Question about Garden
How to kill crab grass - Garden
We have a weed spreading rapidly it has been identified as Richadia have used Metsolfuren which only kills it temporarily but also kills the grass ....we are looking at a 5 acre patch
There are chemicals on the market such as Round Up Or Weed Be Gone. or others that you can use to completely kill this weed. I have used Weed Be Gone and it does not kill the grass. Whether it kills this weed you would have to see. If you use Round Up it kills every thing even grass. I have sprayed a large area then replanted grass after the weed is gone.
Dec 17, 2017 | Garden
Want to kill grass is vinegar by itself enough ot do i add water to it
One quart of vinegar -- with 20 percent acetic acid -- mixed with 4 ounces of lemon juice will kill the above-ground portions of the weeds and grass. The foliage, flowers, buds and stems will wither, dry and die, but the weed's roots are left intact. For a tougher weed and grass kills, combine 1 tablespoon of 20 percent vinegar, 1 tablespoon of gin, 1 quart of water and 1 teaspoon of dish soap. This mixture kills the above-ground and below-ground portions -- including roots -- of the weeds.
Oct 14, 2016 | Miscellaneous
What is the mixing rate for round up to kill broadleaf weeds such as thistle, parthenium etc so that I do not kill the grass
Any round up mix that will kill the weeds will kill the grass. the only way I can think of is to tie a sponge to a stick dip in round up and apply to each weed, you will not have to cover the whole weed, just touch a few leaves.
Sep 03, 2016 | Garden
How does one remove strawberrys from ones lawn
A liquid broad-leaf herbicide (2, 4-D) has worked best for me when I needed to get the strawberries out of my lawn. Won't kill grass.
Aug 20, 2012 | Scotts 71030 Easy Hand-held...
Of roundup powermax do I mix per gallon of water to kill grass and weeds?
last bottle of this product I had , it had a lift off label that included all the mixing instructions ,
I will say if you have long fence lines or large areas of grass/weeds to kill , id use something a bit more economical as this product /it works well but it is a bit on the expensive side for large areas , ive found that just a block of softener salt soaking in a five gallon pail of water for a few days , works very well for large areas of land sprayed on to clear it of weeds and grass (although it's not rain proof)
May 14, 2012 | Garden
How soon can weeds be mowed or watered after application of roundup?
Depends a littlebit on what tpe of weed but normally 24 hours after application on an actively growing weed is enough for it to be taken into the plant
Aug 03, 2011 | Roundup "" Weed & Grass Killer
I cant kill them
Crabs are very hard to get rid of - be thankful they are not bed bugs. Bed Bugs using GPS are extremely hard to kill.
Try pouring gasoline on them and then see if that cures the problems.
Best of it
Gary @ Fix Ya
Mar 31, 2011 | Cycling
I have kukuyu grass growing around my vegetable patch and I want to kill a patch of grass 30cm around the veg patch. What proportion of roundup should I use per litre and will it affect the vegetables?
Using the standard 10ml of Roundup per litre of water you can kill the grass without harming your vegetables. I would spray only on a nice calm day and use a piece of cardboard to block any over spray from reaching your veggies. Roundup works through absorption by leaves so transfer by groundwater is not a concern. Also remember more is not better with Roundup, too much just kills the leaves before they can absorb the toxin and kill the root.
Mar 30, 2011 | Roundup "" Weed & Grass Killer
I will be applying Roundup to a large section of my lawn to kill a bermudagrass infestation. Will the Roundup work better on longer grass or a freshly mowed lawn?
Round up will work on any grass...I prefer to mix it a bit stronger when I know I am trying to kill grass... but yes it works... ask my daughter who wanted to help and spray the weeds for me and then decides to play around in the yard writing her name....:-)
It can take a week for a full killl though...
heatman101
Aug 12, 2010 | Roundup "" Weed & Grass Killer
Son used roundup in backyard to kill weeds.
round up i think has a two week withholding period, so wait two weeks & turn the soil over & re seed is the only way I can see
Jun 01, 2009 | Roundup "" Weed & Grass Killer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
