Gorenje f07 fault - Washing Machines
3 Suggested Answers
SOURCE: gorenje WA72145BK fault 6 displayed on my LED
I have the same problem. Any solution? Thanks!!
Posted on Jan 09, 2010
pjhislay1
  • 822 Answers
SOURCE: aqualtis fault code f07
Heater relay stuck
  • Check wiring
  • Check electronic control PCB
Posted on Jul 02, 2014
Hot point ariston aqualtis condenser dryer fault code f07
F07
Heater relay stuck
Check wiring
Jun 21, 2014 | Hoover Dryers
Aqualtis fault code f07
Heater relay stuck
  • Check wiring
Jun 21, 2014 | Hoover Washing Machines
Free whirlpool repair manual
Hello, Without a model number, I can be of limited help. But the F07 fault on a whirlpool dishwasher is indicating a problem with the water intake flow meter. Check the connections at the meter, if good replace the flow meter.
Unplug the appliance.
Take it out of it's installed location
Remove the left side panel .
In the large plastic tank on the left side of the machine is the flow meter. It will have a 2 wire plug on it.
Pull the plug off and push it on again a couple times.
Make sure the connection is dry and tight.
Try the dishwasher.
If you receive the F07 fault again, replace the flow meter.
Apr 21, 2014 | Dishwashers
Fault code f07
The type of dryer would help a lot.... If it is a Maytag you can try resetting the code...
To reset the error code you need to turn the dial to the 6 oclock position.
Press the start button 3 times
Turn the dial 1 position clockwise
Press start button again 3 times
Then turn to off and this should clear the error code.if you still get the F07 error code then the control board may be the problem
If it is a Hot point You have a lower element failure..
Dec 31, 2013 | Dryers
Error code f 07 mid cycle?!?
You do not state your machine or model. The error code F07 that I have states that the Central Control Unit has detected a short in the Motor Control Unit.
Check the wire harness between the Drive Motor and the MCU and between the MCU and the CCU.
Check the MCU.
Check the Drive Motor.
Check the entire wire harness.
Replace any defective parts.
Apr 26, 2011 | Washing Machines
Can not find model no.of the oven. Fault F07 on
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 09, 2011 | Whirlpool RBS307PVS Stainless Steel...
Gorenje WA72145BK fault 6 displayed on my LED
Dec 12, 2009 | Washing Machines
F07 occurs at end of first rinse cycle
F07 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit. Check wire harness connections between drive motor and Motor Control Unit (MCU), and between MCU and the Central Control Unit (CCU). Reconnect power and plug unit in.
Check the MCU by looking for operations of the drive motor, and check drive motor for powered rotations. Replace failed component.
Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 26, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
