Question about GE 31GT740 31" TV
My ge tv clicker power button
Can you salder them or what can you do to make them stick
  • GE Master
  • 15,973 Answers
Are you saying the power button is bad?
Posted on Jul 21, 2013
Aquired TV from a friend but has no clicker, When setting up for air (not cable) I cannot hit enter How Would I set it up without a clicker
Their is a menu button on the tv hit the menu button then use the volume up and down and channel up and down to manipulate the controls like ya would with a remote. I had to do that with 2 tvs.
Jan 03, 2016 | Televison & Video
New LG Flat Screen Plasma tv - worked fine and then when we tried to turn it on, nothing at all happened. What could the problem be? Clicker does not activate tv.
Check ur clicker like tries new set of batteries.Check the power source like the power outlet?Yes,tries tv unplug,replug the tv power a/c cord plug back like about an hour later for the tv to do resetting it seft back to the factory setting.The tv now should work again.If still have the same problems,tv have problems,new tv bought it under a year old.Call LG take ur tv warrenty repair.
Jul 20, 2011 | LG 42LC2D 42 in. LCD HDTV
I hit the "RGB" button
Look for a button named "AV", "AV in", "TV" or "Source" any or all of these should work.
Apr 04, 2011 | Vizio L32 32 in. LCD HDTV
Got a p1698 code on a 98 caravan. What is most likely solution?
I would check the wireing between the tcm and ecm for a wire brakeage another thing I would check is your guage cluster. with the cluster out remove the circut board slitely bend the board to see if there is a brake in the salder speeking of salder CHECK THE PINS where the plug goes I have found loose pins with little to no salder if you tackle this salder job DO NOT LET SALDER RUN FROM ONE PIN TO THE OTHER good luck CJ
May 20, 2010 | 1998 Dodge Caravan
Start/ reset button does not respond. all other buttons work
Many of these buttons are behind a thin plastic covering. The button is like the dome of a "froggy clicker", These "dome" switches are subject to water leaks. SOMETIMES if you can disassemble the panel you can clean the contacts, else replace the button board assembly.
Dec 06, 2009 | GE Dishwashers
Can't change input to play Xbox without clicker. With tv clicker I could access channel 00, which allowed me to play xbox. now the clicker is broke and I can't access channel 00. can i do this through...
The only way is with the remote. Try to find a GE or RCA universal remote. These remotes are designed around GE and RCA tv's and generally don't have to be programmed. (GE and RCA are both THOMSON made sets). Thanks
Oct 13, 2009 | GE 31GT660 TV
GE tv shuts itself off
You are not the only one I can tell you that. I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Oct 27, 2007 | Insignia IS-LCDTV32 32 in. Television
GE 31GT740 31" TV Logo
35 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
