Question about Husqvarna Garden
Chainsaw manual Cut out switch won't work
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Husqvarna Master
  • 102,366 Answers
What model Husqvarna chainsaw?
Posted on Jul 21, 2013
2 Suggested Answers
redneck77lc
SOURCE: Chainsaw won't start. Has spark, has fuel, chain
does it have a primeing bulb?
Posted on Apr 05, 2012
1998 Honda Accord Won't Start
Park neutral safety switch maybe be the reason for the no crank ! Try putting the vehicle in park ,then try to crank the engine . Testing the electrical circuit is the best way to trouble shoot this problem , along with do a voltage drop test on the starter circuit ! This will test the battery cables an connections .
Starter Voltage Drop
How to voltage drop test starter motor circuit
Does it have a manual or automatic transmission ? Manual ? clutch switch . Looking at a wiring diagram I also see a starter cut relay !
http://www.bbbind.com/free_tsb.html Free wiring diagrams . Enter vehicle info. year , make , model and engine size . Under system click engine , under subsystem click starting . Then click the search button , then click the blue link ! Check the starter cut relay also . Videos on youtube showing how to test a relay controlled circuit !
May 29, 2017 | 1998 Honda Accord
My poulan 18 inch chain saws blade turns but only cuts in about an inch and won't go any farther. It's two days old and worked fine cutting the first 2 trees down.
It sounds like the chain does want sharpening, it depends on what you are cutting ( type of timber, dirty timber,burnt timber etc ) as to how long before it needs sharpening, if the chain comes into contact with the ground below the tree it will lose its edge instantly.
Dec 29, 2012 | Poulan Wild Thing 2375 18" Gas Chain Saw...
It starts but won't stop when switched off by stop button it's a husky55
Apr 04, 2012 | Homelite Garden
Electric chain saw pole wouldn't cut branches
Check to make sure the blade is not installed backwards. It's an easy mistake to make, everything will work OK, but the saw won't cut if the blade is on backwards.
Mar 15, 2012 | Remington Electric Chain Saw
Water wouldn't not stop used a half of loaf of bread.
This has to be the most interesting problem I have ever seen... Chainsaw, water that won't stop, and you used a half loaf of bread... I really can't imagine such a scenario... Let me try one... you cut a drain pipe with the chain saw and stuffed a half loaf of bread to block the cut pipe?
Aug 16, 2011 | Garden
My remote will not cut on my Bose Cinemate system. I have changed the batteries in my remote and the red light on the receiver is illuminated, so I know the system is operational, . I've also unplugged...
It seems to be a common misconception that the remote is necessary to turn a device on. All devices have hard-wired power controls. Does THAT work? It is unclear which device (remote or the Cinemate) is malfunctioning. If the Cinemate won't turn on by its own power switch the remote won't magically bypass whatever the problem is.
The Cinemate Manual offers some steps to take if it won't turn on, as well as other guidance.
Bose.com
Jul 31, 2011 | Audio Players & Recorders
My Ariens 34" zero turn's
there is a switch under the hand brake that you can by pass this is not a good idea but it works e-mail me when you get it whitejeff74@yahoo.com
Jul 19, 2011 | Garden
Wagoner Procoat Airless Sprayer without manual. Won't prime.
One cause for this is that one or both of the check balls in the piston are frozen in place. This can be caused by drying paint on the check balls or seats or, as is the case many times in our area, if you did clean the machine well with water without any airless conditioner in it, sometimes the water dries and leave behind minerals that 'lock' the check balls in the seats. Set the machine up in water and turn it on to prime. Using a hammer hit the pump head where the piston is working fairly hard. You are trying not to break anything but knock the check balls loose. If they come loose and water starts cycling through the system, let run a while to wash anything out before switching to paint. If this doesn't work, you may have to take the head apart to see why the check balls won't free up. It could be because of peices of dried paint that won't come loose by themselves.
Jun 16, 2011 | Garden
I have a Husqvarna 235 that decided it didn't want to start anymore. It's only a few months since I got it. It was used the cut up a small tree that fell down in a wind storm and used again while...
Has the fuel been in it since you last used it? if so drain and re fill with fresh fuel oil, work the primer plenty of times to flush the old fuel out, crank the engine twice only with the choke out, then push it fully back in and crank again until it fires up.
Jun 08, 2011 | Garden
Garden Logo
22 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
