Question about Garden
Kubuta D330 Brush Cutter
Require a Fuel Fank for a Kubota D330 Brush Cutter - Where available or part number
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: What is the mixing ratio for the fuel(fuel+oil)
Hi marius65..
Use the normal mixture for 2 cycle engines
50 to 1 mixture...1 pint of 2 cycle oil to 6 gallons of gasoline
Please rate me
Bud
Posted on Oct 11, 2012
Fuel ratio for homelite 40cc brush cutter
50:1
100ml of 2stroke oil in 5L of petrol.
Apr 16, 2016 | Homelite Garden
Require a Parts list for a Stihl FS56,
Here's a link to some STIHL parts. String Trimmer Parts
Mar 28, 2016 | Garden
What year is my Kubota m6800 with the serial number of 50953
this is fixya,not your tractor manufacturer,if it doesnt require fixing then please take your question elsewhere
Mar 11, 2015 | Kubota Garden
Husqvarna 235r brush cutter starts fine when cold but won't start when hot
If it has spark and fuel then it may be worn, causing low compression and too weak to start. .
Jun 15, 2014 | Husqvarna 323R 24.5cc Straight Shaft Bike...
Brush cutter
Drain your Gas out and mix up fresh Gas Mix and then it should run, Your old gas is only good for about 4-6 weeks because of the ethanol in it., you might have to possibly clean your carb. and change fuel filter, but would try fresh mix gas first
May 24, 2013 | Garden
How do I install a brush cutter on my 128LD trimmer?
The 128LD is a detachable shaft machine, there are a number of attachments, hedge trimmer, brush cutter, brush, blower etc, there is a alloy clamp at the bottom of the machines tube, just push the attachment tube into the clamp, there is a locating hole so as you know it is fully home, now screw the clamping screw fully down to lock in place
May 12, 2011 | Husqvarna Garden
I want to check if a makita rbc 230 brush wood cutter runs on petrol (neat) or two stroke mixture
I think the model your speaking of is the RBC30. It is a 2 stroke mixture. The 430 models are 4 stroke and do not require mixing oil and fuel. They are made by Ryobi for Makita.
Here is the RBC 30
RBC30SESA
  • Powerful 30cc 2-Stroke Petrol Engine
  • Easy-Start Carburettor
  • Expand-It™ Attachments Compatible
  • 18"/46cm Cutting Path Width
  • 2 Year Domestic Warranty
Info on the 430
RYRBC430SES
  • New 4 Stroke Design
  • Light in Weight 7.3kg
  • Safe Anti-kick Feature
  • Reduced Noise Levels, Lower Emissions
  • 2 Year Warranty
This is pretty much the entire line up of their brush cutters:
http://www.mowdirect.co.uk/acatalog/MowDIRECT_RYOBI_BRUSHCUTTERS___PETROL_STRIMMERS_311.html
There is not a 230 model.
Thanks for choosing FixYa.
Kelly
Sep 06, 2010 | Garden
Hi im after the fuel mixture for a 125L husqvarna straight shaft brush cutter.thanks
From you manual:
Two-stroke oil
For great results and performance use HUSQVARNA two--stroke oil, which is specially formulated for our two-stroke engines. Mixture 1:50 (2%). To maximize the life of your trimmer, you may choose to use a high quality synthetic oil formulated for two-stroke engines. Mixture 1:50 (2%). Never use two--stroke oil intended for water-cooled outboard engines, sometimes referred to as outboard oil. Never use oil intended for four-stroke engines.
WARNING! Always ensure there is adequate ventilation when handling fuel.
1 gallon of premium fuel to 2.6 ounces 2-cycle oil. 2.6 ounce pre-measured containers are available at most chainsaw outlets.
You can find your manual here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
HTH
Lou
Jan 24, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
Model rlt30ces serial no 0811007404
Thanks found a distributor in Townsville
Nov 30, 2009 | Ryobi Garden
Garden Logo
65 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
