Question about Samsung PCJ522R 52" Rear Projection Television
How do I get my HD channels to work?
When changing to an HD channel the screen is vertically scrambled. I can hear the audio and can make out some of the picture. Is there a setting I need to change? The TV in general has a yellow haze. I have attempted the contrast, color, tint , etc...
    Problem Solver:
  • 10 Answers
If the tv is an LCD then you may have power supply issues inside the tv causing all of the trouble.
if it is a projection tv then it sounds like you have multiple problems.
contact a service center for this problem.
Posted on Dec 27, 2007
I HAVE A SUMSUNG THAT IS HD, BUT IT'S NOT HDMI,i GET REGULAR CHANNELS, BUT WHEN I SWITH TO A HD CHANNEL, IT IS ALL SCRAMBLED? WHY?
I assume you have cable. The cable HD and digital channels are usually sent in Quadrature Amplitude Modulation (QAM). The cable companies are required to send local channels in the clear but not so for any others. Regular (basic) channels may be clear or scrambled. USA many not be but HBO will be.
So you have 1 of 2 problems: (1) your TV does not do QAM or (2) they have scrambled the channels you want to see. Questions: (1) Have tried direct Over-the-Air (OTA, ATSC) reception for your locals? (2) Can you see the HD local channels on cable? (3) Are you paying for an HD box from the cable company to have the channels decoded? If in doubt contact the cable company.
Current Samsung TVs do do QAM and OTA HD. Alternatives are Dish or Direct to get satellite with an HD receiver using HDMI or 5-cable RCA. Costs are comparable but OTA wins, hands down. -Ken
Aug 18, 2009 | Samsung Televison & Video
I don't know how a program it, since you change digital.
So far as I know the HLN series does not have an ATSC tuner, thus no over the air (OTA) reception. You can probably still get a $40 coupon for an OTA ATSC to NTSC converter. Note that will NOT get you high definition (HD). With Dish you can get HD receivers that do get OTA ATSC both HD and SD. With Direct, no OTA AFAIK. With cable you would need a QAM tuner, not in your TV AFAIK to get clear channels as required for locals. Otherwise cable needs a Set Top Box for digital and scrambled channels although the standard definition (SD) non-scrambled channels work with your NTSC tuner. Too bad there seem to be no ATSC to 5-cable RCA or HDMI HD converters except Dish. -Ken
Aug 10, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Connecting hd cable box to philips 60 rear projection
So, You have Five cable leads, The rgb get plugged into there corresponding colors and the other two are your Red and White Audio Input ------Correct? You do not use the in4, that is for a pc with horiz and vert sync. You use input 1 rgb and plug the red and white into the audio input.....your done!
Jun 06, 2009 | Philips 60PW9363 60" Rear Projection...
Sony KV-27V22 scrambled picture and loud buzzing audio
the variation from higher channels from lower channels, few things changes eg frequency, voltage, and current.
take your tv to a w/shop and have the following
tunner voltage pulse variation on a avo meter has you change channels. if the difference of voltage is not unform when you are changing from to channel then you should change the control ic on the rf stage or check the capacitors a round the rf ic for variations in value.
Mar 25, 2009 | Sony KV-27V22 TV
Mitsubishi WS-55809 Upconvert Stopped working
your problem is the 2hdw board is located in the signal board.
Feb 02, 2009 | Mitsubishi WS-55809 55" Rear Projection...
I cant get high def 1080-i to work on my mitsubishi 55807
IYou have to have your comcast box tuned to a channel that is broadcast in HD. On your Comcast remote hit menu. This will bring up several icons, one is HD. Select that icon and it will bring up the TV Guide for just HD channels. Select one and tune to that channel. Once your on that channel use your original remote and hit menu, then advance features, then go down to video display and change it from 480 to 980 or 1080. Let me know if this helps.
Dec 15, 2008 | Mitsubishi WS-55807 TV
Scrambled picture
Which caps on which boards as that sounds like a issue with the signal and FMT PCB. The v26 chassis like yours has problems with bad caps on the DM, Signal, FMT and the PWB and terminal
Jun 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
HD Picture is Scrambled, but Has Sound
I had the same problem
you have to set up the componant on DTV.
the signal my be hd 1080i and the only connection with componant that can support this is the DTV port.
the other componant connections only support 480,
good luck
Apr 06, 2008 | Mitsubishi WS-55711 55" Rear Projection...
Mitsubishi WE-52525
. Suspect the FMT PCB part # 930B924002 when set is warm.
Jul 31, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Problem w60 inch using hdtv cable box
i know this problem, happened to me with the comcast Motorola HD receiver box. The key is with the setting in the cable box. Switch on the TV. Set the channel to normal tuner channel 3 or HD input. Turn off the cable HD box. Press the Menu Button on the Cable box or the remote. You should see a Menu. Use the cursor keys to navigate The default setup is also one of the option, Right click on your cursor keys acts like the computer keyboard enter key and applies the change. The default setup is 16:9, the shacking would happen if you have set the picture type to "PAN SCAN". change it to either 16:9 or 4:3 Letter Box. The shacking should stop. Hope it helps.
May 15, 2007 | Philips 60PP9352 60" Rear Projection...
Samsung PCJ522R 52" Rear Projection Television Logo
90 people viewed this question
Jerry Greenberg
Jerry Greenberg
