Question about Garden
Where do i find idel jets in carb on a poulan2150 2.1C.I chainsaw
  • 2,239 Answers
The jets will be under alluminium core plugs, special tools are required to remove them, this should be left to a chainsaw shop as with the wrong tools the carb body can easily be damaged.
Posted on Jul 23, 2013
Chainsaw chain keeps running
This is a carb adjustment issue and needs to be rectified before using it again, the L jet on the carb is set too lean, if you cannot correct yourself i would suggest taking it to the local chainsaw shop.
Jan 19, 2014 | Husky Garden
Stihl chainsaw primer bulb will not fill. Runs but will not idel
The first thing I would check is the gas lines and the primar bulb itself as ethanol in the gas will ruinthe rubber parts in about 6-12 months. If they are still pliable then remove the primar bulb and blow carb cleaner through the passages, you may also have a problem with the low speed jet in the carb causing it to not idle. Good luck
Nov 12, 2013 | Stihl Garden
How do you find and clen the idel jets in carb on a poulan 2150 2.1C.I
Poulan 2150 is a Chainsaw.. not a Lawn mower right?
Jul 21, 2013 | Garden
Backfireing when ideling and when i give it some throttle
CHECK PISTON RINGS FOR WEAR AND I WOULD RE CHECK THAT CARB ADJUST IDLE SPEED JET ETC. WORSE ADJUST VALVES.
Jun 30, 2013 | 2003 Yamaha V Star 1100 Classic
My chainsaw starts and runs fine. After a short time cutting it starves for fuel and cuts out. It will still idle. The carb has been rebuilt and no change.
Take it back to whoever did the carb work. There are two jets on those, an idle jet which can be adjusted for idle speed, and the power jet that kicks in when the saw is under work load. You still have a problem with the power jet, either needs adjusting 1/4 turn at a time until the saw stops killing under load, or the jet and assembly is bad.
Apr 06, 2013 | Makita DCS6401 20 20",64cc Chainsaw 2...
Suzuki 500 quadrunner idels good but will not throttle up just dies
I expect you have blocked jets in the carb.
Strip down the carb and clean the jets then reassemble and tune.
Hope that helps.
Dec 24, 2010 | Suzuki GT 500 Motorcycles
Have stihl ms 210 chainsaw cranks will idle boggs out when you give it gas adjust highspeed then want idle been threw carb twice its clean [ help]
if it is ideling ok I would check the air filter first , try running it without filter in clean air enviroment, Then check the spark plug, clean or replace if necessary, then attempt adjusting carb...
Dec 11, 2009 | RTO Spur Sprocket For Stihl 017, 021...
Carb problem
Sounds like a problem with the main jet. Make sure the carb is cleaned of all the gunk from old fuel. Idle jet ok but if throttle opens too much air will kill engine if the main jet is blocked.
Apr 30, 2009 | 2007 TN'G Baja 150
Snowmobile problem
hi jay,,if u r having to use the choke to keep it go ideling , then either u the idel jet is blocked and will give u fuel starvation ,so usin the choke the main jet has to force fuel in 2 the float chambers,, at the bottom of the carb,, so firstly remove bottoms of carbs and one jet at time take the needle jet and main out , u will see little holes on the needle jet.or needle guide jet if u like, poke a pin in the holes ,and blow threw till u see light threw them, give every thing in the bottom carb a clean while u r there, then replace that jet and everything else ,,then move to the next carb and repeat the process,,put carbs back on the bike, then air boxmake sure theres no air leaks between air box and carbs ,, try that matey,, hope it helped,,
Jan 09, 2009 | 2000 Yamaha YZF-R1
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
