Question about Optoma Office Equipment & Supplies
Optoma HD230X wont turn on - Optoma Office Equipment & Supplies
My Optoma EP 719 DLP shows a message saying D-Sub 2 source block, my remote is missing and it wont bring up the menu when i press the button on the device
I would look and look and look for that remote .unless your dog ate it then I would try the manufacturer's website tech support
Apr 25, 2015 | Optoma Office Equipment & Supplies
Why wont my optoma dv11 dlp projector play new dvds
YES REPLACE THE LASER ASSEMBLY YOU WILL NOT GET IT FROM OPTOMA THEY WILL CHARGE THE EARTH FOR THE REPAIR BUT I KNOW WHERE IT IS AVAILABLE BUT YOU WILL NEED TO SETUP THE EYE PATTERN AND TRACKING.
john
www.jvsvisual.com
Apr 14, 2013 | Optoma "DV11 MovieTime DLP Projector"
The projector just turned off suddenly and now it wont turn back on
Possible failure of the main power supply and it is necessary that you must check the main panel and power supply. please check the link for tips to check the SMPS -power unit.
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Dec 29, 2011 | Optoma Office Equipment & Supplies
OPTOMA HD70 projector turns off in a few seconds
my 3m projector turns off as soon as it is turned on
Mar 05, 2010 | Optoma HD70 DLP Projector
Optoma HD 70 turns on with lamp and temo soiled lights
Asher fadida and alll,
The issue:
solid red error light?
HD70 "die's" after few min with strage noise?
flickers different colors before complete self shutdown?
well try this....
Before replacing your bulb, fan or any other component try first cleaning your optoma realy good!! HD70 doesnt comes with any kind of filter so you can imagine the amound of dust can be.
The most importent thing is to blow away any dust from your color wheel + the sensor attached to it .
for farther troubleshoting clean your fan's.
there are 2 fan's insinde the HD70.
probably the most problems will be solved by cleening the color wheel!!
if the problem is not solved ,chack the lemp and the fans if they work properlly.
For fan replacing:
Fan Part number: GM1207PKVX-A
Good luck!!
Feb 23, 2010 | Optoma HD70 DLP Projector
Optoma hd65 projector new bulb wont turn on...cant reset timer!
I think it's a lamp driver issue from what I've seen others have gone through. I also read that if you go through the sequence of unplugging, plug back in, wait 20 seconds and try to turn on, multiple times, it will finally kick on and work. I just got mine to turn back on by doing this and waiting through the fan cycling without the light turning on. After the 4th sequence the light flickered. After the 7th sequence it finally turned on and is working. Now I can watch the Super Bowl and will look into replacing soon.
Jan 31, 2010 | Optoma HD65 DLP Projector
Optoma hd65 wont power on
The problem sounds like the lamp ballast is bad--it's a circuit that initially starts the lamp and then keeps it burning--the lamps are like a welder's arc inside of a glass globe. When you push the power button, the ballast uses a spark of electricity (sort of like a spark plug) to get the initial arc going and then switches to low voltage, but HIGH amps to keep it going.---Rick
Sep 06, 2009 | Optoma HD65 DLP Projector
Optoma EP739
The lamp cover has a disconnect that wont allow the unit to power on while the cover is off.
Try taking the lamp cover off and bending the little piece of metal you find underneith.
It worked for me.
Nov 01, 2008 | Optoma EP739 Multimedia Projector
Wont power up optoma movie time
it's probably not this: Try using the remote to turn it on. I cleaned out mine a while ago and the controls on the main unit stopped working. Only way to turn it on now (for me) is the remote.
Feb 12, 2008 | Optoma MovieTime DV10 Multimedia Projector
Top Optoma Office Equipment & Supplies Experts
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
