Question about Miele Rotary Iron
Miele b864 foot pedal not working
Foot pedal not working
Rotary iron kenwood used
If there are wires connected to the foot pedal, control is electrical, not mechanical. Contact eBay directly for resolution.
May 09, 2017 | Irons
My Meile B890 Heat plate is not heating up. can any one help
Miele 890 User Manual
maybe a simple thermostat or overheat safety switch off problem
Jul 31, 2016 | Irons
Its a Miele Rotary B890D model, when appliance is switched on the heater plate moves up and down (automatically)without the foot pedal being pressed, seems to be that the foot pedal is stuck in a pressed...
I am by no means an expert. I have an electronic background. I have been looking at my mother in laws iron and noticed a few things about it. Check the foot pedal switch. it is easy to acess. Lay machine on its back and remove the two screws and the cover. If you have a continuity test just make sure the switch changes states when you push it. Hope this helps
Mar 03, 2014 | Miele Rotary B890 Iron
Needle Wont Move When Pedal Is Pressed
check if the foot pedal connect correctly or not change the footpedal if still not working
Jan 18, 2014 | Singer 2250 Tradition Basic 10-Stitch...
My Singer sewing machine model #7470 keeps stitching after I remove my foot from the pedal.
Mine was doing the same thing. I called Singer and if the reverse stitch is working fine, it's a problem with the foot pedal. They sent me a new one under warranty. If the reverse stitch is having issues as well, then it could be a problem in the machine itself.
Feb 02, 2013 | Singer 7470 Confidence Sewing Machine
I was reversing and the machine just stopped...I have unplugged and replugged both the machine and the foot pedal. I have unthreaded and rethreaded the machine. Any suggestions?
test the power cord for open or faulty 2) loose wires from the power cord to the foot pedal
3) foot pedal switch open or faulty, test the wires from loose or breake wires and repair
3) motor need repair , brush, condensator, centrifugal switch. etc
God bless you
Jan 25, 2013 | Singer 7469Q - Confidence Quilter Machine
Miele Rotary Iron Logo
83 people viewed this question
Top Miele Irons Experts
Andrew Taylor
Andrew Taylor
ray gallant
Tom Chichester
Are you a Miele Iron Expert? Answer questions, earn points and help others
