Question about Fisher and Paykel Fisher & Paykel Washer
Smartdrive wont spin on last spin even with nothing in it as if out of balancemodel smartdrive 7.5
On last spin even with nothing in it as if out of balance
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 66 Answers
Posted on Nov 09, 2015
  • 72 Answers
Change the board
Posted on Nov 06, 2013
  • paulus649 Nov 06, 2013
    change the board
My fisher and paykel eco washer spins weirdly and makes lots of noises
Noisy
If the user is complaining about noise, it may be in a number of different areas. Is the noise during
spin? Is it a banging sound? This would typically be the drain hose, inlet hoses, mains lead or
harness. If it is an out of balance noise, check that the machine is level and stable. Check the
bias spring and balance rings. Remove the inner bowl and check that its weight is within
specification (Refer Section 1.12).
If it is a 'clunk' that occurs up to 3 times per cycle, this would be a bowl check and is completely
normal. It occurs when SmartDrive is draining and 3/4 empty. This is a 'feature' and a noise that
cannot be reduced.
Other things to check are:
• Is SmartDrive level and on all four feet equally.
• Check the mains lead, inlet hoses and drain hose outside the wrapper, behind SmartDrive.
• Check the harness and drain hose inside is not banging on the wrapper during spin.
• Check the bias spring is fitted correctly.
• Check the 2 balance rings in the inner bowl contain water. Check the bowl weight.
• Check for noisy suspension rods.
Apr 04, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paaykel Smart Drive 708 not working once filled with water.
You need to check your lid switch & out of balance switch for
corrosion and replace if faulty.
Your out of balance switch is under the big yellow motor controller
OOB switch Is where the grey plate is on this picture.
Mar 03, 2013 | Fisher and Paykel Washing Machines
F&P smartdrive wont spin..
What lights are lit on the display? There should be 8 lights on the display.
Dec 03, 2012 | Fisher and Paykel Washing Machines
Ninja blender blade wont turn with food in container.
make sure blade is pressed tightly onto shaft... should click into indent. if not then you need a new blade piece.- stripped
Aug 18, 2012 | Blenders
My f&p smartdrive washing machine does every cycle except the last spin cycle. it drains the water out but doesnt spin the clothes
Hi just read your posting.Could you please supply the model number of your machine for me.The model number is located on a sticker at the back of the machine top left.Does your machine stop and beep and show an error code?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Sep 26, 2010 | Washing Machines
Fisher and Paykel Washing Machine "Pride 5.5" Smartdrive 8 Model MW058U. Washing tub thrashes around violently when wash cycle starts any spinning - even during rinse cycle. Load looks even around...
Hi just found your posting.Do you still require help?The problem with your machine sounds like your suspension rods are faulty.Please reply and I can help you rectify this fault.Looking forward to your reply.
Jul 14, 2010 | Fisher and Paykel Washing Machines
Fand P smartdrive 9 fault codes
Does the machine start when you press start?
Have a look at this page for more info (I hope it helps you?)
http://www.fisherpaykel.com.au/admin/pdfs/pdf_usecares/529589BDD605userguideNZAUw.pdf
Jun 17, 2009 | Fisher Washing Machines
Fisher and Paykel Smart Drive 608 wont spin
remove the pump from underneath front right move whith clip forward the twist pump out.but you will need to remove all the water first you may a ball of lint stuck in the pump.hope this helps.
Mar 29, 2008 | Washing Machines
Washing Machines Logo
562 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
