Question about Acer Aspire 3000 Notebook
Acer aspire 3000 doesn't charge
My laptop doesn't charge the battery, it only works with ac.
Hi i have an acer aspire 3000, it will only run off ac and wont charge the battery, the battery is good as i can charge fine with my other battery.
Posted on Feb 22, 2008
    Scholar:
  • 53 Answers
Harvester3 makes a point here most likely the battery is gone, don't worry it happens quite often batteries have a life time and they need to be replaced. Good luck!
Posted on Aug 30, 2007
    Scholar:
  • 181 Answers
Are you sure the battery is good? How old is the system and battery? Do you have any way to check voltage at the battery terminals?
Posted on Aug 29, 2007
5 Suggested Answers
bruce508
  • 44 Answers
SOURCE: I can not charge battery on laptop or run on ac.
How are you sure that the power is getting through? Is the AC light on the computer on steady? Does it blink if you bump the connector?
So often the jack of the adapter or within the machine fails. Often if the jack feels loose on the computer, it is bad.
However, if none of that applies, I would go into the control panel and look at all the power settings to see if anything is unreasonable. Similarly, I'd look at the BIOS settings. (You may have to hit a particular key, like F10, when the machine boots --- there should be information on the screen, in the manual or at the Acer site.)
If that doesn't turn up anything, I would check the BIOS version and carefully follow the instructions to load a newer version if one is available or reload the previous version. Why? I don't exactly know, but when I had a Sony VAIO machine witih similar symptoms tech support suggested this and it did work.
Posted on Jul 02, 2009
leecom72
  • 4806 Answers
SOURCE: Acer aspire laptop won't charge
First of all you have to determine whether it's the battery, charger or the laptop itself.
Remove the battery and boot the laptop on AC power only, if the laptop boots up you can rule out the charger and the laptop, you may need a new battery if that is the case.
Regards.
Posted on Sep 08, 2009
  • 32 Answers
SOURCE: battery not charging
As you have tried to replace battery and still new battery is not getting charged in this case it seems there is hardware problem. Circuit which allows battery to charge is not working.
Posted on Apr 29, 2010
  • 184 Answers
SOURCE: ac adapter connection inside laptop doesnt work, light for battery charging will not turn on and will not charge
It's more likely your dc power jack was loose or broken. It need to be resoldered.
Posted on Dec 07, 2011
Hp 2510p not charging
If your laptop works fine while plugged in but stops working while unplugged it's likely that either your laptop battery is bad or your laptop is not charging the battery properly.
Below are steps that can be taken to help identify the cause of this issue.
Leave power plugged in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
Remove and reconnect battery
In some situations the battery can become loose.
Removing it and then put it back into the laptop.
Third-party utility
Use a third-party battery utility to determine the total capacity of the battery.
For example, BatteryCare is a free software utility capable of doing this.
Replace battery or AC adapter
If your computer is still in warranty we suggest skipping to the next step.
If the above steps have been completed, we suggest replacing the battery in the computer or AC adapter.
In most situations it's a bad battery.
hope this helps
Try removing the battery from the back and then running it directly through the AC adapter. Sometimes the battery and AC adapter have conflicts and it can cause a laptop to become inoperable.
If this doesn't fix the problem in any way, I would recommend trying a new battery or AC adapter.
hope this helps
Oct 09, 2012 | HP Compaq 2510p Notebook PC
Set dead
Did you plug your AC adapter in and then try to turn it on? It may be that your battery ran out of power. Try to plug your AC adapter into your laptop, wait about 2 minutes for the battery to charge, then turn on your laptop. If that doesn't work, you may need to replace your battery. The battery on that laptop is fairly cheap, ranging in price from $10 used to $60 new. If that doesn't work, your power button may need to be fixed. You then need to have it fixed by a reputable computer repair store.
Hope that helps. Good luck!
Jun 27, 2012 | HP Computers & Internet
Charging problem of dell pp41L, it works as an ac online power bt it doesn't charge it.
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 20, 2012 | Dell Computers & Internet
New battery 6600 mAh does not charge anymore
It is possible it is a bad battery again. Also could be a bad solder joint on the DC jack or bad AC adapter. To test power off and unplug the laptop, remove the battery. Now plug in the AC and power on the PC. If it comes on, gently wiggle the AC plug going into the PC. If it shuts off you have a bad DC jack solder joint. If it stays on the battery is probably bad or the battery connector on the PC. If the PC doesn't come on at all with just the AC gently wiggle the AC plug and tap the power button repeatedly. If it comes on briefly than off again it is the jack solder joint. If it doesn't come on at all then it's a safe bet the AC adapter is bad.
Apr 17, 2012 | Acer Computers & Internet
My toshiba satellite series a135-s4656 laptop stopped charging for over two weeks now. Though the adapter (power pack) is functional. Please what do i do (cos the system has been down since)?
How do you know the ac adapter is working? Just because the light on the ac adapter is on doesn't mean it's working. Does it work with the ac adapter plugged in? Just not charging the battery. If in the first case just buy a new ac adapter and see if it works, most are affordable some not so much. If the battery isn't charging then you will have to shop for a new battery. If both of those are good then you have either a bad ac plug on your laptop, or motherboard issues. Hope this helps, if you have more questions just reply and I will try to help.
Aug 01, 2011 | Toshiba Computers & Internet
My Toshiba a200 laptop doesn't charge and when I charge the battery in another laptop then install it in my laptop it works and when I plug in AC adapter while the battery is removed the AC LED goes...
It look like you have another portable of the same type If you have the same problem trying your adapter on the other laptop it will be a good indication that the adaptor is deffective
Aug 01, 2011 | Computers & Internet
BATTERY DOESN'T CHARGE ON MY ACER ASPIRE ONE MOD#KAV60
Sounds like the battery might be bad. Try another battery in the laptop and see if it charges. If it does then you know the other battery is bad.
If you try another known working battery and it still wont charge, then try another AC Adapter. If you still cant get the laptop battery to charge then at that point the motherboard is bad because you will have tried another working batter and another working ac adapter.
May 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
Laptop power charging stops and laptop later shuts down and no charging
First you should figure out what caused this problem. Here below are some possible cause:
AC Adapter Problems
If the AC adapter is not working properly, then the charging won't occur at all. An AC adapter, with lower than required voltage settings, will not be able to charge the battery. See to it that the AC adapter matches the laptop battery's requisite settings. A loose wire or internal breakdown, may render an AC adapter useless. Changing the adapter all together might solve your problem.
Acer Aspire 5720 AC Adapter
Power Management Software Problem
Sometimes, the problem is merely with the power management software. This is the classic case, when the laptop charges when switched off, but doesn't when the computer has booted. The software may have gotten corrupted which must be causing the problem. In such a case, go to the device manager section and uninstall the power management software. In case of Windows XP, uninstall 'Microsoft ACPI Compliant Control Method Battery listing' from the device manger section. Take care that you do not install any other AC adapter driver software. Then go for a 'hardware scan', which will automatically identify the battery and reinstall the latest version of the drivers again. That will restore the charging facility of your laptop.
Internal Charging Circuitry Problem
If neither the AC adapter, nor the power management software has a problem, then problem can be with the internal charging circuitry of the laptop. In this case, there is little you can do, other than send the laptop to the manufacturer's service center.
Bad Battery
If you have checked for all of the above, one of the main reasons, which could lead to the problem of laptop plugged in but laptop battery not charging is a bad or dead battery. Run a laptop battery test. If your laptop is quite old, this could be one of the most likely reasons. Get the battery checked from the manufacturer and check if it has exceeded its predicted recharge cycle limit. It is important that you get the dead battery replaced immediately with a new one. Laptop battery troubleshooting will solve the problem.
Hope this will help.
May 09, 2011 | Acer Aspire 5720-4230 Notebook
Acer Aspire 3000 Notebook Logo
308 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
