Question about Vehicle Parts & Accessories
Ingnition switch 1999 chevy lumina.. changed ing switch.. car will start with key, but will not turn off
    Top Expert:
  • Vehicle Part... Master
  • 12,223 Answers
See the diagram attached, and fix it. test the starter relay +solenoid . God bless youingnition switch - 62f66ef4-1591-4c2e-801b-8e050e9fdd60.gif
Posted on Jul 21, 2013
Alarm won't shut off on 1999 Chevy blazer 4x4
Is it factory alarm or aftermarket??. Try using the key to lock and unlock the doors driver and passenger then turn the ingnition on with the key and leave it in the key on engine off position for a few minutes and start the vehicle
Oct 14, 2012 | Cars & Trucks
My 1999 chevy lumina only starts sometimes....HELP!! wat
If your key has the resistor pellet in the key then more than likely, the pellet is worn. This is normal wear and tear from just putting the key in and out of the ignition over the years. You could either purchase a new key or, install the resistor inline at the ignition.
Oct 02, 2012 | Barnett Crossbows Speaker Wire Harness...
How do u unlock your steering wheel and ingnition for a 99 sunfire gt
Place ing key in ingtion make sure u r in park or clutch if a stick shift is pushed all the way to the floor, then grab stering wheel tight turn wheel to left and hold while turning ing key, or try turning wheel to right while trying ing key, steering wheel can lock with pressure causing ing key to be non turnable same with transmision, park or clutch to the floor. Hope this helps
Mar 05, 2012 | 1999 Pontiac Sunfire
Starter key switch wont turn
MORE THAN LIKELY THE ING SWITCK / KEY AND TUMBLER NEEDS TO BE REPLACED, BUT TRY TO MOVE THE STEERRING WHEEL RIGHT OR LEFT COULD BE HUNG IN LOCK POSSION
Jan 10, 2012 | 1999 Chevrolet Malibu
My 1999 chevy lumina will not start, the battery is fine, but when the key is turned, it doesn't even click. May be the starter, but not sure?
It will either be the starter solenoid or the ignition switch being faulty. Check those, if you are unfamiliar with the components i suggest you take it to a repair shop. Those are cheap fixes even if you have someone do it for you. I hope i was able to help. Please rate if i did.
Thank you!
Mar 30, 2011 | 1999 Chevrolet Lumina
Ingnition problems for 1999 chevy silverado wont start wont crack over when you turn the key on but you have dash lights when your trying this
maybe not strong enough battery or try shifter moving while you try to start.. may be neutral safety switch so try jiggling the shifter in park and neutral. also the key may need to be cleaned the fobs get dirty where it wont read it, got a spare try it....
Dec 10, 2010 | 1999 Chevrolet K1500
How do you check and replace the igintion?
loose battery connection, or loose wire, ground wire maybe.
Oct 22, 2009 | 1997 Chevrolet Lumina
Ingnition switch
yes you will need to reprogramme the key to the key reader otherwise it won,t start yates210456
Jul 13, 2008 | 1999 Honda Accord
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
