H6 written on indoor panel of gree ac what means
After switching off the gree ac unit a day before the next day upon switching on the ac indoor panel gives an indication H6 and also fan is not running. could you please suggest the solution. thanks
SOURCE: furnace won't kick on
My gas furnace wont kick on when it has been off for awile, we have replaced the thermostate and checked eveything else. Once we gett it going it works but wont kick in once the temp drops
Posted on Nov 30, 2008
SOURCE: DeLonghi Planus quick connect split heat pump.
I was told by a delonghi technician that it does this to defrost the unit.
Hope this helps.
Posted on Apr 22, 2009
jmgldsmth
  • 1869 Answers
SOURCE: ice formation in the indoor unit
you need to have the unit checked for the amount of freon in the system this must be done with a gauge set the freon amount is obviously incorrect
also the a-frame evaporator must be sealed in the furnace cabinet
Posted on May 28, 2009
  • 10 Answers
SOURCE: Outdoor unit does not start. indoor unit fan does run.
by the sound of it the relay in the outdoor section is bad
Posted on May 31, 2009
  • 12 Answers
SOURCE: Fan Runs, AC Doesnt, Blinks 5 times
Need to look around and should have an error code and give more detail of what the problem is. If you post that i can maybe help you more. I need to know......
Posted on Aug 20, 2009
It not working shows H6
They appear to be make specific
H6 OPERATION HALT DUE TO FAULTY POSITION DETECTION SENSOR
Tweet It means there is a fault in the temp sensor on the indoor unit that is working on with the cooling unit. It is a leak on the system. It also signifies that the air conditioner is low in charge. It is not getting the air conditioner to work in cooling. The cooling coil needs to be repaired. It could also be caused by not functioning controller board. See the vibration son the grill, glass, wooden and its plastic body.
Mar 18, 2016 | Heating & Cooling
When the indoor unit is on F4 fault error code display.please help to solve the problem.
f4 mean Air Conditioners Questions & Answers - Fixya
www.fixya.com > Forum > Tags > f4 mean
My gree split type ac error F4 what is problem Name of malfunction = Outdoor tube sensor open or short circuit Display of double eight code = F4 this means
Oct 29, 2015 | Heating & Cooling
My Gree hansol split air conditioner wall mounted model gwh18tc-d3dna1a says it has a "Error U5" what does this mean
U5 Malfunction of current detection for the complete unit. A/C status, During cooling and drying operation, the compressor will stop while indoor fan will operate; During heating operating the complete unit will stop operation. Possible Causes, Therese a circuit malfunction on the outdoor unit control board AP1, replace the outdoor unit control panel AP1.
Mar 06, 2015 | Heating & Cooling
What does error code E6 mean?
E6 usually means that there is a communication problem between the indoor unit and the outdoor unit. This could be due to a wiring problem or maybe you had a momentary drop in the voltage. Find the circuit breaker in the circuit breaker panel for your home/office that is connected to the A/C unit. Turn it off and back on and try using the A/C again. Sometimes the indoor unit is connected to one circuit breaker and the outdoor unit is connected to another one. Make sure you have disconnected and reconnected both before running your unit. If that does not solve the problem you may need to have some cable replaced between both units.
Apr 30, 2014 | Gree 18000 Btu 20 Seer Ductless Mini Split...
Gree splet ac i want salution
A Teco unit is almost identical to a Gree. The E5 error on those , it usually means that the outdoor pipe sensor has failed.
Mar 22, 2014 | Heating & Cooling
Azure split Ac error code is h6 what is the problem
Indoor gas pipe thermistor faulty ... CHECK ROLLOUT SWITCH AND CHECK FOR A POSSIBLE GROUNDFAULT..OR FUSE ...
Jun 01, 2013 | Heating & Cooling
VIDEOCON SPLIT AC SHOWS H6 & IS NOT WORKING
Videocon Air Conditioner Shows Error Of H6 Plz Tell Me The Solution.as urgent
Apr 16, 2013 | Heating & Cooling
My gree air conditioner turns off and turns on automatically during most of the time. what kind of problem is this? how can i solve it? in the owner's manual is not written anything like this...ca
its obvious that its the timer , some one has played with the timer settings , and now it switch on and off on the time set , i have this problem too, you need to turn off the timer , i dont know how to do it , this is the nasty thing about the gree AC's
Aug 05, 2012 | Heating & Cooling
Daikin error code H6 Outdoor Compressor motor position detection sensor error
sir
daikin inverter air conditioner we are replace the indoor pcb then next it gone out door pcb,next we are replaced outdoor pcb also then compressor not working oftre last we are replaced compressor then it will be giving H6 ERROR CODE please give me suggestion
Feb 16, 2011 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
