York air conditioner manual
Need to know how to wire in a new capacitor, and quick start unit. Have disconnected wires and need to kmnow where they go back onto clips Model ACO24M1O2ICG. Thanks
  • 4 Answers
Can you post a pic of the unit s electrical opened up here and I amy be able to step you through it
Posted on Jul 21, 2013
bobotfel
  • 236 Answers
SOURCE: reinstall capacitor 370 vac from a/c
Here is the standard connection of dual capacitor. Actually you can see the diagram on the unit but Im not familiar with the Intertherm model. What can I give to you is only the standard connection of dual capacitor.
Posted on Feb 26, 2008
SOURCE: Danby air conditioner model #DPAC10060(R)
here is the manual link: http://www.danby.ca/manuals/DPAC8020.pdf
Posted on Jun 15, 2007
  • 659 Answers
SOURCE: New motor runs but doesn't blow air through the registers
Is the blower wheel turning? Did you by chance have to remove the motor from the blower wheel to work on it? If you did, did you put the blower wheel back on in the correct direction of air flow? Also, did you put the correct capacitor back on the unit so it can get up to the required rpm's? These are things that you will need to check for. If the motor is running and the blower wheel isn't and the wheel is tight on the shaft, then you will have to replace the motor. The brushes may be bad on the unit and it's not turning the shaft. Hope these ideas help.
Posted on Apr 10, 2009
bobicehouse
  • 1524 Answers
SOURCE: rewire air conditioner controls
Assuming "Window Unit" with rotary switch.
L1 (smooth part of line cord) to thermostat 1, thermostat 2 to overload (black disk) from overload to Common( C) terminal on compressor.
From Run (R) terminal on Compressor to Common (C) terminal on dual capacitor. From Start (S) terminal on Compressor to "Herm" terminal on capacitor. From fan motor to # 4 on switch = Medium Speed, to # 6 on switch = High Speed, from fan motor to # 7 on switch - Low Speed. Brown wire from fan motor to (F) on dual capacitor, white wire from fan to (C) on capacitor and L2 (ribbedwire) (N) to (C) on capacitor
Posted on May 10, 2009
SOURCE: wiring diagram for portable air conditioner
I think the wiring diagram is on a printed sticker on the side of the water collector, just pull it out of the right side as you look at it. There should be one on there hope this helps as i have the same unit in the other room. regards Richard
Posted on May 29, 2009
Compressor will not start up during new gooman packaged 3.5 ton heat pump a/c unit installation
New unit and it will not start typically a miswired unit. which happened at the factory. If you turn off the power you can Trace the wire from the compressor and make sure there are no disconnected wires. You need to know how to read a wiring diagram and a meter to effectively troubleshoot you loss of voltage or if the compressor is operable.
Oct 04, 2012 | Goodman GPC1342H21A Air Conditioner
Need to change a broken blower motor in RUUD central air unit. Old central air blower motor (GE electric) was connected with brown and orange wire to 15 MHD capacitor. Another orange wire from central air...
on the motor should be a diagram detailing the wires. brown white goes to either side of the capacitor and brown wire to other side of capacitor. hi speed goes to normally open contact on the indoor fan relay and the wire designated common on the motor goes to the other side of power from the relay contacts.
Oct 03, 2012 | Heating & Cooling
Our air conditioner stopped cooling last night. The fan runs. My husband pushed the reset button on the outside unit but didn't know if he is supposed to keep it pushed in or just push it in quickly or...
If it is a split unit this is a unit with a furnace and air handler inside with the condensing unit outside. If your inside fan is running ck your outside fan and seeif it is running. If it is it is probably the wires to the capacitor or the capacitor its self. Some capacitors have 3 wires this is a dual capacitor with a 5uf for the outside fan and a 35up for the compressor. on some there are two seperate capacitors one 5 one 35 uf. also it could be the wirng to the capacitor they will be melted and chared. all of this is located in the outside unit where the elect wires go into the unit you can removethe shell but first disconect the power there should be a disconnect switch near the unit. if not trip the breaker. be carefull with the elect.
Aug 08, 2010 | Ruud UBHC Air Conditioner
Air Conditioner comes on but outside fan wont start unless I manually start it....how do i replace capacitor and how would I know if it is a capacitor issue? Please Help
First mark the wires and make a diagram so you can reconnect it. Next remove the capacitor. You can take it to a heating and air supply and they will test it for you. They will also sell you a new one. Use your wiring diagram to reinstall the capacitor wires. It sounds like your problem is the capacitor.
Aug 02, 2010 | Heating & Cooling
My rooftop coleman AC main wires are burnt
Either the power supply wiring is too long - i.e. a 150 foot extension cord used to power it with poor plug blades?
Or the capacitor is shot, (more likely)
Disconnect Power supply, wait 5 minutes, try to start the unit WITH POWER DISCONNECTED. (will drain capacitor). Short capacitor with well insulated screwdriver, get the new capacitor replaced on ebay or local electrical supply or appliance store (not home depot)
Aug 30, 2009 | Coleman Mach III Air Conditioner
Wiring Question York Diamond 90 Condensor Unit - New Capacitor
the wire diagram should tell you how. it all depends where wires lead to. be very carefull, capacitors can be dangerous. brown usaully go to fan black usaully goes to common red usaully goes to herm or compressor. it all depends where wires come from
Aug 27, 2009 | Heating & Cooling
Schematic missing - need to know which cond unit
Black wire goes to contactor. On your capacitor the brown wire goes on one side the blue and the other wire from your contactor goes on the other sideof the capacitor. Russ
Aug 07, 2009 | Heating & Cooling
REPPLACING FAN AND COMPRESSOR CAPACITORS WITH A SINGLE UNIT
Well, it sounds as if you have a Coleman rooftop unit. If you have a start capacitor with a PTCR (Postive Temperature Coefficient Resistor) then it is different than if you have a Potential Motor Starting Relay. Why are you replacing the run and the fan capacitor?
Here is a link to the documentation that you need. If you do not have a Coleman and it is in fact a Duo-Therm, let me know the model number and I will be able to pull up the wiring schematic.
Thanks,
Jeff
Rate this please!!
Jun 26, 2009 | Dometic Rooftop RV Air Conditioner
Rewire air conditioner controls
May 10, 2009 | Heating & Cooling
Heating & Cooling Logo
94 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
