Question about ASUS N76VZ-DS71 17.3" Notebook
Unlock scroll lock laptop
I'm writing this to ask for help to unlock the scroll lock on mousepad though I tried fn+scr lk waiting for your advice
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 58 Answers
Go to All Control Panel Items, - Ease of Access Center - and Start On Screen Keyboard. Now you can click on the Scrollock key.
Posted on Nov 12, 2013
Where is the scroll lock/unlock button?
Look for a key that has Scr Lk at your keyboard
Sep 28, 2013 | Gateway NE56R13u Laptop
Keyboard default setting
This may be due to a numlock setting. Try holding down the Function key,it should be on the bottom left corner of your keyboard as "Fn", and press either Num Lock or Scr Lk.
The Num Lock and Scr Lk keys should be on the upper right hand side of the keyboard.
Feb 12, 2013 | Acer Aspire 7551-7422-22085
Number pad does not work
  1. Find Alt code.
    Numeric Alt codes for symbols are listed in Alt codes list. Check for Alt code of symbol you want to input.
  2. Enable Num Lk.
    You may need to simultaneously press ["FN" and "Scr Lk"] keys. That's the combination for "Num Lock" on some laptops. Look at the picture - the "Num Lk"/"Scr Lk" button is highlighted there.
  3. Hold down "Alt" key.
    Some laptops require you to hold both "Alt" and "FN" keys.
  4. Input Alt code of symbol on Keypad.
    Do this while holding "Alt" button pressed. Type Alt code on your laptop's numeric keypad. It's highlighted on the picture.
  5. Release all the keys.
    After you release all the keys alt symbol should be entered. If all this stuff didn't work - check if you have really enabled the "Num Lock" first. Remember that green indicator should shine near the lock symbol on your laptop's keyboard. If that wasn't the case - try simultaneously holding "FN" and "Alt" keys instead of just "Alt". That just might work.
Feb 15, 2012 | Toshiba Satellite P105-S9722 Notebook
For some reason the number lock is on my keyboard - i can*t figure out howto unlock it. i have to keep the fn key down in order to type the letters on the right hand side. how do i unlock/ thanks in...
Please follow the below instruction to fix your problem.
Press 2 keys at the same time: "FN" (next to the CTRL key, lower-left of the keyboard) and "num lk", which is the upper-right of the keyboard (it is on the same key as "scroll", and is next to "F12"). This will either turn on or turn off the "Num Lock" function. Both the "FN" and "num lk" are enclosed in a small rectangle. They are easy to see.
Hope the above information will be helpful to you. Thank you. Have a good day.
Aug 11, 2011 | Fujitsu Computers & Internet
Hi I have just bought an Acer Aspire Z5710 all-in-one PC. I find the screen too bright when working for long, and want to adjust the brightness. But i am not able to figure out how to do so. And there...
http://support.acer.com/acerpanam/Manuals/acer/2011/ServiceGuides/SG_Aspire_Z5700_Z5710_20100907.pdf
If the keyboard doesn't have a Fn key often the Scroll Lock key is used, try Scr Lk + Down arrow to dim the display.
The manual indicates and Fn Key to the right of the Left Alt Key but that doesn't mean you have that keyboard eitther
Jun 30, 2011 | Computers & Internet
Unlock keyboard for dell e4300
Hi
you could try the FN+Nulock which is quite often the FN+F11
also th FN+Scr Lk which is quite often FN+F12
hope this works for you if not
have a look here
http://www.ehow.com/how_5063232_unlock-dell-keyboard.html
Mar 18, 2011 | Dell Latitude E4300 PC Notebook
When I type have to press "Fn" otherwise will type as fallows
make sure scroll is off
on the keybord it might look like scr lk
try that
Jan 16, 2009 | Sony VAIO VGN-N250N/B Notebook
Mouse problem
CHECK WHETHER YOU HAVE NOT SWITCH ON SCROLL LOCK BUTTON press FN key and F12 OR THE KEY THAT HAS WRITTEN SCR LK, TOGETHER
Nov 27, 2008 | Lenovo 3000 Y410 Laptop
Keyboard Stuck in Function (Fn) Mode
To unlock number lock (numlk):
Depend on comp, but try pressing (at same time)
fn + f11
or
fn + Scroll/numlk (next to f12)
or
f12 + Scroll
or
f12 + Scroll + fn
or
ctrl + Shift + Scroll
or in BIOS there is a numlk option
Aug 12, 2008 | Gateway MX6124 Notebook
Two port kvm belkin
Switch to the First PC [Scroll Lock] [Scroll Lock] [1]
Switch to the Second PC [Scroll Lock] [Scroll Lock] [2]
Previous Active Port [Scroll Lock] [Scroll Lock] [Up Arrow]
Next Active Port [Scroll Lock] [Scroll Lock] [Down Arrow]
Switch Audio to the First PC [Scroll Lock] [Scroll Lock] [F1]
Switch Audio to the Second PC [Scroll Lock] [Scroll Lock] [F2]
AutoScan Mode [Scroll Lock] [Scroll Lock] [0]
Change All to the First PC [Scroll Lock] [Scroll Lock] [A] [1]
Change All to the Second PC [Scroll Lock] [Scroll Lock] [A] [2]
Other information:
In AutoScan mode, the switch remains on one port for 10 seconds before switching to the next. This time interval cannot be changed. To exit autoscan mode press [Spacebar].
When in AutoScan mode, no mouse or keyboard controls. If the user moves the mouse or uses the keyboard while switching the connection between computer and the switch might be interrupted and cause erratic mouse movement and errant display when using the keyboard.
Maximum resolution supported is 2048 x 1536 @ 75Hz.
If mouse movement is erratic:
make sure you do not have more than one mosue driver installed. Make sure that the driver is either for a standar PS/2 mouse or a Microsoft compatible PS/2 mouse. Make sure you do not have any mouse drivers loaded in your CONFIG.SYS or AUTOEXEC.BAT files. Avoid moving the mouse or pressing the mouse button when switching ports on the switch. You can reset the mouse and resume porper mouse movement simply by unplugging the mouse from the switch and allowing 2-3 seconds before plugging it back in.
Company information:
www.kaiweitech.com
Nov 03, 2007 | Computers & Internet
ASUS N76VZ-DS71 17.3" Notebook Logo
311 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
