Question about Cameras
Flash Does the flash go down automatically or manually?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 54 Answers
Manually.
Posted on Jul 22, 2013
How do i get the flash off
Most cameras, when set to automatic, will pop up the flash, when the lights are to low. As soon as you switch to a manual setting, with Aperture or shutter priority, the flash should stay where you put it. Down and if should not give any light. So check your settings and don't use Automatic or P(program)
Jan 24, 2015 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Turning flash off on Nikon D60
Based on what you said, it appears that you want to know how to turn the flash off on your D-60.
On my D-90, you do this by rotating the mode switch on the top center left side of the camera one click counterclockwise, from the green automatic setting, to the white automatic with no flash setting.
You can also change flash settings from the menu. For my D-90, the manual says you use custom setting "e2." Check your manual for the D-60.
I never turn my flash off from the menu because it takes too long to turn it back on when you need it. Another alternative is to simply hold the on-camera flash in the down position while you shoot.
Apr 19, 2014 | Nikon D60 Digital Camera
Auto flash wont work
did it pop up automatically or did you pop it manually? if it popped up by itself then the flash unfortunately is probably dead, since on automatic, it won't pop unless it's going to fire. If you popped it manually then - the camera doesn't think that the flash is necessary for the conditions that you're shooting in.
Oct 21, 2009 | Nikon Cameras
EOS Rebel XTi 400D flash not popping up
Flash will automatically pop out only in AUTO mode, if the camera needs some additional lightning. In manual modes, you should use the flash button located at the left down side of the flash compartment, to manually force the flash to pop up
Jul 13, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
I CAN'T TURN ON THE FLASH.WHY? AND PICTURES LOOK BLURRY.HOW DO I ADJUST THAT?
usually by manually over-riding the automatic flash, the shutter speed varies (in this case it slows down, giving you that blurry or ghosted look) depending on the lighting conditions. If you are shooting in the dark (with flash), leave the flash on automatic. Only force the flash to fire manually if you are shooting in bright conditions, as a "fill-in" flash to reduce shadows.
Feb 27, 2009 | Vivitar ViviCam 6330s Digital Camera
I have a canon rebel xti with an 18 to 55 lens .. I recently bought an external flash to sit in the hot shoe .. now when I removed the flash from the hot shoe .. the cameras own flash will not pop up and...
I had the same problem.
Look closely at the hotshoe. Inside it, way over to the side, under one of the tabs on the side, is a tiny metal strip. When you attach an external flash, the strip is pushed down and holds down a tiny button that deactivated the pop-up flash. The strip can get bent so that it doesn't let the button come up even when the external flash is removed.
Very gently take a fingernail or a jeweler's screwdriver and run it underneath the metal strip. I had to do it a couple of times to get mine working again, but it's working great now!
Dec 30, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
The flash unit for my D50 doesn't pop up automatically
The flash is spring-loaded and always "trying" to spring up. It is held down by a small lever that should disengage automatically when the flash is instructed to pop up either manually or in automatic mode. It sounds like the small lever has broken on the inside and will not release. The camera must be opened in order to repair this, and this should only be done by a qualified technician.
Mar 03, 2008 | Nikon D50 Digital Camera
Automatic flash problems
I have the same problem as Irichard, in that the flash won't pop up automatically, the camera wont work when you pop it up manually all all modes that allow flash photography do not work.
Nov 01, 2007 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Flash modes?
There are 5 flash modes: Auto-flash, Manual fill-flash, Auto-flash with red-eye reduction, Manual fill-flash with re-eye reduction, and Flash cancel. In Macro mode, the built-in flash is automatically disabled.
Sep 19, 2005 | Konica Minolta DiMAGE E201 Digital Camera
Flash Problem
Using the flash When shooting with the built-in flash, open the flash manually. The flash does not pop-up automatically. The flash will not fire if it is closed. The flash will work when it is opened up. When the flash is open, the (flash on) icon or (automatic) icon will appear on the LCD monitor (or in the viewfinder). Flash on: The flash fires in every shot. Automatic: The flash fires automatically. Press the (flash) button to switch between the and flash modes while the flash is open. In some shooting modes, the flash mode does not switch even if the flash button is pressed. Please refer to Functions Available in Each Shooting Mode in the Camera User Guide provided with your camera for more information. When you are not using the flash, close it manually. When the flash is closed, the flash will not fire and the icon appears on the LCD monitor (or in the viewfinder).
Aug 31, 2005 | Canon PowerShot S2 IS Digital Camera
Cameras Logo
12 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
