Question about RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley
Engine specs in Nm for ford tractor 6600 T3 engine
2 Suggested Answers
  • 3600 Answers
SOURCE: my ford 6600 tractor has white smoke white comes
If you have white smoke it is a head gasket or water jacket. If their is no water in the oil on the dip stick tube and you can crack the oil drain plug and don't get water coming out then it is most likely a intake gasket thats leaking. You did not mention if it was a L head or H head that Marks a difference on where the water can leak.yo could have a bad head gasket and have water leaking into one cylinder, to test this go to a tractor shop or truck shop and buy a grease pencil that is heat sensitive mark each exhaust pipe with the pen then start the engine if you have one cylinder that the grease does not melt that will tell you that that cylinder has an issue, cold be a injector copper a head gasket or broken head bolt this will give you an ideal of what your up against and how much you are going to have to spend before you get a lot of money into it.If you need more help just post to tis answer and thanks for using fix-ya.
Posted on Mar 17, 2010
Main bearing cap bolt torque specs for a 1999 2.0 Ford engine
See #1; Main bearing diagram
See #2; NM conversion chart
  1. NOTE: The crankshaft must rotate freely; if necessary check and adjust the bearing clearances.Tighten the main bearings and connecting rod bearings.
    1. Tighten the main bearing bolts in two stages.
    • Stage 1: 25 Nm.
    • Stage 2: 60 degrees.
    1. Tighten the connecting rod bearing bolts in two stages.
    • Stage 1: 25 Nm.
    • Stage 2: 90 degrees.
# 2) Newton Meters conversion chart:
http://extraconversion.com/energy/newton-meters/newton-meters-to-foot-pounds.html
#1)
25730427-ddvrxh52bv4dwu240r4mw22m-2-0.gif saailer
Jun 05, 2015 | Ford Cars & Trucks
Need torque spec for 02 camry 2.4 cam shaft bolts
Bearing cap No. 1 30 Nm (301 kgf-cm, 22 ft. lbs.)
Bearing cap No. 3 9.0 Nm (92 kgf-cm, 80 inch lbs.)
Aug 11, 2013 | 02-09 Toyota Camry 2AZ-FE 2.4L T3/T4 Turbo...
Anyone know the torque specs and sequence for a 97 ford escort 2.0 for the cylinder head?
Hi.
The specs below are for the 2.0 L SOHC engine mounted on P VIN Ford Escort.
The bolts must be tightened 30-44 ft. lbs. follows the procedure.
  1. Tighten the bolts in sequence to 30-44 ft. lbs. (40-60 Nm).
  2. Back bolts off 1 / 2 turn.
  3. Retighten bolts to 30-44 ft. lbs. (40-60 Nm).
  4. Rotate all bolts in sequence by additional 180°, in two steps of 90°.
Specs from AutoZone.
Regards,
Ginko
Sep 13, 2011 | 1997 Ford Escort
I need the torque specs for the main and rod bolt for a 99 escort 2.0l engine
engine tightening torques
Main bearings Renew bolts/nuts No
Main bearings Stage 1 43 Nm
Main bearings Stage 2 85 Nm
Big end bearings Renew bolts/nuts Yes
Big end bearings Stage 1 15 Nm
Big end bearings Stage 2 90°
Jan 21, 2010 | 2004 Ford Focus
I nee the head bolt torque specs for a 95 sable
    • Tighten retaining bolts in sequence to 80 Nm (59 ft. lbs.).
    • Then back off bolts 360°.
CAUTION: Always use new cylinder head bolts when installing cylinder head or damage to engine may occur.
  1. Tighten the cylinder head retaining bolts in two final tightening steps in sequence shown in the following illustration:
    • 50 Nm (37 ft. lbs.)
    • 92 Nm (68 ft. lbs.)
Nov 03, 2009 | 1998 Ford Taurus
Intake torque specs
Upper intake
Stage 1: Tighten to 20 Nm (14 lb-ft).
Stage 2: Tighten to 25 Nm (18 lb-ft).
Lower intake
Stage 1: Tighten to 15 Nm (11 lb-ft).
Stage 2: Tighten to 32 Nm (24 lb-ft).
Rocker Arms
Stage 1: Tighten to 10 Nm (89 lb-in).
May 17, 2009 | 2000 Ford Windstar
Head bolt torque specs needed for 96 tbird 3.8
Head bolts are torque to yeild so you MUST use new bolts.
Tighten cylinder head retaining bolts in numerical sequence in three steps as follows:
  1. 20 Nm (15 lb-ft).
  1. 40 Nm (30 lb-ft).
  1. 50 Nm (37 lb-ft)
Loosen retaining bolts one at a time two to three revolutions and retighten as follows:
Long bolts:
  • Tighten to 40-50 Nm (30-37 lb-ft).
  • Rotate an additional 175-185 degrees.
  • Go to next bolt in sequence.
Short Bolts:
  • Tighten to 20-30 Nm (15-22 lb-ft).
Here is a pic of the sequence
http://i253.photobucket.com/albums/hh43/chuck943/Headboltsequence38L.gif
Mar 19, 2009 | 1996 Ford Thunderbird LX
Open Questions:
See all RTO Ford Tractor 2000 3000 4000 5000 Water Pump Questions
RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley Logo
123 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
