Question about Cub Cadet Garden
How to remove and clean fuel tank - Cub Cadet Garden
    Sergeant:
  • 352 Answers
UNBOLT TANK FROM MOWER
1. USE A NON FLAMMABLE CLEANING SOLVENT..LIKE SEA FOAM FOR MARINE ENGINES
2. COMPLETELY BLOW ANY FORIEGN DEBRIS OUT WITH COMPRESSED AIR
3. REPLACE FUEL FILTER AND LINES
Posted on Jul 21, 2013
Replace fuel lines on model no. 358.797931
Hi.
Before you remove any fuel lines, make a drawing or take a picture of how the lines are connected to the tank for later reference.
You will need to remove all the old fuel lines and fuel filter out of the gas tank.
Clean and remove all trash, broken lines,etc. from the fuel tank.
After you have all the trash,fuel lines and filter removed.
You will trim the end that goes into the fuel tank to a point.You will lubricate about 1 inch of fuel line with a small amount of vasoline or light machine oil...
Now using your fingers or small needle nose pliers push the fuel line and insert it into the hole in the fuel tank.
After you have the fuel line in the tank, extend enough fuel line into the tank to exit the fill spout of the tank .
You will insert the new or cleaned fuel filter into the line and pull the fuel line to pull the filter just back into the tank.
Hook up the fuel lines to the carburator and you should be good to go
Please take time to rate me
Bud
Apr 21, 2013 | Garden
Dirt in fuel tank on hyundai H-100
Remove fuel tank and drain.Remove fuel filter and replace.
Refill tank with clean fuel once it has been thoroughly cleaned out.
Nov 11, 2012 | Hyundai Cars & Trucks
Have fuel starts dies then won`t fire leave for a while then it does the same again
if it has not been serviced,remove any fuel that is in tank,remove the tank and remove gas shut off and clean the screen,remove spark plug and do compression check on each cylinder,remove carbs and clean/rebuild(carb kit),replace the float needle valve assembly.it will be a little pricey but its worth it,sounds like fuel restriction to carbs,thats why I suggest at least fuel tank shut off screen clean,if you want to just drain carb float bowls of fuel to make sure that there is no water in them first before any disassembly try that,its possible the may be the problem.I have done carb clean with a dynajet kit with K&N filter and an aftermarket performence exhaust,carb synch,and fuel mix adjust ran like champ,but did not check fuel tank,it had water in gas tank,had to drain tank,fuel lines,fuel pump,and carbs again.ran fine after that,hope that helps or at least points you in right direction.
Feb 23, 2011 | 1983 Suzuki GSX 750 ES
Replace fuel pumpand moddual on a 2001 jeep wrangler sport 4.0l in side tank assembly
Fuel Pump Removal & Installation To Remove:
WARNING
The fuel system is under constant pressure, even when the engine is off. This pressure must be released before servicing the fuel pump module.
  1. Drain fuel tank and remove the tank.
  2. Thoroughly wash and clean area around pump module to prevent contaminants from entering tank.
  3. The plastic fuel pump module locknut is threaded onto fuel tank. Install special tool #6856 to fuel pump module locknut and remove locknut. The fuel pump module will spring up when locknut is removed.
  4. Remove the module from fuel tank.
To Install:
CAUTION
Whenever the fuel pump module is serviced, the module gasket must be replaced.
  1. Thoroughly clean locknut threads and mating fuel tank threads. Use a solution of soap and water. Do not use carburetor cleaner to clean threads.
  2. Using new gasket, position fuel pump module into opening in fuel tank.
  3. Apply clean water to locknut threads.
  4. Position locknut over top of fuel pump module.
  5. Rotate module until arrow is pointed toward front of vehicle (12 o'clock position). This step must be done to prevent float/float rod assembly from contacting sides of fuel tank.
  6. Install special tool #6856 to the locknut.
  7. Tighten the locknut to 55 ft-lb (74 Nm).
  8. Rotate fuel filter/fuel pressure regulator until its fitting is pointed to 10 o'clock position.
  9. Install the fuel tank.
Jul 17, 2010 | 2001 Jeep Wrangler
Will not go above 4500 revs power loss, overheating.
It sounds as if the engine is running very lean, this can be caused by several things. Firstly the fuel filter you have installed, is it pointing in the correct direction (Fuel in and Fuel out), also is it a high pressure filter? If not remove it. Another thing that causes problems is the fuel pump could have a problem, it is also possible the gauze filter on it is clogged. Next check the fuel you have and make sure it has no water in it, to clear small amounts of water you can get a tank of ethanol, this will mix water and burn it off as you ride (Don't us a big mix E10 should be sufficient) if you don't like the ethanol, empty the tank of ethanol and refill with regular fuel.
Jul 14, 2010 | 2007 Suzuki GSF 1250 Bandit
Need to know how to replace a fuel pump
Here is what I looked up: Fuel Pump Removal & Installation To Remove:
  1. Remove the fuel tank.
  2. Disconnect the pressure transducer connector on the top rear comer of the fuel tank.
  3. Clean the area around the fuel pump mounting flange.
  4. Remove the bolts and remove the fuel pump.
CAUTION
The fuel pump must be handled carefully to avoid damage to the float arm and the filter.
Remove and discard the fuel pump mounting gasket.
To Install:
  1. Clean the fuel pump mounting flange and the fuel tank mounting surface.
  2. Install the fuel pump mounting gasket on the mounting flange.
  3. Position the fuel pump in the fuel tank. NOTE: Tighten fuel pump bolts in a star pattern.
  4. Install the bolts. Tighten to 10 Nm (89 in. lbs.).
  5. Connect the fuel pressure transducer.
  6. Install the fuel tank.
Jul 05, 2010 | 2000 Mercury Grand Marquis
How to drain ford fusion fuel tank
The "MOST EFFECTIVE
" way is to REMOVE The FUEL TANK and DRAIN it By Tipping it over to Pour From FUEL INLET HOSE. Im Sure you Dont want to Here this as it Requires Much WORK . , BUT It IS The MOST EFFECTIVE Way to EMPTY The TANK.
Oct 31, 2009 | 2004 Ford Fusion
Cleaning the gas tank
Clean it how? Why? Removing the tank is usually a simple process, remove the connecting hoses that go forward, release the 2 straps the hold the tank up, there are usually 2 half inch or 14mm nuts holding the clamps 1 on each, and lower the tank. having told you all of this there is no cleaning solution you can use inside the tank to clean and the worst thing you could possibly do is put water in the tank to clean it. In fact, if the fuel pump isn't located in the tank there is only going to be a 2 1/2 " hole where fuel is added to the tank and the line connections to access the tank. Good Luck.
Sep 09, 2009 | Cars & Trucks
How to replace my 2001 ford taurus fuel pump Instructions
2001 Ford Taurus V6-3.0L DOHC VIN S
Fuel Pump: Service and Repair
REMOVAL
2. Clean the area around the fuel pump mounting flange.
3. Using the special tool, remove the fuel module retaining ring.(Screwdriver and hammer)
4. Remove the fuel delivery module from the fuel tank.
CAUTION: The fuel delivery module must be handled carefully to avoid damage to the float arm, filter, and convolute hoses.
INSTALLATION
1. To install, reverse the removal procedure.
NOTE: A stop should be felt when aligning the raised arrow on top of the fuel tank delivery module to the dot on the fuel tank.
Sep 08, 2009 | 2001 Ford Taurus
Garden Logo
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
