Error in alp k2 ws910 - Office Equipment & Supplies
Alps md driver error
For the ALPS printers, make sure you are using Windows XP SP2 or older. There are no Win 7 drivers and there can be problems with a Win XP SP3. Join the Yahoo ALPS group. In the files section they have a full description of the problem along with a work around. It usually is a conflict with the bi-directional communication and the LPT port. The LPT port needs to be motherboard based - not an add-on card.
I hope this works.
Nov 14, 2012 | Alps MD 5000 Thermal Printer
The "error" light is on
Make sure you have the standard ALPS ink cartridges in the printer (dark gray). I've seen people getting a flashing error light when trying to use the photo cartridges (dark blue) to print.
Apr 04, 2011 | Alps MD 1300 Thermal Printer
Stirling XQG65-908E E11 error clothes stuck in machine. Machine is lock and clothes are inside
Buttons:
Pre-Wash = K1
Delay = K2
Temp = K3
Spin Speed = K4
Add Garment = K5
Extra Rinse = K6 1. Press K3, K5, K3, K5 in 30 seconds after power on to enter serve mode(txx selection mode). The display will show t01.
2. Press K1 or K2, it will change from t01 to t12.
3. Press "start/pause" key to enter txx measure mode. Run txx after"start/pause" key. You can go back to txx selection mode if press "start/pause"key.
b. t02:Show fault code test
Press K1, K2 can see all record fault code EXX after enter t02. You can cleanupthe fault code per hold K2 for 3 seconds. If error code 11 does not go away after doing the above 3 times, then theremay be something wrong with the inlet valve, drain pump or PCB.
Jan 16, 2011 | Washing Machines
We have Alps MD 1000 which makes a grinding noise when we power it up, and then the error light comes on. Is this normal, or is what could be the problem? Where would we need to send it for repairs?...
All ALPS printers make noise when they are turned on. The error light is not normal. Do you have cartridges in the printer? there are two kinds: ones with gray plastic cassettes and ones with dark blue plastic cassettes. For the 1000, you want the gray ones. Are the cartridges installed correctly? Side B should be facing up.
Feb 06, 2010 | Alps MD 1000 Thermal Printer
Incomplete print job
Cartridge Changer Errors are series. Did printer work before you installed XP?
Oct 10, 2008 | Alps MD 5000 Thermal Printer
ALPS 5000
Cartridge changer error can be bad. Inspect and clean the changer. Try changing the order of the cartridges in the holder. Any effect? With just the black cartridge installed, try printing an internal self print test. Does that work?
Sep 04, 2008 | Alps MD 5000 Thermal Printer
You need to have the driver installed in order to see what error the printer is reporting.
Jan 30, 2008 | Alps MD 5000 Thermal Printer
Prints 1/3 to 1/2 a page then I get an error
Sounds like you have a problem with the anti-curl motor.
To confirm, you will need to print a test page from a computer that has the Alps drivers loaded (Not the drivers that Microsoft ship with XP, as the Alps drivers have a printer monitor that will inform you of any problems that the printer encounters, the Microsoft drivers do not). You can get them by joining the alps and alpsdecal groups at http://groups.yahoo.com. They are in the Files section of one of the groups.
Assuming you are using Alps drivers, and not the Microsoft drivers that are loaded by XP, you can disable the anti-curl function by the following process:
1. Click File->Print
2. Click the Properties button in the dialogue that opens.
3. Check the checkbox labelled "Print on backside" in the Media Type box of the properties dialogue.
Oct 14, 2007 | Alps MD 5000 Thermal Printer
Alps MD 1300
The printers are out of production, and out of support.
Oct 11, 2007 | Alps MD 1300 Thermal Printer
k24674
jasbo
jasbo
