Braemar heater airflow fault light
    Sergeant:
  • 352 Answers
IS AIR INTAKE BLOCKED BY WALLS, FURNITURE, OR DUST AND DEBRIS?
Posted on Jul 21, 2013
Braemar spectrolink reset error 05
I had the fault code 05 (spectrolink controller) recently on a Braemer TG420 ducted heater. The heater would start and cut out on high temp as the room fan was not starting. I checked under the house and found the cable fitted to the return air thermistor had been chewed. I repaired the section of cabling and restarted the unit and it worked fine. Fault Code 05 is to do with the Thermistor in the return air duct.
Mar 27, 2012 | Heating & Cooling
I have a Braemar Spectrolink Controller, which has suddenly lost all power and the display is completely blank. I have removed the controller thinking that there would be batteries, but where the batteries...
it gets its power from the unit via the data cable. go on the seely international website or the braemar website and they can put you in contact with another dealer in your area. get it fixed while still in warrenty.
Feb 19, 2011 | Honeywell Programmable Thermostat Heater
My heater won't stay on! Thefire blows then shuts off
safety protocalls prohibit your unit from running unsafely, sounds as if a safty switch is terminating operation, try a clean filter first to insure good airflow, next check your fault light and count flashers to determine the fault, thank you and good luck
Feb 03, 2011 | Heating & Cooling
Braemar spectrolink comfort controller keeps on asking to be reset works ok for a while then goes to reset
Look for the error code on the right hand side of the display above the zone section and below the actual temp displayed.... refer to:
http://www.braemar.com.au/PDFDocuments/Section8_ServiceTroubleshoot.pdf
Jul 21, 2010 | Honeywell Programmable Thermostat Heater
We have a braemar chronotherm IV plus It turns the heating on and off after aproximatly 5 minutes we have replaced the fan and had a plumber here several times each time he replaces a part now he is...
What type of heat, electric, gas or heat pump, did anyone replace the thermostat recently? Did he replace the capacitor when he replaced the motor?
It sounds like either an airflow problem or a fan or limit switch, possibly the thermostat.
Aug 18, 2009 | Honeywell Programmable Thermostat Heater
Braemar ducted heating wont switch on
If a used unit check under lid for a pressure hose no thicker than a pen , black or clear, look for splits or if disconnected reconnect
Jul 12, 2009 | Heating & Cooling
Heating & Cooling Logo
81 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
