Question about Casa Vieja Dryers
Wiring fan separate from light w/ dimmer
Separate light with dimmer and separate fan control from wall
5 Suggested Answers
Cerfer39
  • 709 Answers
SOURCE: wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Posted on Oct 29, 2007
bigg t
  • 640 Answers
SOURCE: 2 many ceiling wires
ok lori connect the fan wires like this-----white from fan to both white wires---blue from fan to red---black from fan to both black wires then copper wires to a ground.let me know.
Posted on Jan 17, 2008
  • 37 Answers
SOURCE: How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Posted on Jan 27, 2009
jmgldsmth
  • 1889 Answers
SOURCE: remote controlled ceiling fan
unplug the fan then remove the batteries from the remote then plug the fan back in and, reinstall the batteries; this resets the fan control
Posted on Apr 22, 2009
When I put the light on, the fan comes on; the light is on a dimmer switch and the brighter the light, the faster the fan; remote control does no better with controlling either
It sounds like you have a wiring error. The fan and light wires are separate so you can wire them independently if you want. Often people want to have one switch or dimmer control the light, and control the fan with a different one. I suspect you have both the fan and light connected to the dimmer. This isn't healthy for the motor, so it should be corrected. (You can have both fan and light controlled by the same switch if it's a standard on-off type, but the motor shouldn't be connected to a dimmer.)
Jun 10, 2011 | Minka Aire Ceiling Fan
I bought a Hunter fan Model 21778 that uses 2 incandescent candelabra lights. Before installing it I called Hunter support to see if it was okay to use a dimmer switch for these lights (I had already...
They're right, you don't want to control the whole thing with a single incandescent dimmer. First of all, the fan-speed and the lights will all be controlled by the same dimmer setting (dim low, low fan-speed - dim high, high fan-speed) - and the dimmer's not rated to control fans anyway which can result in exactly what they said.
There is a Skylark control, the S2-LFSQ- where half the knob controls the light, the other half controls the fan. The only problem you may (and most likely) have is that in order for that to work, between the electrical box for the dimmer and the fan, there needs to be seaparate wire run for the fan, and a separate wire run for the light so that the dimmer can individual control both.
If that's a problem, I recommend the MA-LFQM-, which includes a module that you install in the ceiling with the fan. The wall switch it comes with speaks to that module, and gives you independent control of the fan and light without having to install new wiring. I have one of those myself, I've installed one in one of my friend's houses, and they work pretty well and then you don't have to worry about what wires you've got in your wall.
Jan 19, 2011 | Lutron Skylark Incanhalogen Dimmer 600w ...
I have a black red yellow and green wire on a combination fan controller and light dimmer,which wires do i hook up to my switch line and feed line in my wall box....thks in advance
You have new wiring device.
Device controls fan and light.
To control fan and light separately from wall box, requires a separate wire to each Load.
So box requires one wire going to fan, and a separate wire going to light.
If previous switch has just two wires that controlled both fan and light, and then fan is controlled with pull-chain, it sounds like new device requires another wire be added to circuit.
Add a comment and say how many cables enter wall box, and say color of each wire in each cable.
Without knowing exact wires in your box, or exact device ... I can suggest answer based on typical wiring.
Compare this answer with instructions that came with device.
How to wire fan-light device:
-Device-green wire always connects to bare copper wire
-Device-black always connects to black Hot wire from breaker
-Device-red usually connects to wire going to light
-Device-yellow usually connects to wire going to fan
Nov 18, 2010 | Cooper Lighting Lighted Switch
I need help hooking up my bathroom fan and light i have three wires going to the bathroom fan and light white black and ground i want a swith to turn off the bathroom light one to run the light to the fan...
Right now a single switch turns on both light and fan.
You want to put in a double switch to control light and fan separately.
But the problem is there is not a separate wire to each the light and fan.
You need a separate wire to each, but the circuit wasn't wired that way.
Usually when the circuit is wired for separate control, there is a red wire that also goes to ceiling box.
Unless you run another wire to the ceiling box, it won't be possible to control light and fan separately.
Electrician can do this pretty easily if there is attic space above bathroom.
Oct 17, 2010 | Broan-NuTone Broan 68W White Decorator...
Trying to install lsdc163pwv for ceiling light operated by 2 different switches. Install box is through switch with black common hot wire, red and black travelers and 2 white neutrals and grounds . New...
Found a .pdf file that shows LSDC163pwv ... it does not show wiring for LSDC. It shows wiring for other 3-way dimmers & separate wiring for 3-way fan control. This is a clue.
The Pass and Seymour download page does not load, so I can't see specific manual.
Let me provide what I know:
-Instructions might be confusing because LSDC works for both single-pole and 3-way circuits ... which probably adds a lot of extra wording in manual
-LSDC Device has single-pole/3-way dimmer (this requires 3 wires)
-Device has single-pole/3-way fan control with 3 speeds (which requires 3 wires)
-That's 6 total wires
-If I understand correctly, you just want to control a ceiling light? -And you do not have a fan? And your ceiling light is set up with 3-way switches.
-IF you are also wanting to control a fan in addition to the light, the box will need separate wires that go specifically to the fan >> your description shows that you do not have separate wires for the fan. Is this correct?
-Without separate wires to the fan, you can still control the light ... but if wires to light also turn the fan on-and-off, then the LSDC is not the right control since a dimmer for lights will not work on both fan and light.
To wire the light:
-You have identified black common wire for light (it is connected to dark-colored screw on 3-way switch)
-You have identified travelers that connect the 3-way switches
-The neutral wires seem to be twisted together at back of box.
-I think the dimmer is located on the top, and fan control is bottom?? Not 100% sure >>>
-Question: are there 3 wires that are associated with dimmer?
-If you can see 3 wires for dimmer, one of those wires should be black ... just hook that to common, and hook other 2 wires to travelers ... and see if it works. If not, keep connecting them until correct combination is found.
Tip- I read a lot of electrical part manuals, and when confused, I write out the instructions so it breaks down the information.
Oct 03, 2010 | Pass & Seymour Pass and Seymour Decorator...
Can a dimmer switch be put on the lights of this fam?
Yes if the fan motor is wired direct to a separate switch
Apr 11, 2010 | Hampton Bay 52 In. White Redington...
My new fan with light fixture is hooked up but it only works through the pull strings not from my wall dimmer. Can someone please tell me why and what do I need to do to have it work from the wall dimmer....
It depends if the fan and lights are ran for separate control. If only one power line is ran from the fan to the switch location than you are out of luck. You should install a switch instead of a dimmer because a fan is not designed to work with a dimmer. A dimmer works by rapidly turning the power on and off faster than our eyes can detect creating a dimming effect for lights. This is not good for your fan. The strength of the fan speed will be limited by the dimming/power output of the light dimmer.
Nov 21, 2009 | Universal Remote Control Hampton Bay...
Control fan/light separately, with only two wires
They are available at Home Depot and Lowes. Hunter makes a wall mounter dimmer that will control the lights and fan speed separately. There is a receiving unit that mounts above the fan to the house wires on one side and the others connect to the fan.
The two hots you mentioned should be a black one and a blue one. The blue is for the lights; the black the fan. Ground everything you can to boxes, etc, if the house is only a two wire system without a ground.
I believe that remote wall switch and receiver runs close to $40.
Sirwriter
Apr 22, 2009 | Slider Lutron: Dual Fan Control / Light...
Quit working
first turn it off, then rotate the fan, half turn and try to turn if on again. if it start running again you have a faulty motor, and need to replace it. or if the problem continue, try replacing the switch in the wall.
Nov 24, 2007 | Hunter 23852 Classic Original Ceiling Fan
Dryers Logo
27 people viewed this question
Top Casa Vieja Dryers Experts
Stan Ford
Tom Chichester
Bill Boyd
Are you a Casa Vieja Dryer Expert? Answer questions, earn points and help others
