Question about Grohe Classic Kitchen/Bar Faucet 31.057.000...
How to remove handle to repair leaking faucet?
3 Suggested Answers
  • 659 Answers
SOURCE: trying to remove handles on grohe 31054000
I couldn't find the number you have on the Grohe website so I have included a link to their website. Just find your model and it will give you many different options for manuals. Hopefully this will give you the information you are needing.
http://www.grohecatalog.com/category/1/
Posted on Apr 12, 2009
Dplumber
  • 119 Answers
SOURCE: How do you remove the handle son a Grohe two-handl...
Pull the handles straight out of the faucet. use both hands to pull back on the hand while wiggling it left and right just a little at a time. Eventually it will pull off.
Posted on Dec 12, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Tip
    Ball-Type Single Lever Faucets
    BALL-TYPE SINGLE-LEVER FAUCETS
    • The single-handle faucet with a ball inside to control both hot and cold water may either leak at the spigot or at the handle. A handle leak is usually caused by improper adjusting-ring tension. Simply adjust the tension to stop the leak. Leaks at the handle can also result from a worn cam gasket. Dripping from the spigot is usually caused by worn spring-loaded, soft rubber seat assemblies.
    • Parts for ball-type faucets are available in kits. Get the spring/seats kit for spigot leaks, or the complete kit for handle leaks. It may be advisable to use the complete kit to replace all working parts of the faucet at the same time. In any case, you'll need a kit containing the spanner/hex wrench for removing the handle (hex end) and turning the adjusting ring (spanner end).
    • Without turning the water off, loosen the handle set screw. Slide the handle from its stem.
    • For a handle leak, try using the spanner wrench to tighten the adjusting collar. Tighten it by turning the wrench and collar clockwise until the faucet doesn't leak when it is turned on and off. If the adjustment is too loose, the faucet will leak. If you turn it too tight, the handle will be hard to move. When the adjusting ring cannot be turned with the wrench, it is corroded. At this point, you will need to remove the cap to free the adjusting ring. (See next step.) You must turn the water off before removing the cap! Apply penetrating oil to the threads, remove the ring and clean all parts before reassembling.
    • Install the seats. For faucet leaks at the spigot, you must install new rubber seats and springs. You must turn off the water to make this repair. Unscrew the chrome cap by turning it counterclockwise. If it won't turn easily, wrap electrical tape around the cap and turn it with pliers. The adjusting ring, which is threaded into the cap's center, will come off with it. For a seats/springs replacement, pull the ball up and out by its stem. The gasketed cam will come with it. Now you can locate the two rubber seats and springs inside the faucet body. Remove them with pliers or yours fingers and install the new ones. The springs go into the holes first, and the cupped sides of the seats fit over the springs.
    • Service the ball. If the ball is dirty or coated with scale, clean it or replace it with a new one. Both plastic and brass balls are available, but use a plastic one if your home has hard water.
    • Reassembly. Put the ball and cam back into the faucet with the slot in the side if the ball fitting over the pin in the faucet body. Then make sure the tab on the cam slips down into the notch in the body. Not aligning the tab and notch is the number one cause for a faucet leaking after it is repaired. Finally, screw on the cap and adjust the ring as described in Step 2. If a properly adjusted ball-type faucet leaks at the cap, the cam and gasket must be replaced.
    • Swing spouts. If a single-lever ball faucet leaks at the base, you should replace the O-rings. Remove the spout-retaining parts, as well as the spout. Wrap the spout-retaining nut with electrical tape to protect it, and remove the nut with a wrench or pliers by turning counterclockwise. Remove the spout by pulling it up and side-to-side. One or more O-rings should now be exposed. Take the O-rings to your hardware or home center store to get matching O-rings for replacement. Clean any scale that appears on the spout base, faucet body, and the inside of the swinging spout. Install the new O-rings and reverse the steps above to reassemble the faucet.
    on Jan 16, 2010 | Plumbing
    Tip
    How to repair disc-type faucets
    DISC-TYPE FAUCETS
    • Disc faucets may have one or two handles. The water is controlled by openings in the two discs. When the discs are rotated to align, the water flows; when the discs are misaligned, the water shuts off. If the discs wear, the worn discs cause the faucet to leak. Simply turning the handles harder will not stop the leak.
    • To repair a leak in a two-handle disc faucet, turn off the water and remove the handle on the side that's leaking.
    • Use pliers to pull the disc assembly out of the faucet.
    • Beneath the disc unit is the seat assembly, or seal. Replacing this special O-ring may stop the leak.
    • You may need to install a whole new disc assembly for faucets that have been used over a long period of time. In this case, all moving parts of the faucet will have been replaced and should last as long as the original discs did. The parts of some disc units snap apart into a separate bonnet assembly and bottom cap.
    • To repair a leaking single-handle disc, turn off both the hot and cold water and remove the handle to expose the disc assembly. Take out the screws to lift the assembly out of the faucet.
    • You'll notice that beneath the disc unit are three O-ring seals. Though unlikely, water could be leaking between the unit and one of these seals. In this case, you may be able to stop the leak by cleaning the disc assembly and faucet body and installing a new set of seals. If that doesn't work, the entire disc unit must be replaced. This will renew all moving parts.
    • Replacing the unit is fairly simple. Place the three O-rings into their recesses in the bottom of the disc unit. Then install the unit and tighten the screws. Finally, replace the handle–and you're done!
    How to fix a leaky Moen faucet that leaks at the spout ,which is separate from the handle?
    These faucets can leak in three different places:
    1. Internally at the valve seat
      You'll see water dripping from the spout. This means the rubber washer is worn or damaged. To replace the washer, remove the decorative cap from the handle. Remove the retaining screw and pull off the handle. Remove the decorative cover, called an escutcheon, if there is one. Unscrew the packing nut counterclockwise. Unscrew the valve stem and remove it. Remove the screw that holds the rubber washer in place. Because these washers come in many shapes and sizes, you'll want to take the old one to the hardware store and buy an exact replacement. Be sure to buy two washers so you'll have one for the other valve. Replace the washer and reassemble the faucet.
    2. Around the handle
      If you see water coming from below the handle, the packing nut is leaking. Older faucets have a string-like graphite packing material wrapped around the stem. Newer faucets use an O-ring. First try tightening the packing nut clockwise... about one-half turn. If this doesn't stop the leak, remove the packing nut and replace the packing or O-ring; then reassemble the faucet. If the valve is using the graphite packing material, it might be a clue that you should shop for a new faucet.
    3. Between a pivoting spout and the body
      The spout might be held in place with a packing nut, similar to the faucet stem, or it might have a nut at the top of the spout. In either case, remove the spout and replace the packing material or the O-ring seal. Then reassemble the faucet.
    Single lever faucets also are known as "washerless" faucets. They are easier to repair than compression faucets after you determine what type of faucet you have. There are three types of washerless faucets: ball, ceramic disk and cartridge.
    Leaks are evident in two places... dripping from the spout and seeping from around the spout where it joins the body of the faucet.
    Leaks from the spout indicate that the ball, disk or cartridge is leaking. To repair, turn off the water to the faucet, then remove the handle. The handles on ball-type faucets are held in place with a setscrew that requires an Allen wrench to loosen. Ceramic disk and cartridge-type handles usually are held in place by a screw hidden beneath a cap.
    On ball and ceramic disk-type faucets, remove the ball or disk and replace the seals. You can buy replacement kits for these faucets at the hardware store or home center.
    On cartridge-type faucets, remove the spout and pull out the retainer clip that holds the cartridge in place. To remove the cartridge, pull on the cartridge stem with a twisting motion. If it resists, install the handle so you can a better grip on the cartridge to pull it out. Take the cartridge to the hardware store or home center and purchase an exact replacement kit.
    Reassemble the faucet according to directions.
    Leaks at the spout-to-body joint indicate an O-ring failure. Disassemble the faucet as described above. Remove the spout sleeve and replace the O-rings. It's a good idea to replace these seals if you have the faucet disassembled for repair of the ball, disk or cartridge.
    Sep 10, 2011 | Moen Plumbing
    Repairing two handle shower faucet with replacement part RP1740 and need a step by step diagram of the repair?? Can't understand how to repair without diagram. Hot water tap won't shut off!
    No diagram available, but I should be able to walk you through the process easy enough. First, make sure your water is off and you have relieved the existing pressure by opening a nearby faucet until the water stops running. Then remove the handle. Under the handle there will be a nut that can be removed with an adjustable crescent wrench or water pump pliers (if you use the pliers be careful not to mar the surface.) Make note of which way the stopper for the handle is sitting, this is the raised piece of plastic on top of the stem. Then after the nut is removed, you can use some pliers to grab the center of the stem and pull straight out. Once the stem is out, inside the faucet you will see the seat (the rubber piece) sitting down in a little hole and under that a spring. These two pieces are typically the culprit for the leaking faucet so make sure you replace these as well or the faucet will continue leaking. Then working in reverse order, put the new items back in place and then before tightening the handle in place, turn the water back on and check for leaks at the handle as well as the spout. If you have any leaks, tighten the nut at the handle if that is what is leaking, or turn off the water and start the process again to reposition the seat and spring. Good luck, you can do it.
    Aug 17, 2010 | Delta Home
    Leaky eurostream kitchen faucet
    if its leaking under the handle, all you need to do is remove the blue and red cap on the handle under you will find a 1/8 allen screw, loosen screw and remove handle and tighten the brass nut a little which will seat the packing underneath.
    Jun 19, 2010 | Plumbing
    Single handle, about a year old,leaking at the
    There will be a set screw on back or under cap on top. Remove handle, next use a phillips screw driver to remove the part that holds on to the cartridge. Then a bonnet that unscrews leaving the cartridge easily repaired or replaced. And there you have it.
    Sep 30, 2009 | Plumbing
    Repair leaky handle
    Try removing cap of knob and tighten screw it could be loose. If that is not it it may need a new seal ring.
    Apr 21, 2009 | Plumbing
    Kohler Forte Single Handle Faucet Leaks
    you will have to replace the ball assembly with a repair kit
    1 turn the water off under the sink (hot and cold)
    remove the handle ( you may need an allen head wrench to remove a hex screw or you may have to take a channel lock pliar and unscrew achrome
    nut over the ball mechanism
    after the handle comes off there is usually some type of lock nut that you must remove to remove the ball mechanism
    remove the ball (usually chrome or brass(ther are usually little springs and rubber washers under ball
    take ball and washer to ACe or lowes and match the pieces (usually sold as a kit
    follow directions and installl
    turn water on and pat yo!ur self on the back !
    Nov 12, 2008 | Kohler Forte entertainment remote valve...
    Grohe Classic Kitchen/Bar Faucet  31.057.000... Logo
    49 people viewed this question
    Top Grohe Plumbing Experts
    Donni Steen
    john h
    Mike
    Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
