Question about Compaq Presario Notebook
Water aftertaste bad water
Just bought a Delonghi expresso and when the water passes through the machine it has a bad taste. I have compared normal kettle boiled water and the machine water and it is completely different. I have run 10 or so cycles with just fresh water but the problem persists
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Run vinegar through the system
Posted on Jul 21, 2013
I Descaled expresso maker and 4 reservoirs later, their is still an oily residue on top,of the water coming out. What do I do. I used DeLonghi expresso maker cleaner
white vinegar is a natural de-scaler (and cheaper than those specialist chemical cleaners) Lemon juice is a natural de-greaser, try a diluted solution then rinse it through with water. ;-)
Nov 23, 2017 | DeLonghi Coffee Makers & Espresso Machines
Grinds beans OK and goes through the cycle but no coffee comes out even on expresso and not sounding right. Anyone know why?
If the machine is making a loud rattling noise it may be that the pump is sucking air and not water at start up. Clean out the machine, reassemble, install water tank and tilt the machine over backwards at approx 45Deg, and start the rinse cycle again. This normally clears the air lock. Good Luck.
Sep 16, 2015 | DeLonghi EAM3500 Espresso Machine/Coffee...
My Coffee machine Delonghi doing expresso without foam today. Before doing good expresso with foam. help please.
Espresso should have crema not foam, foam is air added to coffee, like Starbucks does. Issue lays in the grinder and coffee quality. Recommend using Italian espresso bean like Miscela d Oro
Apr 14, 2014 | DeLonghi Coffee Makers & Espresso Machines
Water leaking from underneath my delonghi ec330s
There could be a loose hose, or a hole. Try to call the number the expresso came with.
Feb 08, 2014 | DeLonghi EC330-s Pump Espresso Maker
It's not making expresso.
clogged. Check the water passage and clean out.
Apr 24, 2013 | DeLonghi Caffe Nero BCO264 Espresso &...
How do you descale the machine,as we have no manual
Have you ever wondered, 'how do I descale my expresso machine?' First lets us understand what is exactly is scaling. The build up of minerals inside the hot parts of your coffee machine or espresso machine is commonly called lime scale. When lime scale builds up inside the Espresso machine, it slows down the water flow, reduces the boiler capacity and can prevent your coffee machine from working properly. To keep your Espresso machine operational at full order, it is important to descale it every three months. The time intervals between descaling depend upon many factors. Quality of your water and the amount of water running through the machine are the two main factors that decide the frequency at which you should descale your Espresso machine. The more you your machine, more often should you descale it. In some cities, in conjunction with a water filter you can use your coffee machine for a year or more without descaling at all. If you use less water by drinking espressos you'll need to descale less often than if you make cappuccinos.
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Expresso machine. In case your Espresso machine does not come with a instruction guide or booklet, then use a proper citric acid based descaling solution designed for espresso machines. This should be mixed and prepared as per the instructions on the bottle or packet. Once your Espresso machine has been descaled properly you would not be left wondering, 'how do I descale my expresso machine?', treat yourself to a great cup of coffee. Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
HOPE THIS HELPS. MIKE (MR BEAN MAN) FROM FIXYA
Jun 14, 2011 | DeLonghi Perfecta ESAM5500 Fully Automatic...
How to descale the delonghi icona pump coffee machine?
Jun 12, 2011 | DeLonghi EAM3500 Espresso Machine/Coffee...
Coffee doesn't taste good
even if the machine is new use a decalfier 1 partsolution 1 part water normally when you clean start the machine turn it off for a few minute repeat until emty rinse it very good thatstuff is very corosif try after a good wash and dont forget it like a the pot the older the better hope it work cheers
Jan 17, 2008 | Keurig B50 Coffee Maker
Suddenly coffee tastes TERRIBLE!!!
First try putting a cycle through with no coffee - see if you have any more luck identifying the taste. If you haven't descaled recently, that could be the cause - scale can hold other materials which can be tasted - run a cycle with 50% white vinegar, then rinse through a couple of times and see what you get - if you need to get rid of any vinegar taste, just run a cycle with a couple of teaspoons of bicarbonate of soda through. The water could still be to blame - even purified, there are certain things that can change that most purifying methods will not remove, such as higher salt levels during summer months etc. Make a cup of coffee without the machine at all, and see if you get the same aftertaste. The machine may not be to blame. Hope this helps, please ask again if you need more info :)
Sep 09, 2007 | Cuisinart DGB-600 Coffee Maker
Compaq Presario Notebook Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
