Question about Russell Hobbs 9209 Classic 4-Slice Toaster
Parts Bread holder not staying down. Why?
Russell Hobbs 18140 Toaster The bread carrier will not stay down during toasting. Insert two slices of bread into bread carrier and push down to lock. The right hand side carrier does not stay down. The...
Constant use can lead to crumbs clogging the path of the lever. Try opening up the bottom panel, by pulling on the metal tab to release the plate (and crumbs!) over a trash can. Also try flipping the toaster upside down and, very gently, shaking the crumbs out. if that doesn't work, you can try checking the toaster's browning dial. This might be too low to activate the heating coil. Try dialing it up, and pushing the lever down again. I hope this helps. You can check our post on Best ways to use a Toaster oven. Best ways to use toaster oven 2017 ultimate guide Kitchenutilitypro
Sep 28, 2017 | Kitchen Appliances - Others
Right side lights on all buttons won't stop flashing and bread 'holder' stays closed
Hi! Try to unplug it from the electrical grid and to clean it inside the place where the bread goes, maybe there's a piece of bread stuck in there. I hope this will work! Have a nice day!
Sep 02, 2011 | Breville BTA840XL 4-Slice Toaster
Blade holder attachment
IF YOU MEAN THE BREAD KNEADER IN THE BOTTOM OF YOUR BREAD TIN YOU CAN BUY THIS FROM AMZON FOR £6.05 ALL PARTS CAN BE FOUND THERE GOOD LUCK
Jan 12, 2011 | Kitchen Appliances - Others
Bread will not stay down; element does not get hot (Kenmore toaster- 10 -12 years old). I don't know if there is spring that needs to be replaced or if the element itself is gone. How would I test for this...
Hi and welcome to Fixya. There is a simple test you can do with an ohm meter across the heating element connections.
The unit must be unplugged and your going to have to remove the cover.
Check for any signs of low resistance across the element connections. No resistance or infinity and the element is history.
Any sliced bread toaster with a failed heating element will have the symptoms you described. However, it could also be the mating contact has failed which is closed when the bread holder is in the down postion.
My experience... 10 - 12 year old toasters are not worth repairing unless it is a commercial type unit. By the time you order the needed parts and pay the shipping you far exceed unit replacement costs. Repair costs rise even more if you ship it or hand carry it to a repair service center.
Jan 26, 2010 | Microwave Ovens
Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Aug 04, 2009 | Kitchen Appliances - Others
Be sure the temp/time dial is not on zero.
Mar 11, 2009 | Russell Hobbs 9376 Classic 2-Slice Toaster
WELBILT bread maker model ABM550
Yes, there is a recipe book. It's called Easy Baking by Tom Lacalamita. But you can use other recipe books, too. The only thing you need to know is that for this machine, is the yeast goes in first and the liquid goes in last. If there is a specific recipe you are still looking for, I can try to share it.
Apr 28, 2008 | Welbilt ABM3500 Bread Maker
Russell Hobbs 9209 Classic 4-Slice Toaster Logo
29 people viewed this question
Top Russell Hobbs Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
ashburton
Are you a Russell Hobbs Kitchen Appliances - Other Expert? Answer questions, earn points and help others
