Question about Refrigerators
Fridgemaster mtrl130 The Fridge is Icing up at the back, Is the problem terminal or, is it a problem worth solving ( money-wise
5 Suggested Answers
  • 29 Answers
SOURCE: fridgemaster mtrl 130 keeps icing
sounds like a faulty thermostat,turn this down to its lowest setting possible if it doesnt turn off you will have a faulty stat,it can be checked with a container of ice and a multimeter,place the thermostat bulb or wire into the ice the thermostat should break circuit,do not try this unless you are somewhat mechanically or electrically minded if you do attempt this UNPLUG the supply voltage first
Posted on Aug 13, 2008
  • 3287 Answers
SOURCE: i have a fridgemaster fridge
The first thing to do is to manually defrost the freezer.
If the defroster circuit has failed, the coil in the freezer that is responsible for cooling will be choked with ice. The air that is drawn into through this coil is restricted by the ice - resulting in rising temperatures in the fridge. The freezer will also eventually have a rising temperature (if it hasn't already started).
The next thing to do is decide whether to call a repairman or attempt the job yourself. The faulty component is likely to be one of the following: defrost terminator, defrost timer or the defrost heating element. Accessing these parts will require some simple tools and testing them (once visible) will require a multimeter and taking readings with power both on and off. If you are not comfortable doing this, please call a technician. There is also the hazard of damaging the cooling lines. Skin exposed to refrigerant gasses can result in instant frostbite - and is very dangerous.
You can put this repair work off if you need to - return power to the fridge and it should run fine until the coil becomes choked with frost and ice again. Repeat as often as needed.
This job is not very difficult for trained people to perform and shouldn't be very expensive - of course, "expensive" is a relative term. I hope this helps!
Posted on Dec 07, 2010
SOURCE: Fridgemaster drain hole blocked. Fridge
either it needs a good vacumning the coil area or it is low on freon.
Posted on Jan 17, 2011
  • 884 Answers
SOURCE: fridge freezer icing up
Check the drain is clear by blowing through. Some frosting is normal anyway.
Posted on May 01, 2012
Fridgemaster MS91562FF American Fridge Freezer brand new but the fridge is 15C It needs to be lower? How do i do this?
then call that delivery person and demand it back . but there is a dial in the fridge part to adjust the temp just turn it to a higher number for cooler temp
Jan 10, 2016 | Fridgemaster Refrigerators
How much clear space for Fridgemaster MUR49100?
enough clear space to allow air to circulate between and over items
Feb 16, 2015 | Fridgemaster MUR49100 White 100 l Mini...
Fridge Icing Up
Sounds like you have a defrost Prob. Take back cover off. Turn defrost timer in to defrost mode you will feel a click. timer may be located in fridge. ceiling or back wall if not there check bottom of fridge. behind kick plate or in back bottom of fridge. by compressor. See if heating element gets hot if not check for 120 volts at heater and defrost thermostat ( Terminator ) if not check defrost timer if you do have 120 volts check for 120 volts at heater terminals if no voltage or weak voltage replace terminator if you do have good voltage replace heating element. When ice builds up the fridge. starts to get warm turn off for 24hrs turn back on fridge. will run OK till ice builds back up.
May 22, 2010 | Refrigerators
Traulsen Ultra freezer quit and right wall is leaking water--why?
The fridge is twenty eight years old and not worth putting another dime into it. A fridge that old will just keep dimeing you to *****.
Mar 06, 2017 | Traulsen Refrigeration 48'' Wide x 24''...
FREEZER NOT DEFROSTING AND ICING UP
Fridgedaire has a lot of defrost termination switches that are separating and not allowing the defrost cycle to heat up. The defrost termination switch is located behind the wall that is icing up, take out the screws that hold the back wall in place and use a hiar dryer or hot water to remove ice do not use an ice pick or sharp object of any kind. the def terminatin sw is small and round about 3/4 of and inch thick and has two wires coming off of it one goes to the defrost heater the other usually back into the wiring harness. check it to make sure it is not coming apart. Ohm it and the heater out it should have continuity when below 20 degress. the heater should have continuity all the time,.
May 30, 2009 | Frigidaire FRT22RGC
Freezer icing up
I changed the defrost thermostat and it solved the problem.
Oct 17, 2007 | GE GBS22HCP Bottom Freezer Refrigerator
Refrigerators Logo
99 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
