Question about Kodak HERO 7.1 PRINTER
How do I print on A5 card please on my Kodak Hero 7.1
I have tried putting A5 card in bottom feed tray further down the tray. I then need to print double sided
4 Suggested Answers
SOURCE: kodak 5300 wont print on glossy side of photo paper
I just sussed this issue out. On the front of the printer tray there is another pull out tray, this opens up and must activate the photo printing for A4 because it stops the paper falling on the floor once printed (cos once printed on photo paper it may still be wet). As soon as I opened the tray (and it then opens again - you'll see what I mean) it printed A4 photo paper perfectly
Hope this helps others
Posted on Oct 10, 2008
  • 60 Answers
SOURCE: Kodak 5300 printer 4x6 printer tray
it could be a problem with printer and least with the print head.......i would advice to contact Kodak tech support...........
Posted on Jul 16, 2009
FixinFax
  • 3085 Answers
SOURCE: Printing Issue
It has dust or built-up goo on the feed switch. Try some canned air
Posted on Jun 11, 2010
Printing 5x7 card stock in HP 1510 injet all-in-one printer
You need to set up your printer preferences to accommodate the type and size of paper you wish to use, usually listed under printer/print or page set up.
Invariably, paper is loaded, butted to either left or right of the paper feed, but on the other side of the feed there should be a sliding stop which keeps your paper in place.
If feeding from the top feed, print side towards you, if printing from a tray at the bottom of the printer, print face down.
You can download a user manual from here once you've chosen your model printer:-
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=uk&cc=uk&h_page=hpcom&lang=en&h_client=S-A-R135-1&h_query=+HP+PSC+1510&submit.x=11&submit.y=7
Apr 22, 2010 | HP PSC 1510 All-In-One InkJet Printer
HP Photosmart C6100 All-in-One
Just click below;
Set Up the Printer Hardware
Remove packing materials, check contents of the box, connect the power cord, set the menus, load paper, and install the print cartridges. s.gif » Product Specifications
Minimum system requirements, connectivity, print cartridges, specifications for print, copy, paper, print margins, paper tray capacity, memory card, scan, physical size, power, and ... s.gif » Printing Instructions for 4 x 12 and 5 x 7 Inch Paper
Generic printing instructions. s.gif » Creating Borderless Photo Prints with the HP All-in-One Software
... 4 by 6-inch photo paper with tab (snapshot paper) ... Remove the paper from the paper tray and load the snapshot paper. Insert tabbed paper with the perforated, tear-off ... Click Photo Prints . The HP Photo Prints window will appear. ..
hope this may help;
Regards,
VOTIT
Jul 31, 2008 | HP Photosmart C6100 All-In-One Printer
I cant find my manual how to i place the paper underneath so it feeds through the bottom
You can use the paper cassette located at the bottom of the printer, on the front when the output paper tray is closed concealing the paper feed switch, the usb port and the cassette lamp.
1 Gently pull out the cassette from the printer.
2. Remove the cover from the cassette.
3. Place your paper in the cassette tray.
a. when using A5 or larger sized paper (non standard sized paper, pinch the tab and extend the cassette if needed.
b. legal sized paper is not loadable in the cassette
4. Do not load paper above the load limit mar4k.
5. Make sure the print side of the paper is facing down.
6. Align the paper stack against the right side of the cassette
7. Slide the paper guides so they fit the loaded paper stack.
8. The paper cassette will hold up to 150 sheets of plain paper, however you do not eant to stack any more than 50 sheets in the Paper Output Tray.
9. Reinsert the cassette into the printer. Then set the cover on the cassette. Now make sure the cassette is pushed al the way into the printer. (If long paper was used and the cassette was extended iy will now extend beyond the front of the printer
10. Prepare the paper output tray by opening the front cover and pulling out the tray extension until extended completely.
11. Press the paper feed switch so the cassette lamp lights.
You can slo select the paper source with the printer driver if you prefer .
Mar 07, 2010 | Canon Office Equipment & Supplies
Paper size mismatch for A9 envelope (5.75x8.75)
Set the envelope size in the printer properties paper size list to A5 (5.83 x 8.27) which is only .08 inches wider than the short side of an A9 envelope (5.75 inches). The paper size sensor on the HP6520 printer must not be sensitive enough to tell the difference. I can print A9 envelopes just fine using the A5 setting.
Jan 20, 2010 | HP Photosmart C4580 All-in-One - InkJet...
Trouble printing envelopes on kodak esp3 printer
Have you tried this procedure?
Loading Envelopes
You can load plain envelopes into the paper tray of your Kodak ESP 3 All-in-One printer.
Important Do not use envelopes with cutouts or cellophane windows.
1 Remove any other paper from the paper tray.
2 Insert one or more envelopes into the right side of the paper tray with the print side down and
the envelope flaps on the right, pointing left.
3 Squeeze the paper-width guide and move it to its right-most position up against the envelopes.
4 Leave the paper tray open while the envelopes are loaded.
If you have and it's not printing correctly, there is probably a problem with the document you're trying to print.
Jan 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Loading A5 paper into photosmart 8450
your printer is capable of accepting a5, load the paper on a different direction, with the leading edge 5.83" feed first, then properly aligned the side guides to match your paper this will surely work this time, then slect a5 on your printing properties on your pc
cheers
Sep 27, 2008 | HP Photosmart 8450 InkJet Printer
Kodak PD6000 Printer Dock will not lift and feed paper from paper tray
Greetings,
Here's the link for your products Troubleshooting Guide
Keep us posted and thank you for using our service.
FixYa - Technical Support, Instructions & Repair Service
Jul 30, 2008 | Office Equipment & Supplies
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printer
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
3.
4.
5.
6.
7.
Jun 03, 2008 | Office Equipment & Supplies
Not accepting paper
Check the paper feed path for obstructions like objects that may have fallen in. Tip the machine onto its back then almost upside down and give it a bash a few times to try and dislodge anything that has fallen in.
You can try sticking the vacuum hose in to the feed tray to **** out a foreign object and the last try is to feed an A5 piece of thick card (like off the back of a shorthand pad) through the feed path the wrong way. Start at the exit rollers and feed the card back through the mechanism. Take care to keep about an inch away from the right hand side as there is a sensor flag in that corner and you don't want to snap it off.
If nothing comes out, get a service manual from this guy and remove the ASF to get better access to see what is in the way. You can then also remove and clean the pick up roller before re-assembling.
Mar 15, 2008 | Epson Stylus 680 InkJet Color Printer
Kodak HERO 7.1 PRINTER Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
