Question about 2wire 2700HG-B Router (2700HGB)
At&t 2wire 2700hg-b problem
I'm trying to port forwarding on my modem (2wire 2700hg-b) but went I try to open the ports that I need doesn't work ex: go to firewall setting then add application do the work and then click add application. good so far but went I check the ports it say that they not open. I try other ports too even DMZ, but went I use DMZ and check setting it show me the public IP address but the local IP address in the computer(DVR CAMERAS) doesn't work because went i want to watch cameras in local network network doesn't work. thanks for any advice or solution.
5 Suggested Answers
dvrsetup
  • 43 Answers
SOURCE: Q-See System Not Listed in available computers
http://www.portforward.com/qsee/
Choose the model of your Q-See DVR and then select the model of your router.
Posted on Jan 18, 2009
spincycleus
  • 62 Answers
SOURCE: Port forwarding won't allow individual apps
The 2wire HG is an old 2Wire, they've come out with several models since that one. It sounds like the firmware isnt working correctly. You can try resetting it to factory default. If you do that, hold the reset button down for at least 30 seconds. 2wires take a good 2-3 minutes to re-syncronize.
When you have solid green lights, open Internet Explorer and it will say page cant be displayed. Clean out the address bar up top where you normally type www stuff (and make sure its the address bar, not the seach bar so many people use). Type 172.16.0.1 to get into the router. Run the system setup wizzard on the right. When it asks you to put in a password, it means make one up. Then you need to click on run system set up wizzard again. The key code should already be in there and end in F2NV. Click next, set your time zone, click next, put in your userID and password, click next, after the reds dots, you should be online. Now go back in and try to open your ports. If they dont stay open this time, then you need to think about swapping the router out. The newest model is the 2701.
spin
Posted on Jun 20, 2009
SOURCE: Can't access my DVR remotely via Video Server E
Try checking to see that you set up the DNS address correctly on the DVR itself. Either set it to the router (typically 192.168.x.1) or the same DNS address as the router.
Posted on Dec 05, 2009
pamthegreek
  • 148 Answers
SOURCE: Hi. I have a
See the following: http://portforward.com/english/routers/port_forwarding/2wire/3800HGV-B/ATT_Remote_Monitor.htm
Posted on Nov 24, 2010
How do I port forward with my 2701HG-B router?
Use this link:
http://portforward.com/english/routers/port_forwarding/2wire/2700HG-E/2700HG-Eindex.htm
Then scroll down to the game you want to port-forward, click on that game. Follow all the instructions. Then do a Port checker test:
http://portforward.com/help/portcheck.htm
Now enjoy your game!
Oct 07, 2010 | 2wire 2700HG-B Router (2700HGB)
Tryin to open ports
Download Routing Commander program from www.routercommander.com, it will automatically forward ports and setup the router. Another option is go to router's web interface and set up it manually according to router's User Guide.
May 20, 2010 | 2wire 2700HG-B Router (2700HGB)
2wire 2701 block port 80
Go to the following link. This is just an example on how to forward ports for limewire. Use the same steps to forward port 80.
http://portforward.com/english/routers/port_forwarding/2wire/2701HG-B/Limewire.htm
If it still doesnt work, try updading the firmware. In case this fails, then we have some issue with the router
regards
Sandeep
Oct 13, 2009 | 2wire 2700HG-B Router (2700HGB)
I need to open ports on my 2 wire 2700HG modem ( i was told to by microsoft) how do i do so?
Hi! to open the ports on your 2wire 2700hg modem..that is possible by accessing the setup page of the 2wire modem, if there is an option for the port triggering then you can set the application name and the port #, check if the modem is capable of opening a ports..
Aug 08, 2009 | Computers & Internet
Port forwarding not working for me on the 2wire 2701HG-B...i follow the instructions exactly, but after setting up a firewall rule the port then gets stealthed instead of closed...how can i open it please?...
Here is the link directly from 2wire's website. Shows step by step on how to open the port.
http://support.2wire.com/index.php?page=view&article=21&text=port%20forwarding&cat=&sort=
If placed in DMZ plus mode, does the computer as you wished?
Feb 21, 2009 | 2wire 2700HG-B Router (2700HGB)
Trying to use port forwarding
hi!
i tried to remote access your modem using the serial nos. but it didn't give me anything, pls try to run system setup wizard from your computer by accessing gateway.2wire.net or homeportal/setup, once you have configured the modem with your own settings, please let me know and i'll try to open some ports for you
Mar 23, 2008 | 2wire HomePortal 1100 Router...
Ports
My name is Laxman.,
Please check this link, you can get some information about the port-forwarding in 2700HG-B Router (2700HGB)
http://www.portforward.com/english/routers/port_forwarding/2wire/2700HG-B/Xbox_Live_360.htm
Please feel free to ask, if you have any further questions. I can answer as much as I know.
Nov 14, 2007 | 2wire 2700HG-B Router (2700HGB)
Port forwarding? 2wire 2701hg-T
try the link below it may do it for you if your router is supported on the site http://www.portforward.com/
Sep 04, 2007 | 2wire 2700HG-B Router (2700HGB)
2wire 2700HG-B Router (2700HGB) Logo
21 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Bruce Silvernagle
Bruce Silvernagle
Level 1 Expert
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
