Speed Queen RWM373W-3062
I am only using cold water for washing. Do I only connect the cold the cold water inlet pipe at the back of the machine?
  • 99 Answers
SOURCE: roper washing machine mod# RAS8245EQ1
The problem is one of two parts. One is your water temperature switch or your hot water solinoid. To get to the back you must remove the hex screws on the back and then the panel is removeable.
Posted on Jan 27, 2008
  • 5 Answers
SOURCE: cloged inlet filter
You can also buy new filters to replace the old inlet filters from Home Depot. They are not LG brand they are "generic" filters but they do work. LG does not supply these filters the only way to get them from LG is to purchase the entire inlet valve (keep in mind you have 2 hot and cold) to obtain these filters. You can call the parts dept 888-393-6484 and get the part numbers for these valves and a distributors phone number so you can purchase the valves from them. Hope this helps.
Posted on Jun 06, 2008
SOURCE: washing machine
i had the problem of my brand new washing machine not taking the conditioner and the customer service advisor rightly guessed that i was using concentrated liquid and advised me to dilute it with warm water then put it in the drawer because sometimes the liquid is too thick for the machine to take.try this!!!!! regarding the powder why not put it directly in the machine or buy tablets and do the same with those
Posted on Sep 10, 2008
WRMtech
  • 70 Answers
SOURCE: Kenmore Washing Machine - no cold water coming in
most likely cuase would be the inlet valve
you would need the complete model number to make sure you get the right part for that unit.
Posted on Feb 24, 2009
  • 77 Answers
-the conditioner compartment may be blocked
- the cable with spring that change course of the water may be out,
Posted on May 08, 2009
Speed Queen washing machine repair manual LWS21AW
Request a repair manual directly from Speed Queen.
Dec 09, 2017 | Speed Queen Washing Machines
How to remove cover from speed queen AWM372/3062, help please
Go to www.repairclinic.com and enter AWM372/3062. With luck, you will be presented with a list of common replacement parts and may be able to view a generic Speed Queen video showing disassembly.
Jul 28, 2017 | Speed Queen Washing Machines
Speed Queen Model RWM373W-3062, 7.2kg Washer made loud noises while washing kla kla kla. We tried to get repairman but nothing available locally for domestic only commercial repairs. Now machine has...
it's a reasonable assumption, that the transmission on the washer went, not too hard to replace, but first you have to drain it....and lay it , more than likely, on its back or side to get to the part , accessed through the bottom of the unit most likely
Jun 06, 2011 | Washing Machines
I have a Speed Queen top loader(older model). It let's water in but does not wash or let water out. I have checked the control pannel and motor. All seems to be ok. The reset used to work but now it does...
Make sure that the lid switch is working as it can make the program from advancing forward. So check the continuity of the switch that goes to trigger the main board.
If Ok then the program controller is not functioning, if you can try to change manually then the control board is faulty.
Jan 13, 2011 | Speed Queen AWS17NW Top Load Washer
Cold water fills slowly
Make sure water valve/tap is fully turned on.
If it is, then turn off, and remove inlet pipe to washer, and check the filter in the hose or the valve, i9f clean, then could be a faulty inlet valve.
Please rate my solution.
Thankyou.
Jan 24, 2010 | Speed Queen Washing Machines
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
