I TOOK THE TOP OFF MY PDPRO4E MEDIA RECIEVER TO CLEAN THE FAN.NOW IT WONT COME OFF STANDBY?
Bought new remote& reciever,how to install it
What model of fan do you have? It's a 5 digit number starting with a 2.
Jul 23, 2013 | Hunter Ceiling Fan Remote Receiver...
Reciever keeps shutting off!
If your reciever is in a tight enclosed space, than it will overheat and shut down to protect itself. Try to get some ventilation to it by either opening the cabinet door, adding a fan, or pulling it completely out of the enclosed space.
Jan 05, 2011 | Pioneer VSX-33TX Receiver
Plasma tv stopped working
hi i have a pioneer plasma tv pdpro4e all it doses is flash green red green red and on the mediar reciver as well tv dont come on help please
Dec 31, 2009 | Televison & Video
Mobo wont power up
yes u can, test it with another PSU...good luck.
May 25, 2009 | Gateway Media Center Desktop PC
Reciever wont stay powered on
I fear that there's no easy fix. Sounds like the power supply or the board which controls it is bad. If you're not an electronics repair person, it'll need to go to a repair shop.
May 02, 2009 | Audio Players & Recorders
Pioneer media receiver won t turn on
If the light on the media reciever doesn't come on then the power supply in that needs to be replaced by a service tech. If you disconnect the 2 cables from the media reciever and the panel and then try to turn on the panel it should light with red and green squares for a few seconds but will turn off as it needs the media reciever to be connected.
Mar 29, 2009 | Pioneer PureVision PDP-4340HD 43 in....
Sony kv32ls36b stuck on standby red green light flashing
If the light flashes 4x or so at a time, I had the same issue. I took the back off the TV checked all the fans.. found the fan that had stopped and blew the back with compressed air, once the fan was clean- the TV started to work again. Hope this helps!
Jul 07, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Wont start up
my wife has a presario that had a similar problem - it would boot up, then immediately shut down. I took off the side plate and blew off some of the dust inside. that worked for a couple of days then the symptoms returned. I took it apart again but this time I removed the cpu fan and the cpu heat sink. I cleaned all the **** off the fan and the heat sink and replaced it. this time it stayed on. I checked out the power supply. compaq installed a very cheap power supply - only 250 watts. a replacement power supply for the same machine but with an output of 300 watts is available. as soon as I can scrape up the change, I'm gonna change the PS
Jun 11, 2008 | Compaq Presario 5000 PC Desktop
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
