Question about Mahindra Vehicle Parts & Accessories
Where can i get parts 4 a cj4a 1980 mahindra jeep
Broken axle drivers side
  • 15 Answers
SOURCE: 2003 suzuki aerio dive axle broken drivers side need repair manual
hoanestly id find a manual onling just google your car year make and your type jsut add manuals after youll get the correct manual you can get a book orderd or get a printable version off there they may be free or pay by pay pal or a similar sight id suggest getting a book one due to the fact youll have it on hand incase you are a do it "yourselfer" youll be able to look up part numbers and such in there good luck
Posted on Nov 14, 2008
csmock132
  • 4669 Answers
SOURCE: rear axle removale
Are you talking about the small lock bolt that holds the spider pin in the differential carrier that you need to remove to remove the axle shafts?
Posted on Aug 14, 2009
  • 117 Answers
SOURCE: broken rear axle on 2003 jeep liberty
Youll have to google it man.
Posted on Dec 19, 2009
SOURCE: CANT REMOVE AXLE
You will need to take the ring gear housing off to get to the retaining clip inside the chunk. Once removed the axil will come out. I had a 47 and that is what I had to do
Posted on Mar 22, 2010
  • 7353 Answers
SOURCE: How to tell if front drivers side of car has
look at the cv boot and see it it came apart. jack up car and look/feel spin the wheel and see if it spins freely, smooth. grab the wheel at 12 and 6 o'clock and see if it wobbles. if the axle is broken, the car wont move
Posted on Jan 20, 2011
Do you have a parts manual for a Mahindra 3510 HST 4 x 4 tractor
Good answer Posted by
Clyde Ottaway Aug 25, 2017
get on the computer punch in Mahindra 3510 HST 4x4 tractor parts manual and a web page will come up that will supply the parts manual.
The link is below
parts manual Mahindra 3510 HST Google Search
Aug 25, 2017 | Garden
Why can't my 2006 jeep go into 4 wheel drive?
are you on dirt? or pavement...????????????????????????
we cant answer until you answer what 4wd option you have.
if that makes no sense, then read the operators guide,
it tells you what's there and how to use it.
read that first, then ask questions,?
and if Part time 4wd?, it';s not to be used on dry pavement only ICE.
eg:
4WD: Select-Trac (or older Select-Drive has a slip coupling too, NP129/229) is AWD in that, "the "4Hi" setting the drive shafts were coupled together using a viscous-type coupler " this anti wind up slipper"
Watch out for exception 1: Select-Trac NP228 based jeeps, it does not have a viscous-type limited-slip coupling. It was used briefly in 1986.
Quada-Trac is full time 4WD (not in lock mode) has a real center differential to shift torque between front and rear. This is the best system , not just a slip clutch as above. Then went BACK to the slipper in 1980. (odd huh?) Up to 1998.
Quadra-Trac-II "4-All Time", "N" or neutral, and "4-Lo". In "4-All Time", torque is applied to the rear wheels under normal driving conditions.
If the rear axle starts rotating at a significantly higher rate than the front axle, hydraulic pressure builds up in the gerotor oil pump and causes the clutch pack, to progressively transfer torque to the front axle, until both axles return to the same speed
Quadra-Trac I was introduced in 2004-10, same as above but is automatic with no driver controls ,like above.
The Quadra-Drive system was introduced in 1999 and is based on the Quadra-Trac II system but adds limited slip differentials (the best full time system ,with great traction to all wheels all the time) 1999 to 04.
Quadra-Drive-II has electronic limited slip differentials or ELSDs 2005 up.
Aug 01, 2014 | 2006 Jeep Grand Cherokee
Why wont my jep go into 4 wheel drive when I pull th lever?
which system?
we cant guess what is In YOUR CAR, ever.
you must SAY. or RTM, in the glove box.
and why are you using 4wd on dry pavement, now>?
Fuel filter
jack up rear axle, support with jack stands, between the rear axle and the fuel tank on the drivers side of the jeep up against the body is the filter. if you do not see one there then you do not have one, it is a part of your fuel pump and is non-servicable
Jun 15, 2012 | 1997 Jeep Grand Cherokee
Need to replace the entire fromt passenger side axle assembly on my 1995 jeep grand cherokee, the axle is broken. Can a regular joe do it? Any tips or instructions if so.
Depends on how many tools you have
What vehicle experience you have
Not a fun job
Do you have jack stands,a floor jack?
You will be there a couple of days,most likely.
I am not talking you out of it,I just don't know
your situation
Any vehicle work on a vehicle from 1980 on,
some 30 years, requires a large amount of metric
tools.
How are you going to get that huge axle nut off?
You need about a 36 mm socket or whatever a jeep takes
I accumulated $30,000 in tools, just working in my driveway
over 47 years.
Dec 21, 2010 | Jeep Grand Cherokee Cars & Trucks
CANT REMOVE AXLE
Mar 22, 2010 | 1983 Jeep CJ5
Suspension issue jeep
only on right turns?? a smaller tire would have resulted in damage if the rear is a locking type rearend. IF it is a locking rear end I would change the oil, noting the color and how it looks. replace it and add some "slip additive"............. IF its not a locking type axle, maybe a spider gear problem, but thats inside the housing, not out by the wheel. You may need to take the axle out and inspect the axle/ bearing.
Jun 04, 2009 | 1991 Jeep Wrangler
Driver side heater blows cold air-passenger side blows hot.
Duct door axle is broken. Dealer will charge $1100 to fix. Go to web site " HeaterTreater.net "
Part will cost around $112. Good luck
Feb 24, 2009 | 2002 Jeep Grand Cherokee
1999 jeep grand cherokee limited
Remove the brake parts tie the brake caliper out of the way, break loose the tie rod and lower ball joint, move the steering knuckle out of the way, pull the axle straight out with a sharp snap motion.
Jul 03, 2008 | 1999 Jeep Grand Cherokee
Vehicle Parts & Accessories Logo
Top Mahindra Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Mahindra Vehicle Part and Accessory Expert? Answer questions, earn points and help others
