Question about Texas Instruments TI-89 Calculator
Error message i have a TI-89 titanium. I'm trying to do my calculus homework and when i have my calculator on function, radian, exact, all that .. and when i go to graph (x)/((x^2-4)^(1/2)) .. in words that means "X divided by the square root of X to the second power minus 4 .. and every time i press the graph button and error message appears and tells me "dimension" .. what does that mean .. please help me out .. thank you, friendly011511
  • 360 Answers
DelVar x
Posted on Sep 14, 2009
    New Friend:
Please can anyone tell me student learning outcomes for area and volume ?
Posted on May 22, 2013
    Sergeant:
  • Texas Instru... Expert
  • 265 Answers
Dimension error meaning that a list or matrix index is not valid. For example, if the list {1,2,3,4} is stored in L1 then L1[5] is a dimension error because L1 only contains four elements. Finally, it is easy to solving your problem. See captured images
Posted on Mar 11, 2012
Calculus cos^-1 Domain Error
If you're in the MATHPRINT mode, press
2ND [COS^-1] ( 8 - 3 2ND [sqrt] 2 1 right-arrow ) / 2 5 ENTER
If you're in the CLASSIC mode, press
2ND [COS^-1] ( 8 - 3 2ND [sqrt] 2 1 ) ) / 2 5 ENTER
In either case you should get an answer of about 103.
Apr 27, 2013 | Texas Instruments TI-84 Plus Calculator
How to un froze the TI-89 titanuim will not turn off.
Press left and right arrow and 2nd keys simultaneosly, hold it and then press ON. Release all keys at the same time and you will reset TI 89 Titanium
Feb 27, 2012 | Texas Instruments TI-89 Calculator
Error memory when loading calculus made easy on ti-89 titanium
You may get Memory Error when you try to access an archived variables. From the other hand Memory Error message is displayed if there is not enough free RAM to access the archived variables. For correcting Memory Error message use the 2ND then MEM to check RAM free size and 2ND then VAR-LINK to determine the size of the archived variables that you want to access. As the third step for correcting this problem deleting unnecessary variable from RAM and archiving large variables or programs. By the definition, the RAM free size must be larger than the archived variables
Feb 23, 2012 | Texas Instruments TI-89 Calculator
I try to install software on a ti-89 and the dimension error when I open the program. Faso also commonly when derived from sin (x) the result is not cos (x) more so, 0.017 cos (x)
I do not know the program you installed, so I will skip the part.
As to the derivative of the sine function, your result is correct if the angle unit is degree.
d(sin(x))/dx = cos(x) is true only if the angle unit is the radian. In degrees, you would have a factor Pi/180 which is 0.174532925. I suggest you consult a calculus book to understand where that factor comes from.
Mar 17, 2011 | Texas Instruments TI-89 Calculator
Ti-89 titanium
Having gone over a month with no response, I assume this is no longer a problem.
Jun 26, 2010 | Texas Instruments TI-89 Calculator
Some of my class set of Ti - 84 silver aren't computing sine and cosine correctly. I've tried clearing RAM and looked at settings. Please help!
I have answered many questions asked by teachers and professors, and very few, if any, deigned to rate the posts. Why do I set myself up for yet another disappointment: I just like to help.
Anyway, the most common source of errors with computation of trigonometric functions is the angle unit. On Ti 83/84Plus (SE) calculators there are two angle units: the degree and the radian.
To verify which angle unit is set as default on a calculator, press MODE. You will see the following screen. The relevant line is the 3rd. On the screen RADIAN is highlighted, meaning that all angle values you feed to trigonometric functions are interpreted as radian measures.
Similarly, all values returned by inverse trigonometric functions are in radians.
I do not know what grades you teach, but if you are doing any differential calculus, the only appropriate unit is the radian. Only for the radian unit is the derivative of sin(x) equal to -cos(x). For the degree, you must introduce a factor to adjust (as a change of variable).
Set all your calculators to use the angle unit you are using in your teaching, and there will be no unexpected results.
Mar 09, 2010 | Texas Instruments TI-84 Plus Silver...
"domain error" message on ti-89 titanium
I had the same problem, this worked for me:
Mode -> page 2 -> Exact/Approx change from "Exact" -> "Auto"
May 12, 2008 | Texas Instruments TI-89 Calculator
Dec to hex conversion
Not sure if TI-89 mode keys are the same, but here's the solution for that calculator:
1. Hit the mode key
2. Hit F3 to get tot Exact/Approx (might be different for 89T).
3. Set it to Exact.
4. Take a look at T-89 manual pages 327, 328, 329.
Nice of TI to NOT include that in the manual, huh?
Dec 13, 2007 | Texas Instruments TI-89 Calculator
Ti-89 wont turn off
I'm having the same problem:(
I need to solve this urgently, i can't stand always being removing the batteries... please help me!!!
Oct 16, 2007 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
737 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
