Question about Coffee Makers & Espresso Machines
Breville bes400 ikon espresso machine instructions
Short circuit
SOURCE: wanting basic operating instructions for CM5
there is no water coming through my coffee machine
it is a visa versa
Posted on May 02, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have a Breville CM3 Coffee machine. The Anthony
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 14, 2010
  • 15 Answers
SOURCE: I've A Breville 800 esxl espresso machine.When mak...
Breville brew head seals are rather difficult to locate, but I personally stock them for ESP8XL & 800ESXL machines and sell them at a reasonable cost. I sell lots of new and used parts for various coffee machines, but specialize in Krups and some Breville. If interested in purchasing a Breville brew head seal, contact me at cowboy_romeo@yahoo.com and I'll make arrangements. I accept Paypal to make the transaction safe and secure for us both.
Posted on Nov 27, 2010
SOURCE: Online store for Breville spare parts?
Hi, can anyone tell me where I can get a replacement steam wand and double coffee holder for a Breville BES820? I have been looking on the web and can't find anything.
Many thanks
Cate
Posted on Mar 09, 2011
SOURCE: Breville BES820 Espresso Machine internal short
  • steve_s741
  • 4 minutes ago
Ok, I'll describe my own fix to my own problem in the hope that it helps others. First of all, the symptoms: your machine just stops working altogether; all lights go out; you try and turn it back on but nothing happens; then you realize half of your house has lost power. So you try and reset the circuit breaker, but you can't succeed until you turn off the machine at the wall plug.
The diagnosis: probably an internal short circuit.
This is what happened to my machine, and because it's out of warranty I thought I'd have a quick look at it myself. Turned out to be simple fix, so here goes...
Getting access to the wiring we need to look at is easy enough.
1. Disconnect power from outlet (obviously);
2. Use your Torx T20 to driver bit to remove 4 screws holding the rear cover, then turn the machine upside down and remove 2 small philips-head screws securing the base of the rear cover. remove the cover.
3. Gently bang the top die-cast cover from the back to try and dislodge it and move it towards the front of the machine (there are no screws holding the cover on the BES820, it is just a tight fit under some lugs). Your attempts to move the cover will be met with resistance. In the end I needed to thump it quite hard with my hand. A rubber mallet would probably be ideal, but I don't have one. Once you have pushed the cover forward by about 10mm, you should be able to lift the cover off.
4. Unscrew the earthing cable form the top cover and put the cover aside.
5. Now inspect the visible cables. Look in particular for any pair of wires that may be making contact with each other. This was what I found in my case. Two wires had been rubbing against each other, probably due to the vibration cause by the pump, and eventually had rubbed through the insulation to the point where the circuit was shorted. Smoking gun found!
6. If you find this evidence, you will need to a) add some additional insulation where the original has worn through (make sure it is heat and steam resistant, consult with your electronics store), and b) ideally, try to rearrange the cabling to keep some physical separation between the cables so it doesn't happen again.
When you are satisfied with your work, you can test it by plugging it back in and turning on at the wall. If you haven't replaced the covers yet, be aware that most of the visible wiring you see in there is running mains voltage, so keep hands clear!
Reassembly is the reverse of above. Don't forget to re-connect the earth lead to the top cover before replacing it. Good luck!
Posted on Apr 09, 2011
Testimonial: "This guy is a gun"
Hi, I'm actually trying to get the manual for
Hello First thing I did was go to this page http://www.breville.com.au/ask-us and posted on this link asking for the manual or instructions for Breville BES400xl Espresso Machine. Please do not rate this solution until after they have contacted me back with your documents. Due to the holiday tomorrow they will either respond on friday or monday at the latest either way I will message you on this chat. Also if there documentation is attached but not allowed to be posted I will at that time then either give you my email to contact me so I may send you the instructions that you are looking for. The reason your not seeing it online yet is the company has not allowed the full manual to be posted online. If you have any further questions message me back. Thank you
Rick
Nov 24, 2011 | Breville BES400 Espresso Machine
Coffee not coming through, loud sound, can't find manual online
Click here to download the manual for the BES250XL which is almost the same as the BES400. Unfortunately, the manual for your espresso has not been added on the official site of Breville but you can get support from them. Check this website.
Or you can also refer here to the Breville Forum.
Hope this gives you a head-start.
May 10, 2011 | Breville BES400 Espresso Machine
Steam function on the BES400 just stopped working! its been working fine for about 10 months & now the light just continues to blink, no pressure, no steam!
I have the same problem. Mine is 2 yrs old. Boiler is OK, just no steam. I opened it up and the controller board has a blown elecolytic cap. However, after replacing this still no steam. I would guess it needs a new controller board. I will try Breville...
Dec 07, 2010 | Breville BES400 Espresso Machine
I own the Ikon BES400XL and the coffee does not seem hot enough. Temperature on turning it on is 140 and gets to 160 if I let it warm up. Shouldn't it be around 200F? What gives? Is it something I can...
It was set to that temp by the factory, check the thermostats on the boiler of the machine, those are the set temps. If your machine has a pressure stat you might be able to adjust it to a little higher, never go past 198.
Aug 10, 2010 | Breville BES400 Espresso Machine
Not pumping water through properly even though I have primed it.
Sounds like a pump issue.
Find your local service agent here http://www.breville.com.au/care_agentsearch.asp?type=replacement
Or call Breville in 1300139798 and speak to Customer Service.
May 25, 2010 | Breville BES400 Espresso Machine
My Breville fresca BES860 cleaning cycle won't start - I hold the three buttons in for 3 seconds and nothing happens. The light has been on for days, and I haven't been able to resolve the issue. Any...
From the model number I guess that you're in Australia? I'd recommend calling Breville themselves on 1300 139798 or speaking to someone at a Breville Service Centre.
Also, is the machine under warranty? I'm pretty sure that's a reasonably new model. Check your receipt and refer to http://www.breville.com.au/care_warranty.asp as it has 12 months warranty.
May 23, 2010 | Breville BES400 Espresso Machine
Water does come out of espresso maker. comes out of wand though
Remove the portafilter and press brew button if water flows then problem is the grind if no water remove shower screen and make sure it is clean also press brew button without shower, if no water then the machine will have to opened to find the blockage.
Sep 13, 2009 | Breville BES400 Espresso Machine
Need instructions
You can read or download the manual at www.euro-pro.com. Just enter your model number (mine is CL766B) into the box on the left side of the screen.
Nov 22, 2007 | Breville BES400 Espresso Machine
Coffee Makers & Espresso Machines Logo
29 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
