Question about Dishwashers
Forgot salt compartment lid
I forgot to put the lid back on the salt compartment. Ran a wash with dishwasher cleaner. Then found lid on kitchen table! Does this matter? Will the dishwasher be harmed?
  • 14 Answers
SOURCE: Detergent lid won't latch shut
The whole dispenser will need to be replaced, they only come complete
Posted on Sep 08, 2007
  • 54 Answers
SOURCE: diplomat slim dishwasher ADP8352
sounds like yhe pcb is faulty
Posted on Feb 12, 2008
SOURCE: Dry Dishwasher Soap Still in dispenser after wash.
so here it is...
get a screw driver (you may need a "star" head driver as well), get in there and take out all that you can and clean it (it all comes out pretty easily)...you will find a lot of undisolved soap and hard water build up...rinse it, scrape it, vacuum it...just get out as much as you can...keep note of how you took it apart so you can put it back together...then put 1/2 to a whole gallon of vinegar in and run a cycle (hi-temp if you have that option)...if it was like mine most of your sprayers were gummed up and the water just wasn't moving through the machine...
to avoid this problem...use half of what you have been using of your detergent...and only fill the "pre rinse" section if you are doing pots and pans....and then only fill that half way as well.
after that run a few cups of vinegar through on an empty cycle once a month...
whole job (not including the wash cycle) 1.5 hours...
Posted on Aug 31, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: ran without water will not fill now
Try unplugging the machine for 30 minutes then plugging it back in. I am worried that the pump is bad due to the fact that it needs water to add resistance to work properly and without water the pump spins so free the it burns itself out. But first try unplugging the dishwasher first
Posted on May 22, 2009
Obertelli
  • 3006 Answers
SOURCE: I put powder detergent in salt compartment in my
Just flush it out by pouring plenty of water into the receptacle. You don't have to get every last trace out. Make sure to wear rubber gloves and possibly eye protection as the powder is caustic and so you need to avoid skin and eye splashes.
You could alternatively leave the salt chamber cap off and run the dishwasher empty for a couple of cycles; that will allow the powder to dissolve without any chance of you getting splashes on your skin.
Posted on Nov 13, 2009
Testimonial: "Obertelli, Thank you very much for your quick response. I'm glad that the solution is not as drastic as I thought it would be. "
Do you need to put salt in the dishwasher. If using tablets detergent ...where to put it ?
A lot of dishwashers do not have salt dispensers. If it does, the salt is added to a container which has a lid on the base (floor) on the inside under the bottom basket. Unscrew the lid and add the salt. Use normal pool salt. It is the same as "special dishwasher salt" that you pay a lot for. When full, the salt will last for 12 to 18 months. Most machines that have a salt container, also have a warning light on the panel to let you know it needs refilling. Dishwasher tablets do not add salt to the machine. Make sure you wipe up any salt that you may have spilt on the base of the machine, it will stain or rust the cabinet.
Sep 25, 2014 | Dishwashers
What do these mean on a zanussi dishwasher model DE 6854
The top light is apparently to indicate that the salt (!) has run out.
The bottom light is apparently to indicate that rinse aid has run out.
For the record, that seems to be a Zanussi DE-6854 dishwasher, and I found the manual here: (link)
"Special salt can be added in one of two ways: 1) If you are using dishwasher detergent that already contains salt, the detergent including the salt is placed in the detergent compartment. - In this case the water softener must manually be set to 1 and electronically to 1 to ensure that the special salt is taken from the detergent container only. 2) If you are using dishwasher detergent and salt separately, the special salt is to be put into the salt container. - In this case the water softener must manually be set to 1 or 2 and electronically between 1 and 5 (depending on the water hardness in your area) to ensure that the special salt is taken from the salt container only. Only use salt specifically designed for use in dishwashers. All other types of salt not specifically designed for use in a dishwasher, especially table salt, will damage the water softener. Only fill with salt just before starting one of the washing programmes. This will prevent any grains of salt or salty water, which may have been spilt, remaining on the bottom of the machine for any period of time, which may cause corrosion." (Page 6)
"Only use branded rinse aid for dishwashers. Never fill the rinse aid dispenser with any other substances (e.g. dishwasher cleaning agent, liquid detergent). This would damage the appliance." (Page 7)
The manual also explains how to turn the Rinse Aid light off permanently if you do not wish to use rinse aid.
Mar 23, 2013 | Dishwashers
What do these lights mean there not going off
Where do i put salt
Typically under the bottom rack on the floor of the dishwasher. There will be a cap to remove and add salt.Use dishwasher salt which is different from table salt.
If you can find the model number you can download the exact manual from herehttp://kitchen.manualsonline.com/manuals/mfg/haier/haier_dishwasher_product_list.html
Mar 04, 2012 | Haier Dishwashers
Where do i put the salt
Hello Maria,
The salt goes in the salt compartment in the base of the washing compartment. Unscrew the lid of the salt compartment (counter-clockwise), pour in salt until the compatment is full or nearly full then screw the lid back on firmly, but do not overtighten it.
If the dishwasher is new and you are using it for the first time, pour about 1 litre of cold clean water into the salt compartment before adding the salt. If you spill any salt or the water spills over the top of the salt compartment, it will wash/drain away the next time you use the washer.
The most important thing is to only use dishwasher salt. The salt is used for water-softening and only salt sold specifically for dishwashers can be used for this purpose.
The picture above is from a Bosch dishwasher. You may have another brand or model of dishwasher, but the salt compartment will still be in the base of the washing compartment and will have a cap which you unscrew as above.
Hope this helps. If you need further assistance, please let me know the brand and model number of your dishwasher.
Regards,
BElectric
Mar 14, 2011 | Dishwashers
Dishwasher is not draining properly. Left the lid off the salt portal.
If anything other than salt can enter the salt portal, the decalcification system might get broken. I once, by accident, filled the cleaning agent into the salt compartment. The whole decalcification system had to be exchanged. The technician said, that nothing else but salt should enter the salt compartment and even leaving the lid open while using the machine can compromise its functionality.
Jan 16, 2011 | Siemens Dishwashers
My salt light stays on my dishwasher. Where do I buy the salt suitable for the Danby Portable Dishasher? I DO NOT WANT TO HAVE TO PAY ANYONE FOR ASKING THIS QUESTION, AFTERALL, I HAVE PAID FOR THE...
HI,
You can buy dishwasher salt in almost every supermarket. It can usually be found in the section with other household cleaning products such as soaps and washing powders. Make sure you are buying dishwasher salt. Do not use table salt or any other type of salt not designed for use with dishwashers.
You have not been charged for this information ;)
Regards,
BElectric
Dec 12, 2010 | Danby Dishwashers
My dishwasher is flashing for salt it is a Miele and i want to know what kind of salt to put in and how much - i have the plastic bowl thing to put it in the dishwasher
Use the salt supplied by your service provider. Or try in a super market.Ask for dish washer salt.
If a plastic funnel is supplied use it to fill the salt compartment. The quantity as it holds.
Do not fill kitchen salt used for food!
Sep 30, 2010 | Dishwashers
What kind and how much salt goes into my miele G575 dishwasher?
Straightforward, coarse, dishwasher salt (sodium chloride). Regular table salt is far more expensive and because it's not coarse it clogs when pouring it in.
Just pour salt into the salt chamber until it's full and screw the lid back on.
Mar 15, 2010 | Dishwashers
Dishwashers Logo
41 people viewed this question
Top Dishwashers Experts
