Question about Canon PowerShot S30 Digital Camera
SET button difficulties
The SET button is very hard (impossible) to press. It is placed in a middle of a rocker with four other functions left, right, above and below it. Whenever I want to press SET, one of the other functions is activated.
    Problem Solver:
  • 17 Answers
I had the same problem...ended up getting it fixed under extended warranty. Otherwise, the problem is impossible to fix without a spare camera for swapping parts.
Posted on Dec 09, 2007
    Genius:
  • 2,985 Answers
How old is the Camera -still in warranty? Check out the Canon support site for a repair estimate
Posted on Aug 29, 2007
SOURCE:
I have a 2000 saturn ls and my code is 8870. Does anyone know what it is to unlock my radio
Do you want the instructions of how to enter your code?
  1. Turn the ignition ON.
  2. Press the power button on the radio. The display will show "- - - -".
  3. Enter the four digit code by using the and rocker buttons. The numbers will start at 0 0 0 0 and will increase on the display each time the corresponding side of the rocker button is pushed.
    1. Press the down arrow side of rocker button to change left digit.
    2. Press the up arrow side of rocker button to change second to left digit.
    3. Press the down arrow side of rocker button to change third digit.
    4. Press the up arrow side of rocker button to change last digit.
  1. Push the AM/FM button once the four-digit code has been entered correctly.
  2. If the proper code has been entered, the radio will return to the armed mode and normal operation shall return. If the wrong code is entered, the display will momentarily show an error message and then return to display "- - - -" indicating that another try at the correct code can be attempted.
Oct 19, 2014 | Cars & Trucks
Turn ringer on
To set the Vtech T2326 ringer:
there are only four ringer tone/volume choices plus "off" available
1. Press the PROG end of the "SELECT/PROG" rocker switch.
The display will light and show "DIRECTORY"
2. Press the right side top button "VOL +/DIR"
The display will change to "SPEED DIAL"
3. Press the right side top button "VOL +/DIR" again The display will change to "RINGER: [number] ( 1 - 4 or OFF )"
4. Press the SELECT end of the "SELECT/PROG" rocker switch.
The "RINGER: [number] ( 1 - 4 or OFF )" will blink and the ringer will sound.
5. Press the right side top button "VOL +/DIR" The display will change from "RINGER: 1" to "RINGER: 2" and the sound will change accordingly.
6. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 2" to "RINGER: 3" and the sound will change accordingly.
7. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 3" to "RINGER: 4" and the sound will change accordingly.
8. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 4" to "RINGER: OFF" and the sound will cease accordingly.
9. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: OFF" to "RINGER: 1" and the sound will change accordingly.
10. ...and so on, cycling through the four choices & OFF: when you decide to select one, press the "SELECT" end of the central "SELECT/PROG" rocker switch.
11. The display light will go out, the phone will chirp in acceptance, and it will be ready to use the chosen ringer. --
Sep 07, 2013 | Vtech T2326 Cordless Phone
Setting Time on Police Hammerhead Watch PL 13088 JS/02
the three dials are for three different time zones, there is no minutes or seconds.
to adjust the middle dial just push the small bottom which is located on the back side of the watch
Jan 04, 2013 | Police hammerhead pl13088js-04
Takes pictures but you cannot see image in lcd screen
This model only lets you see the image in certain modes. Test if it is properly working by changing the image mode to "P" and pressing the "Set" button (its in the middle of the arrow keys if you're having difficulty finding it. That should display the image on the LCD screen.
If that doesn't display an image, press "Menu" (upper left hand corner) and press the right arrow 4 times to get to the wrench with two dots menu (says "LCD brightness" on the first line. Press down 5 times and select Live view function settings and press "Set". Make sure the first line is set to enable. This should resolve the issue.
Please leave feedback if this was helpful, thanks.
Apr 18, 2011 | Canon EOS Rebel XSi Digital Camera
I bought an old timex indiglo watch it has a button on the right middle and left bottom, how do i adjust the date?
Thank you for contacting FixYa.
  • Press the button on the lower right side of your Indiglo watch to unlock the mode function of the watch.
  • 2 Press the button on the lower left side to move through the modes. Each time you are in a mode, the digital display will flash. For example, when the time display begins to flash, you are in the correct mode to set the time.
  • 3 Change the time (or date) by pressing the button on the upper right side to advance the numbers or the button on the left side to move the numbers down. When you do this, you will be changing the first set of numbers (the hour or month, for instance); to change the minutes, press the button on the right side of the face until the second set of numbers is flashing and begin the process again.
  • 4 Press the button on the lower left side of the watch to save your settings. The button on the upper left side of the watch is not used in this process--it is the switch to turn on your Indiglo light.
  • Best regards. Jewel
    Sep 08, 2010 | Timex Watches
    How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
    Setting Digital Time
    1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
      Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
      Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
      After the time is set, press the upper left button to exit the digital time setting function.
    2. Setting Analog Time
    3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
      Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
    Aug 21, 2010 | Casio Watches
    Replace rocker cover gaskets on 1990 fxr
    To replace the upper rocker box gaskets is not too difficult. But, if you're replacing the gaskets between the head and the lower plate, this gets a bit more involved. You must remove the fuel tank as well.
    To replace the top gaskets, simply remove the four bolts and lift the top and middle plate off the lower plate. The left rear bolt on the rear cylinder is the toughest bolt to get out. Sometimes there is a hole drilled in the frame to make access to this bolt easier. If not, you'll have to shorten a hex key wrench in order to get it out. With the top and middle plates our, replace the "umbrella valve" in the middle plate making sure you put it in from the correct side. Now place the outer gasket in the lower plate, the outer and middle gasket in the middle plate and set the top plate down on them. Wiggle the plates around a bit until you get them lined up properly with each other and tighten the top four bolts down a little at a time one each bolt until they're all tight. Torque to 80 inch pounds.
    If you're going to remove the lower plate, first bring the piston of one cylinder up to top dead center on the compression stroke. Remove the spark plug and rotate the engine until both valves are fully closed. Remove the air filter assembly and backing plate. Remove the large bolts on the right side of the rocker arms Slide the rocker arm shaft out of the rocker arms one at the time and remove the rocker arm and it's pushrod. Notice that the rocker arm shaft have a recess ground into them. This is so the 5/16" acts as a lock to hold the shaft in place. It must be realigned on reassembly of the rocker plate. Once you get all the rocker arms and pushrods removed, you should have the pushrod tubes out as well. Remove the rest of the bolts and lift the lower rocker box plate. Clean the bottom of the rocker box plate and top of the head.
    Assembly is the reverse of disassembly. Make sure you don't get the pushrods mixed up as they are all four of different lengths and will only work properly in their correct postitions. They are color coded for their proper positions. There is no adjustment of the pushrods.
    Front intake --- YELLOW
    Front exhaust -- GREEN
    Rear Intake --- BLUE
    Rear Exhaust --- PURPLE
    Lower rocker box torque values are: 5/16" bolts 15-18 foot pounds
    1/4" bolts 10-13 foot pounds
    Feb 14, 2010 | 2000 Harley Davidson FLHR-FLHRI Road king
    Need operating instruction
    I dont know where to find an instructions booklet but I can help with setting the time/date:
    To set the time and date (you have to do them both together):
    • First press and hold the 'CLOCK' button until it beeps then let go.
    • You will then be required to select the year by scrolling up or down with the 'TIME SET' rocker switch on the right hand side.
    • Once you have the right time, press the 'ENTER' button, to the right of the rocker switch once.
    • You will then be required to select the the month. Do this by once again using the 'TIME SET' rocker switch and then pressing 'ENTER'.
    • You will need to repeat this to select the date (day).
    • You then use this same process to select the time, starting with the hour and then the minute.
    • After you have finnished selecting the minute, press the 'ENTER' button once and then the set time, with the day in the top left corner will be shown. You do not need to press anything else. Your clock is now set.
    REMEMBER to press the 'ENTER' button after selecting each thing to move you on to the next thing to set.
    TIP; Beside the 'CLOCK' button there is a button which says 'D.S.T SUMMER T'. This is the button which automatically switches your clock from british summer time to winter time and back again. It means that you do not need to reset your clock every time. Make sure that it is in the right setting when you set the clock otherwise it could get confusing. You will know if it is on british summer time because a small sun with a clock face appears in the top right corner of the screen.
    Good Luck x
    Mar 16, 2008 | Sony ICF-C273 Clock Radio
    Round button in middle quits working.
    Sounds like you may not be selecting the right menu buttom. The soft keys are right below the screen. these three buttons function change depending on which screen you are viewing. I have copied the instructions from the manual below. You must select phonebook to view the phone book using the round button. You must select volume to change the volume with the round button.
    The Standby Screen
    When the phone is in standby, the handset display shows the following items:
    Handset
    Ringer off icon (when the ringer is off)/ day of the week and time / battery iconHandset ID and BannerNumber of new Caller ID calls received (If there are no new Caller ID messages, the Handset ID appears here.) SUN 12:00A Handset #1 New CID: 5REDIALMENU
    Using the Four-way Function Key
    Your handset has a four-way function key that allows you to move the cursor (or highlighted area) on the display and access the most commonly used features at the touch of a button. By moving this key to the left, you open the Phonebook. Move the key to the right to access Caller ID information. To use this four-way key, place your thumb over the key on the station and move to the four positions to get the feel of how it moves and operates.
    Using the Handset Menu
    To open the menu, press the MENU soft key. Highlight the option you want by pressing the four-way function key. This will move the cursor; the option currently highlighted appears in reversed out text. Select the highlighted option by pressing the OK soft key. To exit the menu and return to standby, press [].
    If you do not press a key within 30 seconds, the phone will time out and exit the menu. When setting Date and Time, the time-out period is extended to two minutes.
    Note: For GLOBAL SETUP and DEREGISTRATION menu options, make sure the line is not in use and the handsets are within range of the base. 123abcdefView the phonebook Four-way Function KeyUpView the Caller IDDown123abcdefView •
    Jan 31, 2008 | Uniden TRU9480 Cordless Telephone
    Bang and olufsen BEOTALK 1200
    Make sure answer machine function is turned on. Bottom right button.
    Make sure an outgoing message is set. Should see a <-> arrow in the display screen. If not, press the <-> button. To record outgoing message... the press the middle button; record out going message; press middle button. Wait a few seconds and you should be set. Hope this helps
    Aug 28, 2007 | Bang and Olufsen Beotalk 1200 Digital...
    Canon PowerShot S30 Digital Camera Logo
    51 people viewed this question
    Top Canon Cameras Experts
    old marine
    old marine
    Doberman
    Ekse
    Are you a Canon Camera Expert? Answer questions, earn points and help others
