Question about Ford Tractor Grill 2600 3600 4600 5600 6600 7600
What isthe torque ssettings on a ford 6600 T3 engine?
Big-end bearings, Cylinder head and valve clearance
  • 42 Answers
SOURCE: hi is there anybody who knows the torque settings
most local libraries has books with the specs in them
Posted on Mar 18, 2009
  • 54 Answers
SOURCE: Escort Mk2 1600 valve and torques settings what are they
cylinder bolt torque settings stage 1 15 ft pounds
stage 2 50 ft pounds
stage 3 85 ft pounds
valve clearences 0.15 - 0.20mm inlet
0.22 - 0.27mm exhaust
these are the figures i have been supplied with, you can also use
cylinder bolts stage 1 10 ft pounds
stage 3 + 90deg.
with my exp, i would use the first guide as the degree method has a tendancy to snap head bolts, especially on older vehicles.
Posted on May 14, 2009
drsinister69
  • 2317 Answers
SOURCE: What is the right Torque Specification of the
Cylinder heat bolt torque:
Torque sequence --------- front | 7 3 1 5 | | 8 4 2 6 | --------- Step 1: Torque all bolts in sequence to 14 Ft/Lbs Step 2: Torque all bolts in sequence to 29 Ft/Lbs Step 3: Torque all bolts in sequence to 36 Ft/Lbs Step 4: in the sequence, loosen the cylinder head bolts three turns. Step 5: Tighten short bolt to 15 - 32 Ft/Lbs Step 6: Tighten long bolt to 30 - 36 Ft/Lbs Step 7: Tighten all bolt to 175- 185 degree note: Do not loosen all of the cylinder head bolts at one time. Each cylinder head bolt must be loosened and the final tightening prior on the next bolt in the sequence.
Main bearing torque:
Torque sequence: Step 1: torque bolts to 91 Ft/Lbs with the exception of the rear main bearing cap Step 2: torque rear main bearing cap bolts to 88 Ft/Lbs Step 3: torque brace bolts to 40 Ft/Lbs
Connecting rod torque:
Torque sequence Step 1: Torque to 29 Ft/Lbs Step 2: Turn an additional 90 degrees
Posted on May 18, 2010
Ironfist109
  • 3018 Answers
SOURCE: What is the engine torque
This should get ya going -
  • Head Bolts are 70-75 ft lbs.
  • rod bolts are 21-21 ft lbs.
  • main bearing 60-70 ft lbs.
  • fly wheel 75-85 ft lbs.
  • harmonic damper 85-100 ft lbs.
  • exhaust 13-18 ft lbs.
  • Rocker Shaft 30-35 ft lbs.
  • 1,5,3,6,2,4 cast into the intake head is the firing order most of the time.
Regards, Tony
Posted on May 09, 2011
  • 3 Answers
SOURCE: what isthe torque settin for
I have a same problem. need help
Posted on Jul 15, 2011
Cylinder Head bolt torque and tappet settings to suit a , Ford Anglia 1964 105E Engine
Hi valve clearance inlet 0.010 in (0.254 mm). Exhaust 0.017 in (0.432 mm) normal running temperature .. Cylinder head bolts Torque 65 - 70 lb/ft.,.. Cheers
Jan 10, 2017 | Ford Cars & Trucks
I need the big end torque on the Rocam engine please
A cheap shop manual will have this and much more. If you are in this deep you probably need one.
Sep 05, 2016 | 2000 Ford Ka
Looking for cylinder head, main bearings, big end bearings and flywheel torque settings. Also valve clearence for same engine.
go google and type in - torque settings for (your engine as you haven't given that infomation) and there will be pages of details
There is no flywheel for an automatic. What you have is a flex plate as the torque converter acts as a flywheel
Mar 18, 2015 | Cars & Trucks
I need to kno the cylender head torque specs for a 2.3i vw microbus five cylender
The Audi 5 cylinder engine (Engine code AFU) was mainly produced in South Africa and was called a Microbus. The engine capacity was 2309cc. The Microbus 2.3i T3 was produced from 1992-2002.
According to Mead & McGrouther - Data Digest the torque settings for the cylinder head bolts are as follows: 40Nm + 60Nm + 90'degree turn + 90' degree turn. The cylinder head bolts has to be replaced with brand new ones.
The Main Bearings: 65Nm. The Big Ends: 30Nm + 90 degree turn.
The OHC Bearing Caps: 20Nm.
Flywheel Bolts Manual transmission: 60Nm + 90 degree turn.
Jul 28, 2014 | Cars & Trucks
Engine torque settings
I don't have those specs, but you can get them here www.alldatadiy.com
Mar 19, 2014 | 1991 Mercedes-Benz 350
Whats the torque setting for big end bearing bolt and cylinder head bolt for toyota corolla 12 valve 2E,1990.
hi big end bearings are two stage, 25nm leave ten mins, then 49nm cylinder head bolts three stages 20nm leave ten mins, 40nm leave ten mins then 60nm check after 5,000miles hope this helps
Apr 07, 2010 | 2000 Renault 181
Ford Tractor Grill 2600 3600 4600 5600 6600 7600 Logo
127 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
fordexpert
donald boissonneault
Are you a Ford Garden Expert? Answer questions, earn points and help others
