I bought speaker that are supposed to connect to the tv Cineblue speakers wireless 2.1speaker system with subwoofer and tv RCA P61939 61 in. Rear Projection Television where do I plug the cord that connects to tv
  • B_a_Geek
    B_a_Geek Jul 21, 2013
    Is there a model number for the speakers?
    Sergeant:
  • 396 Answers
I can find not much on the Cineblue speakers. What kind of cable does it use to connect? Is it a stereo sub mini plug? If so, you may need an adapter to connect it to the Audio outputs on the back of this particular set. Here is my first suggestion.That is the simple solution. there are many other types of cables/adapter boxes that will solve this issue.
Posted on Jul 21, 2013
djnick989
  • 1067 Answers
SOURCE: RCA HOME THEATER SYSTEM REAR SPEAKERS NOT WORKING
cheak the mode u are in theter mode reg sterio mode wont do the back ok cheak settings dsp modes
Posted on Jan 20, 2008
  • 5 Answers
SOURCE: loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Posted on Dec 16, 2008
  • 51 Answers
SOURCE: Brookstone Wireless Outdoor Speaker with Bose 123 System Problem
AUX usually refers to an INPUT, such as a CD player, etc. No signal comes out of a standard AUX jack, unless it specifically says "Aux speaker output". Instead, look for another speaker output jack, such as remote speaker, B speakers, etc. You may only have one set of speaker output jacks, in which case you would need to connect your wireless speaker to the speaker output jacks along with your main speakers, or buy a little speaker selector switch box to switch between main and wireless speakers. There's usually no harm in connecting more than one speaker set to the same outputs, though it is technically not recommended. In the real world, just don't crank it too loud and you'll be fine. The wireless speaker MIGHT run off of a standard line output also, if the wireless speaker has its own power amplifier.
Posted on Dec 27, 2008
SOURCE: connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Posted on Jan 07, 2009
    SOURCE: Prima HT 8104 home theatre
    in the 3D processing turn on the Pro Logic and the for the mode as well set it to pro logic.
    it simulates 5.1 surround.
    this is what I did and it's decent. Other way would be to run the system through a amp/receiver that supports 5.1 surround.
    Posted on Apr 27, 2009
    I bought a wireless soundbar to hook up to my Smart flat screen tv, and the manual does not state anything on how to really do it...too simplistic and not enough info for one.
    Find the Audio Out connections on your TV and run the dual RCA cable (Red/White) to the Input RCA jacks on the back of the sound bar unit. You may have to go into your Audio or Sound menu on the TV and turn off the TV's speakers in order for the Audio out on the RCA output to turn on.
    Feb 23, 2016 | Ematic ESB212 Wireless SoundBar with...
    Tip
    How to set up a seven-speaker home theater system
    Set up a home theater
    How to connect your speakers
    In order to deliver surround sound, home theater systems require 5, 6, or even 7 speakers--and that's not even counting the subwoofer. Connecting all those speakers together can be quite a challenge, so here's a quick overview of the basics.
    If you don't have an all-in-one, home-theater-in-a-box system, you'll probably need to supply your own speaker cables. There are several different types available--they vary in terms of wire size (or gauges) and termination types. Make sure you pick cable that's a good match for your speakers and receiver. And make sure they're long enough; the rear-channel cables in particular will be stretching all the way around the room.
    Once you've selected your system and have all your speakers ready to set up, begin by placing each speaker at or near its intended location. Then, attach the cables to them one by one. After securely fastening one end of the cable to the speaker, connect the other end to the appropriate speaker output on the back of the A/V receiver. Be sure to connect the cable to the correctly labeled output.
    For instance, the front-right speaker wire needs to go to the terminal labeled front-right. Also, make sure that each speaker connection is in phase, meaning negative to negative and positive to positive. Otherwise, your system's sound will sound out of whack. Repeat the process for every speaker in your system. Note that the subwoofer uses a coaxial-style RCA cable instead of standard speaker wire.
    Once all the wires are connected, you should test the system with several DVDs and CDs, to ensure that everything is in working order.
    For our first example, we used an elaborate 7.1-channel system, so it may have 1, 2, or several more speakers than your system. Some systems even employ wireless rear speakers, or virtual surround-surround modes that simulate multichannel experience from 3, 2, or even 1 speaker. And some listeners still prefer good old stereo sound from 2 speakers. No matter what type of speaker setup you prefer, however, the wiring basics remain the same.
    How to position surround-sound speakers and a subwoofer
    To get the best performance from a surround-sound speaker system, you must install each speaker in the correct location. There are three basic types of surround-sound speaker systems.
    • The 5.1-channel system has five satellite speakers and a subwoofer.
    • 6.1-channel systems have six satellites and a subwoofer.
    • And 7.1-channel systems have seven satellites and a subwoofer.
    Start by placing the center speaker either directly above or directly below your TV. The center speaker can be perched atop a direct-view TV or mounted on the wall. Aim the center speaker at ear level.
    In most cases, the front-left and front-right speakers can be wall mounted or placed on stands. However, if your speakers have rear-panel bass ports, they should not be wall mounted. Space your front-left and front-right speakers the same distance apart as the distance between your center speaker and your listening position. Position the front-left and front-right speakers no more than two feet above or below the front-center speaker. The tweeters in the front-left and front-right speakers should be roughly at ear level relative to your seating position.
    Ideally, the surround-left and surround-right speakers should be mounted on the side walls of your room, slightly behind or parallel to your listening position. If your speakers have rear-panel bass ports, place them on stands instead. If installing the speakers on the side walls isn't practical, you can mount them on the room's rear wall or place them on stands behind your listening position. The surround speakers can be installed up to two feet above the front speakers.
    Also, 6.1 surround systems have a back-center speaker. You'll typically mount this on the rear wall of your room, centered behind your seating position. Position the back-center speaker no more than six feet behind the surround-left and surround-right speakers. If your speaker has a rear-panel bass port or if the rear wall is too far behind your seating position, place the back center speaker on a stand instead. The back-center speaker should be installed at the same height as the surround-left and surround-right speakers.
    Instead of a single back speaker, 7.1 surround systems use a back-left and a back-right speaker. These, too, are typically mounted on the rear wall of your room. Position the back-left and back-right speakers so that each is approximately aligned with the left and right edges of your listening position. Place the back-left and back-right speakers no more than six feet behind the surround-left and surround-right speakers. If your speakers have rear-panel bass ports,or if the rear wall is too far behind your seating position, place the speakers on stands instead. Install the back-left and back-right speakers at the same height as the surround-left and surround-right speakers.
    A subwoofer is the last component of a 5, 6, or 7.1 system. Because bass frequencies are nondirectional, you can place the subwoofer in various locations. You may get the best performance by installing the subwoofer in the front of the room, approximately six inches from the wall. If you want more bass, try placing the sub near a corner in the front of the room.
    Connect your DVD player to your A/V receiver--digitally
    To hear a movie's soundtrack in surround sound, you must first connect your DVD player to an A/V surround-sound receiver. You'll need to make what is called a multi-channel-compatible connection.
    The easiest way to do this is to use a cable that carries a digital signal. There are two digital options: optical and coaxial.
    An optical digital connection, also called TosLink, uses pulses of light to deliver a digital signal. According to some experts, one advantage of optical digital connections is that optical cables don't pick up noise, while lower-quality coaxial cables can. Many, but not all, DVD players have an optical output. Most A/V receivers have at least one and usually multiple optical inputs. Plug one end of the optical cable into the DVDs player's optical-out jack. Plug the other end into the receiver's optical input.
    Finally, you need to tell your receiver to use the optical connection whenever you switch to the DVD input. This is called assigning the input. Information about this simple process can be found in your A/V receiver's manual.
    A second option is a coaxial digital connection. This type of connection is also used for cable TV, but the connectors are different. This type of coaxial cable has an RCA connector. Coaxial cables are less expensive than optical ones. In fact, you can use any old RCA cable to make a coaxial digital connection, and you won't lose any audio quality.
    Most, but not all, DVD players, have a coaxial output. Some have coaxial and optical outputs, so you get a choice. Audiophiles argue over which connection is better, but it's very hard to hear the difference. Most A/V receivers have at least one and usually multiple coaxial inputs. Plug one end of the coaxial cable into the DVD player's coaxial-out jack. Plug the other end into the receiver's coaxial input.
    Finally, tell your receiver to use the coaxial connection whenever you switch to the DVD input. Again, your A/V receiver's manual will have instructions for assigning an input.
    on Aug 13, 2010 | Audio Players & Recorders
    I just got a multimedia surround system with subwoofer.Spa7650/05, 180w.The subwoofer has three audio connections,front,centre and rear,My tv only has an audio coaxial.I can't connect it.What adapter...
    Firs of all lets get agree on something..The subwoofer has three audio connections for "output " to :front,centre and rear speakers...these are not for "input"..Your powered SUB provides necessary signal for other spekers..
    You can connect TV audio coaxial to SUB input with a RCA cable.....if your SUB does not have "RCA input " probably it should have "3,5mm Haedphone female Jack"..
    if this is the case you need to buy a cable ; one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
    And you need to connect front,centre and rear speakers to your SUB as well...
    Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
    for Helping out the Community :)
    Hope this helps!
    Jun 22, 2011 | Philips Audio Players & Recorders
    Where do the cables go for pic and sound
    You can find the manual here if you need a copy.
    This system was sold with speakers and connecting cables. One cable connects from the main unit to the subwoofer. The rest of the speakers supplied with the system plug into the subwoofer with their special connecting cables. If you don't have the subwoofer and satellite speakers along with the cables, you can't get sound out of this system. There is no built-in amplifier and no way to connect speakers otherwise.
    The video connection to your monitor or TV is from the rear panel on the main unit. You can use an s-video cable, composite video (a single cable with RCA plugs) or component video (3 RCA cables), depending on the inputs supplied on the TV. Component video gives best performance if the TV supports it.
    Jun 21, 2011 | Philips HTS3440/37 System
    I have an rt2870 and am just wondering where i connect the yellow subwoofer cord to the TV at, and i set my tv setting for the surround sound
    You shouldn't connect the subwoofer to the TV. Just connect the Right and Left audio cables (red and white RCA plugs) to the TV audio out and then the other side goes receiver's audio in. If you are using the subwoofer that came with the unit, connect it to the sub port (purple and grey or black striped). The red and black striped cable goes to the subwoofer control.
    If you are using another active subwoofer, connect it to the RCA jack labeled Subwoofer Audio OUT.
    If you have a 3-plug RCA cable that is a composite video cable. The yellow plug carries the video, the red and white carry the audio signal. This cable is most often used for connecting older VCRs and game systems to a TV (or newer devices to an older TV). Thus leave the yellow jack dangling if using it for an audio cable.
    Set your TV to use the external audio speakers and the receiver will take care of the signal to the subwoofer. (You only would connect the speakers individually for a computer sound system.)
    I hope this helps.
    Sep 19, 2010 | RCA RT2870 Theater System
    Samsung home theatre system HT-TZ422 - rear speakers don't work
    I bought the system samsung HT-TZ 422 but wireless receiver module is not connected spikers or not riding tx card.Sound test system is show all spikers but from wireless module is not hiring.When can i get any hepl.
    Thanks.
    Marek.
    Mar 01, 2010 | Samsung Audio Players & Recorders
    I have a Dell 5.1 surround system that I bought for my computer. It has three cables, yellow, black, green, that connect to make it a single jack for the computer. I would like to hook up this system to...
    well you can connect white and red to green connector(Front Speakers) the yellow connector is subwoofer speaker and the Black connector is for Rear Speakers) is not connected. The Tv dont have any Surrond decoder so to have full surrond needs surrond decoder
    Jan 08, 2010 | Audio Players & Recorders
    Trying to connect to TV but only center speaker works. System came with Dell Computer. Have 5 speakers and subwoofer????
    Hi there bud ...Are you sure you using the RCA Cables , and not just the Cables that came with SPeakers?
    Also make sure THat your T.V can handle 5.1 Channel Sound Speakers..
    Hope you come right bud
    Happy new year
    Jan 07, 2010 | Altec Lansing ACS 45.1 Computer Speakers
    Dec 15, 2008 | RCA WSP150 Main / Stereo Speaker
    Pioneer DEH-P3000IB... Hook up RCA cables to 2, 2 channel amps for front and rear control. Supposed to be able to set rear to either rear full or sub... can't find how and all I'm getting is sub response.
    Here are the directions according to the manual:
    1 Use MULTI-CONTROL to select
    SW CONTROL.
    2 Press MULTI-CONTROL to display the
    setting mode.
    # Press BACK to return to the previous display.
    3 Press MULTI-CONTROL to select the segment
    you wish to set.
    Press MULTI-CONTROL repeatedly to switch
    the segment in the following order:
    REAR SP (rear speaker setting)—PREOUT
    (RCA output setting)
    4 Use MULTI-CONTROL to select the desired
    setting.
    Turn to change the setting.
    When REAR SP (rear speaker setting) is selected.
    REAR SP:SUB W(subwoofer)—REAR SP:FULL
    (full-range speaker)
    When PREOUT (RCA output setting) is selected.
    PREOUT:SUB W (subwoofer)—PREOUT:REAR
    # When no subwoofer is connected to the rear
    output, select REAR SP:FULL.
    Hope this helps.
    Oct 13, 2008 | Pioneer Audio Players & Recorders
    52 people viewed this question
     Grubhead
    Grubhead
