 7 Answers
SOURCE: the beater bar/brush won't turn
HI THERE,
FIRSTLY, REMOVE SOLEPALTE BY QUARTER TURNING THE 3 COLOURED STUDS,THEN CHECK TO SEE IF THERE IS ANYTHING OBSTRUCTING THE BRUSH BAR OR IF THE BELT IS WORN OR SNAPPED. IF ALL SEEMS WELL PUT THE SOLEPLATE BACK ON AND ENSURE CLUTCH IS ENGAGED TO AUTO AND TRY IT AGAIN. IF NO JOY THEN PLEASE COME BACK TO ME.
REGARDS
DAZ
Posted on Dec 13, 2008
ukvacfan
  • 328 Answers
SOURCE: The brush bar on my Dyson DC17 stopped turning.
If this model has a brush control - i.e a roller at the side of the model which controls brush to spin or not, then its a protected brush model - therefore even if the drive belt is intact the Dyson would have to be repaired by a service personnel or professional. The brush protection isn't able to be taken apart and sounds like it may well have slipped off due to tension.
Posted on Apr 02, 2009
  • 7 Answers
SOURCE: My Dyson Animal 14 beater brush will not turn.
It MAY be a clutch issue. I had a similar problem with my DC07 Animal recently a posted a solution elsewhere on this site, but here's the summary. To reset the clutch on my model, recline the vacuum, turn it on it's side and slowly change the carpet/bare floor knob from one setting to the other about 6 times. This apparently reset the clutch and now it works fine. You may also wish to call DYSON. They're very helpful and walk you through troubleshooting before recommending servicing. Their number is 1-866-693-9766. They'll need your model and serial number (located on bottom of uinit).
Posted on Apr 18, 2009
SOURCE: DC17 Animal - loud noise in roller bar
We were able to get in touch with the Dyson support people and they told us this model doesn't have a clutch in the roller bar. The support person helped us walk through looking at the vacuum and it turns out the belt was stripped and they are sending us a new replacement belt. Case Solved!!
Posted on Oct 06, 2009
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    Dyson DC54 brush bar not rotating. Have removed all the hair, cleaned the brush and replaced, still not spinning.
    Brushbar not turning Clutch check - Dyson
    www.dyson.com/...dyson...not.../brushbar-not-turning-clutch-chec...
    DysonBrushbar not turning - Clutch check. Please ensure that your hands are clear of the soleplate and brushbar before completing this test. Clutch check.
    Resetting the brush bar (Official Dyson video) - YouTube
    ? 3:52
    https://www.youtube.com/watch?v=AiKnefEr7ns
    Jan 16, 2014 - Uploaded by AskDyson
    How to clear and reset the brush bar of your Dyson DC41 Mk2, DC55, ... Dyson DC41 Mk2, DC55, DC65, DC66 - Resetting thebrush bar (Official Dyson video) .... Dyson Cinetic DC52, DC54with the Musclehead™ floor tool ...
    Dyson DC44 - Remove & clean the Brush Bar - An owners ...
    ? 4:13
    https://www.youtube.com/watch?v=_0a71p84sp8
    Nov 12, 2012 - Uploaded by Tom Strong Reviews
    Here is the fantastic Dyson Digital Slim Mk2 DC44 Animal. (DC45 in ... Europe) Here I show how to remove and clean the Brush Barof any tr... ... It is and easy operation and one you need to do whenever the brush is not clear.
    Dyson DC54 Support - Turbine head not working properly
    https://www.dyson.com.au/.../dc54/dc54...not.../turbine-head-not-workin...
    Dyson DC54 Support - Turbine head not working properly. ... If you cannot clear an obstruction you may need to remove the brush bar. Use a coin to unlock the ...
    Jan 24, 2016 | Dyson Vacuums
    Our DC41 is impossible to push on carpet. Is there an adjustment to do? Almost like there is too much suction.
    See if the following information can help.
    CARPETS OR HARD FLOORS
    • The brush bar will always default to 'ON' (spinning) each time you switch the
    appliance 'ON' and recline it for cleaning.
    • The brush bar will not rotate when the appliance is upright.
    • To switch the brush bar 'OFF' (e.g. for delicate rugs and hard floors):
    - switch the appliance 'ON'
    - recline the appliance
    - press the brush bar 'ON/OFF' button - the brush bar will stop spinning.
    • The brush bar will automatically stop if it becomes obstructed. See 'Brush bar -
    clearing obstructions'.
    • Before vacuuming your flooring, rugs and carpets, check the manufacturer's
    recommended cleaning instructions.
    • Some carpets may fuzz if a rotating brush bar is used when vacuuming. If this
    happens, we recommend vacuuming in 'hard floor' mode and consulting with
    the flooring manufacturer.
    • The brush bar on the appliance may damage some carpet types. If you are
    unsure, turn 'OFF' the brush bar.
    Dec 31, 2014 | Dyson Bagless Upright Vacuum DC41 Animal
    My dyson animal dc41 is making a screaching noise during use. also does not glide easily on some surfaces since this started to happen
    Hi there, it's Jack at Dyson.
    I'm sorry to hear about the issues you're currently experiencing with your DC41 Animal, but from your description of the problem I'm confident that we can resolve this for you.
    Just to make you aware, it's normal for dirt and debris not to spin within the clear bin - in fact, at the base of the bin are four 'baffles', engineered to capture the debris from the airflow and force it to settle. This isn't in itself an indication that there's a fault with the machine.
    I'd like to take some further details to help get your DC41 up and running again. At your earliest convenience, please email askdysonUS@dyson.com and our experts will be in touch. We'll look forward to hearing from you.
    Oct 02, 2014 | Dyson DC41 Animal Bagless Upright Vacuum...
    How do replace belt on dc41
    Ouch The video below shows how to to remove the brush head and how to clean it. I almost think that Dyson didn't ever expect this belt to break. The rest of the disassembly to get to the brush seems to be done by removing torx screws, I have not been able to find a replacement from dyson. A google search shows several sites that sell a replacement belt.
    Dyson DC41 DC43 Resetting the brush bar Official Dyson video
    Link to sears parts direct has a diagram of the brush head.
    DYSON INC Vacuum Parts Model DC41 2013
    Link to Dyson Parts with phone number for customer care.
    Variant Parts
    Sep 23, 2014 | Dyson Bagless Upright Vacuum DC41 Animal
    Where is the reset switch on the Dyson DC41
    DC41 doesn't include a separate reset switch, as the reset mechanism is built into the on/off and brush control switches for convenience. If your brush bar isn't rotating, please follow the steps shown in the video below to reset the vacuum after removing any obstructions:
    Please note, the brush bar will never rotate when the vacuum is standing upright - make sure you recline the machine into the normal vacuuming position before testing it.
    If you'd like further help or advice after giving this a try, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US) or 1800 239 766 (AU).
    Jul 13, 2014 | Dyson DC25 All Floors Bagless Upright...
    What to do? Brush bar not rotating.
    Remove head cover surrounding brush remove brush and replace drive belt .
    May 18, 2014 | Vacuums
    Dc41animal leaves obvious tracks on beige carpet
    Hi Alan, it's Jack at Dyson.
    Like all Dyson upright vacuums, DC41 Animal includes a motor-driven rotating brush bar. This includes stiff nylon bristle tufts which sweep into the carpet pile, agitating out dust, grit and stubborn pet hair. This will also have the effect of raising the carpet pile where it's been trodden down from daily use - this is what causes the tracks you've noticed. You can see how DC41's brush bar and cleaner head are engineered to work in the video I've attached.
    It is possible to turn off the brush bar using the silver brush control switch next to the red on/off switch. However, the brush bar is an important factor in effective carpet cleaning and we would always recommend vacuuming carpets with the brush bar turned on - with the exception of delicate carpets or rugs.
    It does sound like your machine is working correctly, in the way it was designed. I hope this information is useful to you, but if you would like some further advice, please give us a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
    Best wishes,
    Jack
    www.dyson.com
    Aug 09, 2013 | Dyson DC25 All Floors Bagless Upright...
    Plush carpet setting on vaccuum?
    DC41 Animal's cleaner head is designed to self-adjust to different floor types - so you don't need to bend down to adjust a dial. You can see how this feature works in the video below. In addition to this, next to the red on/off switch you'll see a silver brush control switch, which allows you to turn off the brush bar for hard floors and delicate carpeting.
    Carpet manufacturers sometimes recommend vacuuming certain types of carpeting with the brush bar turned off - we'd suggest checking directly with the manufacturer of your carpets to ensure you're cleaning them correctly.
    If you'd like any further advice on using your DC41 Animal, please email us at askdysonUS@dyson.com and one of our experts will be in touch as soon as possible.
    Best wishes,
    Jack
    http://www.dyson.com
    Apr 05, 2013 | Dyson Vacuums
    My dyson dc17 turn on but doesn't turn
    I am sorry to hear you are having difficulty with your DC17. If the brush bar is not spinning it may be obstructed.
    Please visit http://www.dyson.com/support/help.asp?article=956&product=DC17-ANIMAL for step by step instructions on how to inspect your brush bar and clear any obstructions that may be present.
    Once you have carried out these steps you may need to reset your brush bar. To do this please plug your machine in, recline it as if you are preparing to vacuum a carpeted surface, turn your machine on and if the brush bar is not spinning push the silver button next to your power button one time. This should reset the brush and it should begin spinning immediately.
    If you are still having difficulty with your machine please contact the Dyson US Helpline at 1-866-693-9766 or the Dyson UK Helpline at 0800 298 0298 so we can provide further assistance.
    Best wishes,
    Jessica
    Mar 07, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
    Dyson Dc 41 Ball Logo
    595 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
