Question about Digihome LCD TV
The volume keeps going off on my tv - Digihome LCD TV
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
This is a problem with the sound select board, and there is no real solution. One thing to try is to press the manual volume up or down buttons on the side of the TV and keep them depressed to see of remote volume control is restored. This over rides the volume creep issue. I solved this by shorting the UP control to ground and the creep went away, but there is no manual volume control any more, but the remote still works.
Jun 23, 2014 | Sanyo Televison & Video
The volume on my plasma tv goes up to 100 and when i lower the volume it will take a second volume for the volume to go up to 100 how can i fix my tv to lower the
The tact switch is most likely defective which is keeping the volume up engaged. Replace the tact switch should fix the issue. If not the button assembly pcb will need replacement. You can get replacement boards from www.tvcircuitboards.com
Dec 10, 2012 | LG 60PC1D 60 in. Plasma Television
Why does my volume keep going down on my sylvania tv
Just check whether the volume down button on the remote or on the TV is jammed. Else, the TV needs attention by a qualified service technician.
Jul 14, 2012 | Sylvania LC320SLX 32 in. LCD TV
Techwood tv volume going back down
I've got this problem these fixing only work for a sort time! Volume just turns itself down?! Anyone no the real fix?
Jul 03, 2012 | Televison & Video
Volume adjusts on it's own on my Bush standard TV Bush LED26916HD 26" HDTV-Ready LCD LED TV FREEVIEW
My bush 50inch .volume kept going up and down.only to discover i had the audio description on.turned it off via the menu options and it was fine then
Jun 22, 2012 | Televison & Video
The volume on our model AT1302 (32") keep going up
Hello
There is some loose soldeings in the audio output section of your Apex TV. It is quite common for this model with this fault. Resolder all the susepected soldering points in the audio output section of your TV, by applying a little more solder to each point, without making any solder bridge short in between adjcecent solder terminals. This will solve the problem of your TV. OK.
Aug 08, 2011 | Apex Digital AT3208S 32" TV
My olevia tv's volume is not working correctly. I
Maybe the remote or the tv manual control board is damage?Check the tv manual vol + - see if function normally.Take the remote aparts and clean it with some Q tips dip in with rubbing alchahol clean the remote PCB.Try website like Remotes.com to buy an exact to the original remote tv.
Jul 15, 2010 | Olevia LT27HVX 27 in. LCD Television
Samsung TV - have sound/auto volume set to on. When TV is turned off and then on, tv volume is extremely low. Go back to sound menu, it shows "on" but if you go back and act like you are turning in on, the...
Hello Blindrid,
What I would suggest you do is Press your MENU button on the tv remote, Then down to SOUND and then Turn the AUTO VOLUME to OFF. Then come out of the menu screen.
Just to check that it has all work correctly. turn you volume upto a certain number for example 25
Then turn your TV off the turn it back on. Wait until it is displaying a picture then press the volume button Once either up or down and you should see that it will go to 24 or 26 depending on what button you pressed for the volume. This will keep your volume set to whatever you had it on before you turned the tv off.
Hope this Helps Please leave a thumbs up.
Cheers
Little Dish Fitter
Oct 06, 2009 | LG 37LG30 37 in. LCD HDTV
Volume keeps going up by itself
help the volume on my tv keeps going up and no one is touching it! please help. my parents cannot afford a new tv
Mar 29, 2006 | Apex Digital PF2025 20" TV
Digihome LCD TV Logo
22 people viewed this question
Top Digihome Televison & Video Experts
john h
David Hoff
Are you a Digihome Televison and Video Expert? Answer questions, earn points and help others
