Pioneer x-hm20dab-k No screen display
VSxD209
Hey there denisr, please take look at the display screen on the unit. If you see MONITOR, indicated in the display, then this is your problem . Simply deactivate via the button on the front of your machine. Hope it helps. Good Luck!
Feb 02, 2008 | Pioneer VSX-D209 Receiver
The screen is so dark i can barely make out what is on the screen. i hook up a monitor and that looks fine. my stereo is a pioneer avh-p7480dvd
First I would try pressing the DISPLAY button on your remote which controls the display and if that is not it, it's probably the flex cable. These cables go bad after a while and needs to be replaced. you may also contact Pioneer to see if there is a recall on this part as they may pay for it, otherwise you can purchase it on ebay - http://cgi.ebay.com/PIONEER-AVH-P7480DVD-AVX-P7300DVD-FLEX-RIBBON-CABLE-/120529728036
Mar 09, 2010 | Pioneer AVH-P7480DVD Car DVD Player
Pioneer dvd player will turn on but will not function - Pioneer name displays on menu screen but that is all
Will turn on but displays no signal across a blue screen. I did have it working but only in black and white for some reason. I need an owners manuel as well. thanks
Oct 21, 2009 | Pioneer DV-260 DVD Player
Pioneer cdj 800 mk2 playing mp3s, jogwheel & screen dont work
More than likely the contact pad (aka Membrane pad) is probably damaged... or the flat cable which connects to the main processor, might be loose, or damaged.
You'll need to get this professionally checked out by a qualified technician. It's not an easy fix.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Aug 28, 2009 | Pioneer CDJ-800MK2 Turntable
Pioneer AVIC-n1 touch screen display failure
when those screens go out you are better of replacing the unit. they cost more to repair then buying a new one. also with pioneer they seem to only last 5 to 6 yrs. so if yours is a 2004 then it is about time for it to start to have problems and time to buy a knew. it seems with pioneer they only lasts 6 yrs max and then you have to replace them but other brands like solny they last a lot longer.
Jan 07, 2009 | Pioneer Car Audio & Video
Help with Pioneer Elite Pro-1130HD 50 inch
just wait it, because it is processing the display data
Nov 16, 2008 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Pioneer deh-p840mp
THERE IS A RIBBON CABLE THAT CONNECTS THE FACE PLATES TO THE RADIO THAT NEEDS TO BE REPLACED
May 13, 2008 | Pioneer DEH-P840MP CD Player
No screen displayed when on
I have the same problem. I call pioneer in ohio and said the cause of this is the Flex cable. The cable goes bad and had to be upgrade. The only problem is that the unit had to be send to Ohio.
Oct 09, 2006 | Pioneer AVIC-N1 Car DVD Player
18 people viewed this question
 Grubhead
Grubhead
