Question about Dyson DC25 Animal Bagless Upright Vacuum
How do I remove screw - Dyson DC25 Animal Bagless Upright Vacuum
  • Dyson Master
  • 1,510 Answers
You must use a Torx tool to remove the screws.
Posted on Nov 06, 2013
How to remove fan from rsl3c ?
Remove the bottom plate screws & bottom plate. Remove the screws holding the motor and fan assembly to the nozzle housing. Remove the screws Holding the fan housing to the motor to gain access to the fan. Remove the bolt holding the fan on the motor shaft to remove the fan.
Sep 08, 2014 | Riccar Vacuums
Stripped screw on shark navigator plate
drill the head down to the shaft of the screw then remove plate, remove remainder of screw if possible, fit new screw.
Dec 30, 2013 | Vacuums
How do I pop the top off to replace level adjustment lever.
Turn the machine over (with the handle released). Remove the 4 screws (2 on each end of the cover over the brush). Remove the cover. There are 2 screws, deep in the machine (behind drive train wheels) remove the screws. With the machine in the same position, note 2 plastic clips located on either side of the top cover. Release the clips using a slotted screw drive.
Nov 28, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
How do we get the plastic cover off the machine? We have removed all visible screws on cover and plate, removed cover over light bulb area, and plastic extension around plate area. We are trying to...
Is this a sewing machine? Plastic covers can be tricky to remove. Look for deeply set screws in deep holes, as well as screws that might become visible after removing covers. Sometimes the screws holding the rubber feet on will also secure the cover.
Aug 20, 2011 | Vacuums
How to replace the power switch on a Kirby G4
This repair requires extensive disassembly. First remove the handle, bag assembly, and switch "scuff" plate. To remove the switch plate, remove the screw at the bottom, and the upper screw that secures the cord. Insert a screwdriver into the rectangular slot in the plastic and pop it off. The cord must also be removed. One screw holds the cord cover to the lower motor shell. Remove the screw and push with a flat screwdriver on the back of the cover to unlatch it. Next remove the upper motor shell ( 4 screws ). The next piece to come off is the switch button. Pry upward on it's attaching lugs to free it, pull it upward far enough to disconnect it from the switch rod. The power drive assembly is next to go. Three screws on the bottom of the motor unit hold it in. DO NOT remove the center screw beneath the shift lever. The drive pedal must be in DRIVE for removal. The transmission drops down to get it out ( you may have to wiggle and pull on it to free it). Next the headlight frame assembly must be removed. You will see 2 screws at the rear, and 2 long screws in front which also secure the fan housing. After removing the screws, the headlight frame can be removed. Be careful to note the proper location of all wires! The right carbon brush assembly must be removed to allow the switch to slide back for removal. It is held in place by 1 screw and a tab on it's holder. Two screws hold the switch itself in place. One is on a tab on top of the switch, and the other is on the right bottom of the lower motor shell. The lower screw also serves as a motor mount screw. The switch can now be removed by inserting a small screwdriver along it's front edge and prying it backwards. It is wise to clear dust and lint from the motor contacts prior to re-assembly. Be sure the terminals on the field coil have not gotten bent before putting the new switch in place. Snap the new switch in place and replace the screws. It is easiest to replace the wires in this order:
1- Holding the headlight assembly off to the right, install the lower headlight wire.
2- Next connect the wire from the left carbon brush to the upper switch terminal.
3- Connect the upper headlight wire.
4- Gently replace the right carbon brush assembly, secure it with it's screw ( do not overtighten ) , and connect it's wire to the lower switch terminal.
After the switch is in, install the headlight frame screws, transmission and belt, and switch button in reverse order. Be sure the shift arm on the left side of the drive unit engages the slot or pin on the handle pivot assembly. The cover and trim pieces can now be re-installed.
Feb 16, 2011 | Kirby G4 Bagged Upright Vacuum
How do you get to the fan on the generation 3 kirby
First remove the handle, next remove the screws attaching the cord, and switch trim plate. The small screw and knob on the handle pivot must be removed to remove the switch trim piece - insert a flat screwdriver into the small slot in the plastic and pop the trim off to expose the rear motor shell screws. Remove the four screws holding the upper motor shell in place to expose the fan housing screws. Remove the five screws holding the fan housing in place, noting their positions. Pry the fan housing off to expose the fan. Hold the fan in place while turning the belt pulley CLOCKWISE to remove it. If the armature turns, it must be held in place with an open end wrench (about 9mm). There are flat spots on the armature just in front of the commutator bars. Pull or pry the fan and associated washer off the armature shaft. After replacing the fan and pulley, put a bead of silicon sealant on the fan housing and replace all parts in reverse order of removing.
Dec 01, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Motor filter replacement
If you are talking about the motor cooling filter round filter like this here then you must have removed wrong screws. Screws that you want to remove are hidden under clear lenses on the sides of the unit. You will need a screwdriver to remove the lenses (2 latches at the top of each lens). Once you have removed lenses you will see screws (4 or 6 - depending on the e-series model). Remove them and you will have the access to the filter.
Good Luck
Aug 26, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Removal of cover
There a number of screws, remove the brush block, there are acouple of screws there, Then on each bottom edge is a screw sit deep in a hole. There are some more scres, you can see them from the bottom, 2 of which are close together and longer, these help hold the turbine. turn it over, there is a screw near the edge of the noozle, it should lift off, the 2 posts near the back are just pushed in and should come free. The turbine will have a couple of tubes and 2 screws on the front of it, then it come come off.
Jun 28, 2008 | Hoover SteamVac F5914-900 SpinScrub...
U6446-900
from the underside: 1. remove 4 screws holding agitator cover in place 2. remove 2 screws (black screws) holding hose retainer in place, pull hose out through top 3. remove three screws, 2 long, 1 short holding top cover: short screw is at center of inside of brush housing, long screws are inboard of wheel axles, and slightly forward (all of these screws are aluminum colored) 4. from inside surface of each side, at approx the center, locate and push down on ledge inside right and left inside with a screwdriver to slightly displace the plastic ledge that holds the cover on; this ledge-lock-detent can be released with your fingers. You'll have to support the drive mechanism to allow the top housing to drop free. 5. remove housing, turn vacuum over, then go find the torx driver you need to disconnect the cable. Good Luck MB http://in4m8ion.com
Aug 19, 2007 | Hoover U6630-900 WindTunnel Bagless...
Dyson DC25 Animal Bagless Upright Vacuum Logo
22 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
