Question about Element Electronics FLX-3211B 32 in. LCD HDTV
Connecting my 2.1 sound system to my TV
I have my Element ELFDW406 connected to the (RCA) Audio Output on my TV. My TV speakers are still on, and no signal seems to be going to the 2.1 Sound System from the Audio Out on the TV. This TV has no headphone jack which I used on other TVs for the sound system. I cannot find anything in the menu via the remote that lets you shut off the TV speakers and switch the audio out via the RCA output. Any Ideas?
ButtFuzz
  • 463 Answers
SOURCE: No Audio no video on an Element FLX3710
Bad control board. ~$300. Take TV back to wherever you bought it if still under warranty or Purchase new TV.
Posted on Mar 13, 2009
  • 100 Answers
SOURCE: Element 26 model ELCHS 261. The tv powers up ok but
has problem on the board.the solder is loose or loose solder
Posted on Jul 18, 2009
budmrtn
  • 11361 Answers
SOURCE: the video cuts out after 1 minute the tv is turned
The backlight inverter board may be going out, or bad capacitors in the power supply.
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Nov 08, 2009
  • 210 Answers
SOURCE: lost entire picture, sound and everything else OK
check the invertor boards resistors they power the back lights
also check for any capactors that have blown (raised tops) they look little bateries
Posted on Dec 12, 2009
Testimonial: "Your response was quick pointed me in the right direction I might need help with ID of components to continue"
budmrtn
  • 11361 Answers
SOURCE: Element 32" TV. Power only for a few seconds, no audio.
Yes, look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc. http://en.wikipedia.org/wiki/Capacitor_plague
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=FLX3220F+
Please post back what you find.
Posted on Dec 22, 2009
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
Connecting tv external speakers
If you connected R/W RCA cables to the AUDIO OUT RCA jacks on the rear of the TV and connected the other ends to the TV AUDIO IN jacks on the receiver, you should be able to select an input on the receiver that will deliver sound to the Bose speakers. If you went to TV setup and selected external speakers, you directed output from the TV amplifier to external speakers which is not what you want.
Jan 27, 2014 | Televison & Video
Why? no sound from the speskers at all.
There are a few things that could cause no sound and although some are obvious I'll got through them all..
1) Sound is on Minimum
2) Sound is Muted
3) No Power to Subwoofer
4) Speakers connected Incorrectly or Faulty
5) No AUDIO IN connections to TV-IN or AUX-IN
6) Incorrect Input Source is Selected (See Below)
Connecting audio from TV
When connecting the audio output from your TV to this Home Theater Audio System, you will have the sound of the
TV output on all the speakers. It will enable you to enjoy the multi-channel surround sound capabilities.
Use an audio cable (red/white - not supplied) to connect the TV IN jacks on this DVD system to the AUDIO OUT
jacks on the TV. To listen to the sound, press TV on the remote control as the sound source that you want to play.
Connecting audio from an audio/video device
This DVD system provides analog and digital audio connection. You can connect the audio output from an
audio/video device (e.g. VCR, Cable/Satellite Box) to this Home Theater Audio System in order to enjoy the
Use an audio cable (red/white - not supplied) to connect the AUX IN jacks on this DVD system to the AUDIO OUT
jacks on the connected device. To listen to the sound, press AUX/DI to select "AUX" as the sound source that
you want to play.
Or
Use a coaxial cable (not supplied) to connect the DIGITAL IN jack on this DVD system to the DIGITAL OUT jack on
the connected device. To listen to the sound, press AUX/DI to select "DI" as the sound source that you want to play.
Please leave feedback
Cheers
Andy
Apr 27, 2011 | Philips HTS3450 System
How do I connect my RCA standard definition television to surround sound if it doesn't have an audio output. I purcahased a colby surround sound system with DVD. I can't get the system to operate with my...
To connect your sorround sound system to your TV that doesn't have audio and video inputs, you have to use an RF modulator, this devices converts your audio and video signals into a channel 3 or 4 VHF channels which you can tune at your TV connecting a coaxial cable, to change from DVD player to antenna without disconenecting cables, you can add an antenna switch device (2 inputs 1 output), this devices should be available at any elecronic parts store.
Feb 11, 2011 | RCA Televison & Video
Does my tv have audio outputs?
42PG20 Connections
  • Connector Type
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Rear ,
  • 1 x S-Video input ( 4 pin mini-DIN ) -
  • Rear , 1 x Digital audio output (optical) ( TOSLINK ) - Rear ,
  • 1 x Remote control ( Mini-phone 3.5 mm ) - Rear ,
  • 1 x Serial ( 9 pin D-Sub ) - Rear ,
  • 2 x Component video input ( RCA phono x 3 ) - Rear ,
  • 2 x Audio line-in ( RCA phono x 2 ) - Rear ,
  • 2 x HDMI input ( 19 pin HDMI Type A ) - Rear ,
  • 1 x VGA input ( 15 pin HD D-Sub (HD-15) ) - Rear ,
  • 1 x Audio line-in ( Mini-phone stereo 3.5 mm ) - Rear ,
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Side ,
  • 1 x HDMI input ( 19 pin HDMI Type A ) - Side
42PG20 Audio System
  • Sound Output Mode Stereo
  • Surround Mode Yes
  • Sound Effects SRS TruSurround XT
  • Audio Controls Bass , Treble , Balance , Sound mode
  • Speakers Included 2 speakers
  • Output Power / Total 20 Watt
  • Additional Features Auto volume adjustment
  • Speaker(s) 2 x Right/left channel speaker - Built-in - 10 Watt
Feb 04, 2011 | LG 42PG20 42 in. Plasma HDTV
How can I hook up my Bose cinemate on my Philips HD tv when no there is no Audio out and I want to use it for my dvd player, cable box, and video systems?
You don't need to send audio TO a TV. I's a TV, not a source of anything. Many of us use monitors (no TV speakers). The Bose speakers are presumably superior to the TV speakers so whatever the TV is watching (cable/sat/dvd) shuld have its own audio.
Page 11.
If your TV does not have any audio output jacks, you can connect the CineMate™ speaker
system to the audio output jacks of another source, such as a DVD player or cable/satellite
box. However, you will hear sound only from the connected source through your CineMate
speakers.
http://www.retrevo.com/support/Bose-Cinemate-Speaker-Systems-manual/id/526dj591/t/2/
Dec 25, 2010 | Bose Cinemate Digital Home Theater System...
Model ELCHW402 40" LCD
The TV has two audio out options: a digital audio out (coaxial) and a 3.5 mm headphone jack. Both of these are just above the antenna in connector. The headphone jack is the top one.
For a sound system that uses RCA stereo plugs, get a 3.5 mm (M) to 2 red/white RCA F adapter at the headphone jack and use an RCA audio cable from the adapter to the sound system. Alternatively, you can use a 3.5 mm audio patch cable from the headphone jack and the 3.5 mm (F) to 2 RCA (M) adapter at the sound system. The TV speakers will probably be turned off automatically with this connection.
If your sound system has digital audio, get the digital audio cable. You will need to enter the menus to make this audio output active. See the Audio menu > SPDIF Type (PCM, Dolby or Auto).
I hope this helps.
Dec 24, 2010 | Element Televison & Video
Their is no volume
Hello
There is no sound you means? If so what about the picture? If picture is ok and there is no sound either the speaker of your tv or audio output Ic inside your TVs circuit board is faulty.
To check it, place your ear very close to the speaker side of your tv and turn it on. if a "thumb" sound or a "hum" sound is heard from your TVs speaker, the output Ic is faulty. If there is no sound at all, speaker is faulty. If you have any home theater system; and your TV has audio out RCA sockets at the rear or front side of it, connect it to audio system, and swich on both and find if there is sound output or not. If yes you can assure your TVs sound filtering system is ok, and the fault is somewhere between speaker and audio output Ic. Ok.
Oct 19, 2010 | RCA F20640BC 20" TV
Picture but no sound
check audio speaker ,audio ic & its supply voltages,check audio signal
Jan 10, 2008 | Televison & Video
Element Electronics FLX-3211B 32 in. LCD HDTV Logo
52 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
