Question about Plumbing
Installation of Glacier Bay bathroom model #834-0201
How do you attach the product to the hot/cold copper pipe? Is soldering required?
SOURCE: Bathtub water won't shut off
Did you solder close to the valve. you may have melted or damaged you cartrage inside. shut water off and replace it.
Posted on Dec 19, 2008
  • 68 Answers
SOURCE: glacier bay kitchen faucets with 2 handles and a sprayer
to be honest with you if there is a problem the glacier bay brand is from home depot and they are usualy around 20 to 30 dollars the replacement stems are usualy 15 to 40 depending on the part plus the hours ur gonna spend fixing it your better off with a full replacement. if replaced keep in mind you might want to replace the supliy lines to the faucet with stainless steal suply lines to ensure no leaks and if your shut offs are old dont touch them shut off your water main and drain down your house by opening all the faucets and shower valvs in your house then drain at the lowest point in the house weather it be a sink in the basement or an out side faucet once the supliy lines and faucet is in place then close all the faucets you opened and slowly turn on the water to your house slowly and this will ensure you dont have any leeks from your shutoffs good luck  your friendly plumber
Posted on Apr 12, 2009
SOURCE: We recently installed a new bathroom faucet and it
check the strainer where the water comes out of your faucet it may be clogged or if the faucet has a cartridge in it it may be clogged and you will have to dis assemble the faucet to clean it usually the strainer is the problem and it should unscrew by hand
Posted on Mar 11, 2010
Dplumber
  • 119 Answers
SOURCE: how to repair facet stem for glacier bay products
Theres not much you can do to repair the stem except replacing the small O-ring up inside. You can call Glacier Bay and ask for a new stem ( the faucet has a limited lifetime warranty. You can also use Delta faucet repair parts in your Glacier Bay kitchen faucet; they come from the same mold. Heres a link to Glacier Bay 2 handle kitchen faucet repair. Heres one to the Glacier Bay faucet manual for your faucet.
Posted on Sep 16, 2010
  • 13 Answers
SOURCE: i have a single control, new glacier bay bathtub
it is likely required. many new faucets have what's called a pressure balance valve that helps prevent scalding by lowering the pressure of hot when the cold pressure drops (due to a toilet flush or other water being run). Because you have pressure to only one side, that can cause the valve not to provide the necessary volume.
Posted on Dec 12, 2010
How do I set up the plumbing to convert a single bathroom sink to a double sink?
hot and cold supply is easy. You need to solder in a copper T-piece, and to that add a short length of copper pipe with an isolation valve and then connect that to a flexible braided pipe to the faucet.
Waste water not quite so easy. Have both P-traps fall to a cross pipe that goes to your existing waste.
A plumber could do the job in an hour and a half.
Oct 29, 2015 | Plumbing
How to fix a Glacier Bay Bathroom Faucet/ Leonardo
Usually they have a small screw, but its hidden under a cap. Look at the handles you should see a small plastic cap sometimes colored red and blue for hot/cold. Using tip of small knife pop out the cap/plug. The screw holding the handle on is in there.
Mar 20, 2015 | Plumbing
Where to buy handle adapter for glacier bay bathroom faucet
Glacier Bay is a generic faucet brand sold by Home Depot. Good luck finding any parts for it.
Jul 13, 2014 | Home
Hot water not dispensing
I ve glacier bay hot/ cold water dispenser - new product. Cold water is coming but no hot water. Water is not coming. What have I to do it is a week old machine.
Nov 20, 2013 | Vitapur Water Dispenser. Hot, Room and...
I am having problems with the connections of my hot water heater. The connection of the cold water to the water tank leaks around the connection. When I tighten it the pipe twisted and it started...
Remember, that COLD water might cause condensation as it nears the Hot Water tank--
However, you seem pretty sure it was leaking-- so-- What type of piping are we working with: Copper, Plastic, or what?
Copper is the best-- but requires soldering fittings-- are you equipped to do that?
Plastic has shrink and expand problems around a Hot Water tank, and might be why you have the leak?
Tell us more, -- how far do you want to get into this?
Mack B
Jan 19, 2011 | Heating & Cooling
How to repair facet stem for glacier bay products kitchen sink
Sep 16, 2010 | Globe Union Glacier Bay 8 In Double Handle...
Glacier Bay bathroom faucet - 2 handle leaks
see if the housing itself will unscrew
Jun 06, 2010 | Garden
Single-handle Glacier Bay shower faucet, hot/cold reversed
Hello. It sounds like your plumbing was installed wrong, with the hot and the cold supply lines reversed. If that is the case, those supply lines will have to be replumbed to make your faucet work properly. Often, if those lines are accessable, it is only a 20 minute job. Joe
Mar 18, 2010 | Delta & Single Handle Shower Faucet
I have a pyrotenex heating cable in my pipe at the cottage. the copper covering on the cable is cracked where it is attached to the fitting into the intake pipe. can it be repaired? i've been told that it...
no the coating cannot be repaired, because the coating is heat resistant and anything u put on will not adhere or be heat resistant enough, a silicon auto sealant may last for while but not likely to last long, u cannot solder as to high a heat will ruin core, had a though there is a cold copper solder solvent for fusing copper pipes if u wrapped with this copper tubing and cold soldered it might work it works on hot water copper pipes. If u try this and it works please keep me posted on this my email is adirondacktrail@hotmail.com
Jul 08, 2009 | Easy Heat Water Pipe Heating Cable
Plumbing Logo
154 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
