Thomson DV2137 DVD Player reset
DVD has accidentally been set to YUP+ instead of PAL now we can't see anything only flashes across the screen. Unfortunately this also includes the setup menu. Does anyone know how to reset this back to factory default?
The Marv
  • 72 Answers
SOURCE: stuck on either PScan or PAL; can i reset the whole darn player?
To reset Cyberhomes DVD players. Take the dvd out close the tray. then press and hold stop for five seconds.
Posted on Aug 05, 2006
  • 76 Answers
SOURCE: reset Apex DVD player
If you go to the system menu there should be a place under settings where it says Reset or Restore Default settings. Hope this helped. =)
Posted on Feb 25, 2008
SOURCE: How to reset my Denon DN-V210 DVD Player to factory default?
Hi Jason,
I have just bought this unit and have been using the menu recently. The only ways i can see to do it would be to either, (as you say) plug it into a HDTV, or navigate the menu blind and hope for the best.
If you press SETUP on your remote once to get to the menu setup screen and then push the RIGHT navigation button 3 times this should take you to the system setup screen. Then push the DOWN navigation button 4 times and then push ENTER. At this point it asks you for a 4 digit password to reset the unit which is a factory preset, 5555, so type that in. This should then reset the DVD player to factory settings.
Hope it helps,
Nick
Posted on Nov 19, 2008
CRTN
  • 716 Answers
SOURCE: How to reset (manually) factory defaults?
Unplug It And Hold Down The On/Off For 30 Seconds Then Release And Plug It Back In. This Should Reset It If Not Let Me Know.
Thanks For Using Fixya.com
Posted on Jan 17, 2009
CRTN
  • 716 Answers
Press Setup,Right Arrow,Press Down 3 Times,Then Enter 2 times this should reset factory settings, I Hope This Is Correct As I Realize You Cant See The Menu But I Studied The Manual And Wrote Out The Exact Key Movements To Navigate The Restore Factory Settings menu. Hope This Helps
Sincerely,
Michael Scott
Memorex mvd2022 video setup
Download the user manual by this link, and refer it.
May 29, 2012 | Memorex MVD2022 DVD Player
Thompson dvd player unlock code dv2137
Just bought THOMSON DV2137 in Australia (region 4) It plays Aus but not US. A small slip in the user's manual gave these (verbatim) instructions. UNFORTUNATELY it isn't working on my player."This unit has been set to play region 4 DVD discs. If you wish to use this unit outside of region 4 territory you can change the region setting by following the instructions below.1) Turn on the unit.2) Remove disc and press SETUP to enter SETUP menu.3) Press VOL+.VOL-,VOL+,VOL-, by order, then press MUTE to enter Region Code setting. [stays in SETUP menu]4) Press LEFT / RIGHT to choose between 1-4 or ALL region."
Perhaps this will work for someone else or will trigger a clue.
Nov 22, 2011 | Televison & Video
How to Change NTSC/Pal ?
press the button again
or try taking out the
DVD
Jan 10, 2010 | Televison & Video
This is a silly question, but our JVC DVD Player started playing only in Black/White, so I went into the Display menu trying to fix that problem, and instead mistakenly changed the resolution of the screen...
if you have a modern tv you could change the format (pal, ntsc) on the tv and then on the dvd. I have set my dvd player and tv to auto, they are both newer models.
Jan 05, 2010 | Televison & Video
I just purchased a dvd player and it's showing vertical lines.
PLEASE CHECK PAL AND NTSC SELECTION....IF YOUR REGION IS PAL SELECT PAL IN DVD SETTINGS....OR IF YOUR REGION IS NTSC THAN SELECT NTSC IN DVD SETTINGS....ITS NOT A PROBLEM...JUST TRY TO SWITCH PAL AND NTSC IN YOUR DVD SETTINGS....U WILL DEFINATELY GET THE RESULT
Nov 08, 2009 | Televison & Video
Initially had trouble with sound. then went into set up menu. while in clicked on video and accidentally change to PAL which give continous screen rolover and can't get out of it. Help
Look for a "reset" selection to reset the machine to the factory defaults. Try connecting the player to a computer monitor and try to access the setup menu.
Sep 20, 2008 | Televison & Video
Wont play dvd's displays PAL
how to reset awa dvd player pscan, my player just wont do anything only displays pscan and it splits the screen
Jun 25, 2008 | JVC XV-S402 DVD Player
Nextech N600 DVD player problem
You may have connected one of the component outputs (usually colored red, green, and blue) of your DVD player to the composite input of your TV. Connect yellow to yellow. See section 3.2 for hookup details. Also, if you've hooked up component video, check the three cables to make sure one of them hasn't become disconnected or developed a short and that they are connected in the correct order. If you use an s-video connection, the chroma wire maybe broken -- try a different cable or try the composite connection.
If you live in a PAL country (most countries outside of the U.S., Canada, and Japan) you may be playing an NTSC disc in a PAL player, but your PAL TV can't handle the signal. If your player has a switch or on-screen setting to select the output format for NTSC discs, choosing PAL (60 Hz) should solve the problem. See section 1.19 for more information.
May 03, 2008 | NexxTech N600D DVD Player
How to reset dvd recorder to ntsc from pal
After checking today to see no one offered any suggestions - I solved the problem the hard way - I went into settings and although the screen rolled, I was finally able to click onto the ntsc setting after about a half hour of tries and once I clicked it, my screen returned to normal -- i was then able to enter the code that made the player an all region player and was happily able to play a pal dvd I received recently. The procedure was simple -- offered by a European Cyberhome user -- the company is in bankruptcy so you cannot gt help from them. Note - my Cyberhome dvr is 1500- not 1600 as you listed it.
Feb 11, 2008 | Cyberhome DVD Recorder - DVR1600
Problem during 'setup'
I had the same problem too now my TV screen is all black and I can't do anything. can someone help please. thanks
Dec 13, 2006 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Electro Med Services...
