My Iphone is black colour....can i change red colour?
Change Photos from Black and White to Coloured
Unless you want to colorize them by hand, there's no way to add color to black and white photos. Given a black and white photo showing a person in a gray dress, how do you know whether the dress was blue or red or some other color?
Dec 18, 2012 | Fujifilm Finepix S4200 Digital Camera
I have a 2002 Suzuki Swift 1.3 and I need the colour coding for the car stereo. This is how it looks like looking from the back of the connector. The top colour is the main colour and the bottom is the...
why post non usa cars to USA forum>????
hint, we dont have M13 here. (EPA ******* here)
then not telliny your county.
why"?
my guess is you think all cars same, all suzuki same world wide and all suzuki have 1 radio.
sorry that don't fly.
but most posts here are just like this, hopeless.
wild guess 1:
here is our last swift, sold USA.,(not a m13 for sure)
wires
MAin set; and speakers last.
wht/blk, = ign. on. power 12v
white = memory , hot all time to battery via fuse, station memory
black = ground
red-green = illumination
red-yell = park lamps on, lighting,.
and below is speaker.
this is year 2000 last car sold here,
Mar 13, 2017 | 2001 Suzuki Swift
Screen stay in white colour
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Jan 02, 2011 | Apple iPhone Smartphone
What does it mean when it says change k cartridge
There should be four ink cartridges inside the printer: Cyan, Magenta, Yellow and blacK.
While monitors build colours out of three emissive (active) base colours, red, green and blue, printers usually build them out of four absorbing (passive) inks, so-called CMYK. The black is referred to by its last letter to avoid confusion with Blue.
On most printers, since they usually print in black ink over white paper (and black is used to darken all other colours), the K cartridge is either bigger than the others, or needs to be replaced more often.
Mar 31, 2010 | Canon imageCLASS MF8180C All-In-One Laser...
How do i change the colour cartridge for a epson style c42+ printer - if i press the red LED button for 6 secs only the black cartridge comes into the open.! how do i get the colour cartridge into view ?
after the black cartridge moves to the ink changing position, push the 'ink' button one more time to move the carriage to the position to replace the colour cartridge. in some cases this will only work when the printer indicates that the color cartridge is empty.
Oct 12, 2009 | Epson Stylus C42+ InkJet Printer
I need to know what colour wires are for which speaker, etc. I am changing radio but have no manual or wiring schematic
Left Front (+) Blue/Black
Left Front (-) Orange/Black
Right Front (+) Red/White
Right Front (-) Orange/White
Left Rear (+) Red/Light Green
Left Rear (-) Orange/Black
Right Rear (+) Blue/Light Green
Right Rear (-) Orange/Red
More info below
http://www.nexxia.co.uk/More_Information/ISO_wiring.htm
Aug 04, 2009 | Car Audio & Video
I just fix in new black and coloured cartridges and only black and red colours appear on my prints. the replaced coloured cartridge was giving similar print problems.
hi im josh in cebu phils. friend may i help you? it happen try to shake the cartridge that doesn't print.and install it again and just remember this: Problem: Your Color Printer Doesn't Print All Available Colors This problem is most likely caused by an old ink cartridge. It's not unusual for some colors to get depleted before others, throwing off your color output. If you're seeing less blue (or red or yellow or black) than normal, chances are it's time to change your cartridge. so thats all good luck
Mar 06, 2009 | HP DeskJet 1280 InkJet Printer
Washed out colours and thin red lines across the screen
your problem is in red video circuit. please get it done with skilled tech.
Oct 05, 2007 | Panasonic CT-32SL15 32" TV
Picture problems
CRT green gun is not working properly , maybe dry soldered or no green drive signal. Pink and red colour is due to missing of green colour.
Sep 09, 2007 | Sanyo DS27820 27" TV
11 people viewed this question
k24674
