Question about Garden
How do u clean the idel jets on a poulan 2150 2.1C.I chaindsaw
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
No idle jets. this is a diaphragm carburetor
Posted on Jul 24, 2013
Poulan 222 38cc choke problem; choke has to be kept out for it to continue running. Carbeurator has been cleaned.
Sounds like this saw has had gasoline with alcohol in it and the idle jet is plugged up. Have to take it apart and use a small wire to open the jet. Just cleaning the carb will not solve this problem. With the idle jet plugged adjusting the idle screw will accomplish nothing. Then us gasoline with no alcohol in it from then on. Search with google to find a station that sells non alcohol gasoline in your area.
Feb 10, 2015 | Poulan Garden
Carb not working properley
sounds like you didn't get the pilot jet /air screw / idle circuit clean.
the symptoms sound like the pilot jet needs cleaning.. the jet has a VERY tiny hole that's easily blocked or dirty
Mar 12, 2014 | RTO Quads 125cc Full Size Adult 4 Wheelers...
How do you find and clen the idel jets in carb on a poulan 2150 2.1C.I
Poulan 2150 is a Chainsaw.. not a Lawn mower right?
Jul 21, 2013 | Garden
I need to know how to set hight and low on the carborator
Make sure choke is fully open, then run engine at full speed adjust high jet with a screwdriver - what you do is turn jet one way until revs drop of and then the other way until revs drop off - what you want is the middle point between this happening. Do the same for low jet except run engine at idel speed.
Feb 05, 2013 | Poulan Garden
Mine was running fine , set it down to take a break. Restarted just fine, and idels great , but as soon as the throttle is applied it dies..help.....
Check there are no kinks in fuel line.
Make sure that the air filter isn't blocked.
Check the throttle cable is operating the throttle plate in the carburettor ok.
Ensure chain isn't too tight.
The carburettor should be a tight fit on the air inlet manifold.
It's possible that some of the jets could be blocked in the carburettor. You can try and clean these with compressed air but ensure you remove any seals gaskets, springs on the diaphragm pump , primer bulb etc as they can be damaged by the pressure.
Apr 06, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Suzuki 500 quadrunner idels good but will not throttle up just dies
I expect you have blocked jets in the carb.
Strip down the carb and clean the jets then reassemble and tune.
Hope that helps.
Dec 24, 2010 | Suzuki GT 500 Motorcycles
Poulan 33cc Weedeater 3 mo old will not idle, dies during acceleration
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me
Aug 23, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
POULAN FEATHERLITE LEAF BLOWER WILL ONLY RUN AT 1/2 CHOKE
Sounds like you will need to clean your carburetor, or rebuild it. Could be some debris in the jets of the carburetor. If the blower is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit, because the diaphragm will get hard and that will cause it to be hard to crank and not run at full speed. Hint: When you clean your carburetor and remove the jet screws, count the number of turns it takes to seat the jets from their original position. That way when you go to put the jets back in, you know how many turns they were in/out. Please rate me, Thanks Good Luck, I hope this helped
Jan 05, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Idels good but when i start to cut it bogs doun
Either the spark arresting screen is clogged with carbon, or the carb is out of adjustment on the high speed jet.
Mar 31, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
