Cb(x)26uh(-r) SERIES UNIT IS DRIPPING A CORNER
IT IS SPORADIC DRIPPING IN JUST ONE CORNER I NOTICES PUDDING TYPE OF SUBSTANCE AT OUTSIDE DRAIN OFF
  • 232 Answers
SOURCE: Condensate drain not working. Water driping from
the drain coming off the unit is the one you need to clear, not the secondary pan. its usually clogged in the P trap which is usaully not far downstream from the outlet on the coil.
Posted on Sep 13, 2009
Testimonial: "There was no p-trap installed so I decides to cut the pvc pipe six inhes south of the coil. Cleaned debris and replaced drain. All is well.. Thank you"
  • 22 Answers
SOURCE: Excessive water dripping from Central A/C drian line
sounds like the overflow drain is picking up the water that means the main drain is clogged.you need to find the main drain pipe if lookin at the air handler in attic there should be 2 drains from unit one higher than other follow it and blow out drain they put the other overflow drain out the eve so if it stars leaking someone notices it and it doesnt damage cieling but it sound like it needs imediate attention befor it does go to the overflow pan and damage your cieling. i hope this helps and good luck
Posted on Sep 29, 2009
  • 2006 Answers
SOURCE: All my other AC Units
If you have a CENTRAL air unit, you should have an overflow to a drain in the furnace area. So I don't understand what you are saying about a connection to the drain under the sink!
Do you have the make and model correctly listed? Because with your question it does not agree what I know about the Ruud Central air that you listed.
Posted on Aug 08, 2011
  • 4736 Answers
SOURCE: it's a small window unit made by ADMIRAL and i
From what you have described, it sounds like the drip pan's drain hole, near the rear of the unit is clogged and/or there is not enough downward tilt on the rear of the unit. The general rule of thumb is 1/4" to 1/2" downward tilt.
The drain hole can be a challenge to find, as the clog will blend in with the drain hole. Persistence and patience while looking for it will help. A pipe cleaner works well to clear the drain hole.
Be sure to turn the unit OFF & unplug it before attempting and maintenance.
Hope this helped you ans thanks for choosing FixYa.
Posted on Aug 14, 2011
  • 4736 Answers
SOURCE: My 5200 wall air conditions
The outer drain hole is the only one that needed to be cleared. But, keep and eye on it, as there may be some floating debris in the drip pan. You said the unit is angled enough at the rear. So, I'm assume you have at least 1/4" to 1/2" downward tilt at the rear of the unit. If that's the case, for now, that's about all you can do. Unless you have a Wet/Dry Shop Vac. In which case you could **** the water out of the drip pan after removing the front panel of the unit. If you attempt this, be sure the Master ON/OFF switch on the unit is OFF and the unit is unplugged.
Hope this helped you and thanks for choosing FixYa.
Posted on Aug 26, 2011
Coleman Mach 48000 series roof top A/C in my camper & recently it's been dripping heavily inside the camper. We looked at the top & inside for a clogged line & can't find anything, suggestions?
I had the same problem but it wasn't a clogged drain line, it was the gasket between the roof of the camper and the AC unit. The gasket had shrunk and pulled apart allowing rain water in. To make sure you don't have a clogged drain line when using the AC do you notice water dripping off the camper anywhere besides inside? You should have some drips somewhere on the outside.
Jul 18, 2017 | RVs
My Carrier Infinity system Model FE4A is leaking water from the bottom of the unit on to the basement floor. How do I stop the leak?
have your HVAC technician check the pressures in your unit...sounds like you may have low pressure. You should NOT be having any ice build up to melt off.
Sep 13, 2014 | Carrier Infinity Series Variable Speed...
There is not any condensed water coming out the back of the unit. Is this a problem?
the amount of condensate water is related to how much humidity the unit is pullling from the cooling space.
It's possible that water is actually dripping from the unit and it is so little you're not noticing it.
However, if the unit is 'cooling' ok - I would not worry about the lack of water - unless - water starts to drip "inside" from the front of the unit - in which case you will have a problem with the drain.
You could also check the unit and make sure it has a slight tilt to the outside.
Also, you could check and see if the drain hole is clogged up - preventing water from draining.
Hope this helps.
Jun 06, 2010 | Maytag M6Y12F2A Air Conditioner
Water dripping from air con use
If the unit is mounted on an outside wall check the condensate drain that comes out with the line-set to the outdoor unit. If the pipping goes up into the attic than you have a small condensate pump that may have failed. The float in the pump may have stuck in the down position not allowing the pump to come on.
Nov 08, 2009 | Fujitsu 24C1 Air Conditioner
Sep 29, 2009 | Amana PTC153B35AJ Air Conditioner
Dripping water from pan or coils
If the a-coil is on the suction side of the blower, the drain line needs to be trapped. take enough hose to make a circle below the drain fitting and then into the drain. The blower causes a suction up the drain line if it is not trapped and will not let the water go out the hose.
Aug 03, 2009 | Coleman Heating & Cooling
Samsung ac model aw25ecb7
hi! bill,
water drip it should be outsidethe house,beside there is a spout on the basin of your ac unit and hose to drip off outside the house,all you gonna do insert a piece of wood or metal on front side of basin, in between basin and the wall,just small piece object to elevate the basin to outside wall,the water will not stored in the basin.or make a spout, drill a hole 1/4" size at the corner at the backside of basin out side your house,be carefull not to drill condenser tube or the fan blade,insert a plastic hose 3/16" and weld it by glue gun.and end of hose put it an empty bottle so that the water drip will not scattered outside your house.regards and don't forget to rate me,thank's a lot
Apr 29, 2009 | Samsung AW0503B Air Conditioner
Our GE TFX22PPDA started oozing a sticky brown substance from the bottom left corner of the freezer door. We defrosted the freezer and cleaned out the drain. Next we checked the drip pan under the frig,...
I have a GE refridg. and a light, brown sticky liquid periodically drips from the water dispencer panel area. This started after we lost power for 5 days. What to do??
Apr 19, 2009 | GE Refrigerators
Hotpoint MAC-130 air conditioner dripping water
You need to blow out the drain line where it hooks up to the pan and clean out the drip pan. It doesn't matter how clean you keep the filter, that's just to keep the evaporator coils clean, which is important in itself. But algae will grow in the drip pan if it is not tilted to drain correctly and will clog up the drain line. If you put a level on the top of the unit, the bubble should JUST BARELY break the line on the OPPOSITE side from the drain outlet on the pan. Hope this helps.
Jan 25, 2008 | Heating & Cooling
Carrier Weathermaker SX
If you are running it in the cooling function, your drain maybe backed up. Find your drain outside if you can and suck it with a shop vac.
Nov 25, 2007 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
