Question about Sony Cyber-shot HX50V Black
Does the flash go down automatically when turning off camera?
    Problem Solver:
  • 19 Answers
On the HX50V you have to press it down to lock it back down
Posted on Jul 21, 2013
Why does "raise the flash" come on the screen when I turn my coolpix s5090 camera?
I do not know allot about the s5090, but I can give you general information based on how most Nikon pocket cameras are designed to work. If the Nikon is set to one of the automatic modes it is designed to prevent you from taking a picture if it senses that there is insufficient light to get a properly exposed picture. The camera may be telling you to rase the flash because it needs more light. Also, somewhere on your camera there is probably a menu that allows you to choose the flash mode. It may be in your regular menus or, if your camera has a round left-righ-up-down switch on the back, you can select the flash mode by pushing up and then using the right-left keys to choose the flash mode. The mode you select is locked in when you push the button in the center. In general, the modes are automatic (the camera decides when flash is needed), red eye reduction (the flash activates twice; once to cause your subjects eye's iris to close and the second to take the picture), flash always (flashes regardless of the ambient light) and flash off.
Jul 12, 2014 | Nikon COOLPIX Cameras
Turning flash off on Nikon D60
Based on what you said, it appears that you want to know how to turn the flash off on your D-60.
On my D-90, you do this by rotating the mode switch on the top center left side of the camera one click counterclockwise, from the green automatic setting, to the white automatic with no flash setting.
You can also change flash settings from the menu. For my D-90, the manual says you use custom setting "e2." Check your manual for the D-60.
I never turn my flash off from the menu because it takes too long to turn it back on when you need it. Another alternative is to simply hold the on-camera flash in the down position while you shoot.
Apr 19, 2014 | Nikon D60 Digital Camera
Turn off light
what type of camera or model you are using ?
when the camera is set to automatic mode by default the flash flickers as it calibrates the amount of light needed to capture the picutre
try to set the camera on manual settings
or if you set the camera timer on once you click the shutter button the timer will then count down and a light will blink so turn of the timer
Mar 28, 2014 | Cannon Cameras
How do i use the flash on this camera? I can seem to find where its at.
Hello! Welcome to FixYa!
Panasonic Palmcam PV-SD4090 Digital Camera feature a built in flash which can be used to capture image in dimly light conditions. To use the flash first turn on your camera and then press the flash button repeatedly, See the below image to find flash button
When you will press the button the mode that is selected will be displayed on the LCD viewfinder. When the down arrow sign display on LCD it means your flash is On. now you can use the flash. The flash light automatically lights depending on lighting conditions.
I hope this solution helps you
Thank you for using FixYa! Keep Visiting.
Aug 26, 2011 | Panasonic Palmcam PV-SD4090 Digital Camera
How do I turn the flash on
Since you didn't provide brand and model info - only generic help can be given.
Most cameras will automatically turn the flash on when conditions are too dark for a successful exposure. Many times, the camera will not allow you to take the picture if the flash can't be turned on. You'll have to go through the menu settings of the camera to find a Flash Setting. Popular choices are often Always Flash, Never Flash, Red Eye Reduction and Automatic Flash. It sounds as if the setting was changed to Never Flash - or the flash bulb itself has failed.
If you have problems still - provide the manufacturer and model camera you're using and I'll see if I can find out how to do it for you. Good luck!
Oct 08, 2010 | Cameras
Same thing
More Info please, it will usually go to standby if camera turned off or after the meter shuts down after a predetermined time (nikon default setting in camera is usually 6 secs.).
So if you switch camera back on or push shutter release to wake up metering system flash should automatically come out of standby.
Or you can push the on / off button for approx 1 / 2 secs. this will wake it up , then turn it off. Hope this may help Ian
Aug 08, 2009 | Nikon Speedlight SB-600 TTL Flash
I CAN'T TURN ON THE FLASH.WHY? AND PICTURES LOOK BLURRY.HOW DO I ADJUST THAT?
usually by manually over-riding the automatic flash, the shutter speed varies (in this case it slows down, giving you that blurry or ghosted look) depending on the lighting conditions. If you are shooting in the dark (with flash), leave the flash on automatic. Only force the flash to fire manually if you are shooting in bright conditions, as a "fill-in" flash to reduce shadows.
Feb 27, 2009 | Vivitar ViviCam 6330s Digital Camera
I have a canon rebel xti with an 18 to 55 lens .. I recently bought an external flash to sit in the hot shoe .. now when I removed the flash from the hot shoe .. the cameras own flash will not pop up and...
I had the same problem.
Look closely at the hotshoe. Inside it, way over to the side, under one of the tabs on the side, is a tiny metal strip. When you attach an external flash, the strip is pushed down and holds down a tiny button that deactivated the pop-up flash. The strip can get bent so that it doesn't let the button come up even when the external flash is removed.
Very gently take a fingernail or a jeweler's screwdriver and run it underneath the metal strip. I had to do it a couple of times to get mine working again, but it's working great now!
Dec 30, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Automatic flash problems
I have the same problem as Irichard, in that the flash won't pop up automatically, the camera wont work when you pop it up manually all all modes that allow flash photography do not work.
Nov 01, 2007 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Built-In Speedlight (Flash) will not retract
I haven't heard of this problem but compliments of velocityreviews I came up with this. Follow the instructions below to attach an external Speedlight. Refer to your Speedlight manual for detailed instructions regarding Speedlight operation. 1 Make sure that both the camera and the external Speedlight are turned off. 2 Attach the Speedlight to the camera accessory shoe. 3 Turn both the camera and the Speedlight on. 4 Set the external Speedlight zoom head to an angle wider than 28 mm. If you are using a Speedlight with Auto Power Zoom, set the zoom head angle manually. The COOLPIX5700 does not support power zoom. 5 Set the external Speedlight flash mode to TTL. At this setting, the amount of light produced by the external Speedlight is measured by the camera?s photocell, and the flash shooting range adjusted automatically to ensure optimal exposure. D-TTL flash control (available with the SB-80DX, SB-50DX and SB-28DX) is not supported. 6 Take the picture If the Speedlight Options: Speedlight Control option in the SET-UP menu is set to Auto, only the external Speedlight will fire. If this option is set to Int & Ext Active then the external Speedlight and the builtin Speedlight will fire at the same time. The COOLPIX5700 does not support AF-assist illumination, or red-eye reduction using the red-eye reduction lamp on the external Speedlight. At a setting of STBY (standby), the Speedlight will turn on automatically whenever the camera turns on but will not turn off automatically when the camera turns off. Exact functionality varies with the Speedlight in use. Refer to your Speedlight manual for details. I hope it's of some help BMW
Jul 07, 2006 | Nikon Coolpix 5700 Digital Camera
Sony Cyber-shot HX50V Black Logo
22 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
