Question about Tablets & eReaders
My ampe a78 will not boot up all i get is the blue start screen
Why is it stuck on the reboot screen?
reset it somewhere to push a few buttons together by reboot or start this will maybe the tablet goes booting in a bios factory mode with Chinese symbols like a Polaroid smartphone.
Mar 06, 2016 | Ematic 7" Touch Screen Tablet
Panasonic toughbook cf-74 blue error screen loop
Which OS do you have? Have you tried booting to safe mode?. Restart the computer. Immediately after the BIOS post ends, start tapping the F8 key repeatedly. when Windows Advanced Options menu appears, select safe mode and see whether it boots completely without blue screen(BSOD)
Apr 22, 2014 | Tablets & eReaders
Proscan tablet won't turn on
Try this. Plug your charger in. Then press the power button repeatedly until the screen comes up with a charge icon showing.
Hold the power button down until the blue screen comes up. Then if it boots up just leave the tablet alone and give it some time. You should see an android come up and then a scan of the android words start . This takes time. Don't be impatient . It may boot into a factory reset mode. Just start again with the factory screen.
You can try repeating the process if it doesn't work the first time.
Mar 22, 2014 | Proscan 10.1-Inch Internet Tablet,...
English manual for a AMPE A78 tablet
Please send for me user manual ampe a78 in English. frahaas@gmail.com
Apr 10, 2013 | Tablets & eReaders
Mid m729b will not shut down
A bit late but FWIW, I had this problem. I eventually just moved any data I needed to a safe place & fully reset it.
To reset, hold the power button & volume up button simultaneously. It should boot to a screen that tells you what to do next. I think they ask you to keep holding the power button for a reset. Do that & you'll see a big old 3D Android figure & a blue progress bar. Give it a minute & it should eventually load. After that I got a screen that said it was "updating" & gave me a percentage countdown. It finally booted like normal to factory settings. All of my data was gone but it now turns on/off like it should.
Jan 30, 2013 | mid Archos M729B Android Tablet
Can't boot
Have you tried changing the boot order in bios? press the F8 key (usually) when you boot up. Set to boot fron CD. Then reinstall operating system
May 29, 2010 | Toshiba Portege M400 PPM40U01000E Tablet...
Blue screen c0o00021a fatal system error, even in safe mode. cant get the DVD drive to open; it clicks when the latch is depressed, but doesn't open (to try to boot from a repair disk). How do I overcome...
Should be a small hole in DVD drive lid.
Turn off computer and carefully insert a straightened paper clip.
Gently push & the lid should pop out
May 03, 2010 | ASUS R1F Tablet PC
Startup problem
If you are getting a Blue screen repeatedly and you can't start up to windows in any custom setting ( from f8 start up menu ) one way to solve the problem is to Use the restore disc or windows installation cd or dvd to install windows into the computer or perform a repair installation if a windows already exists on the computer and the setup can find it.
how to perform a repair installation
this is for xp, but its similar on 2000 and on vista.
insert your Windows XP Setup CD, and restart your computer.
1.When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
if not then the computer is not set to start up from a cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter boot menu or bios, it will very likely be button F12 or similar, it should say on the screen when you power on.
if it doesn't, then you need to go into the bios and change the boot order so that the computer starts from the CD first.
after that you should be able to start from the cd and install the OS (Operating system, eg.Windows)
here's some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
Repeat step 1 when you have changed the boot order.
2.Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.Do not choose the option to press R to use the Recovery Console.
4.In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.Follow the instructions on the screen to complete Setup.
7.Ones windows is working you will need the drivers for your computer, they are at the makers website, for hp and compaq. www.hp.com for acer http://support.acer-euro.com/drivers/downloads.html for all other brands go to google and write Brand drivers. Should get you to the right place. Dell is most likely www.dell.com and so on.
Dec 20, 2008 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Tablets & eReaders Logo
266 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
