Canon np6030 copier error E210
Error code E210
  • 62 Answers
SOURCE: canon np6030 copier
Does the machine start and switch itself off? Some errors cause this to occur to prevent further damage. Try switching it on with the front door open, this will prevent the fixing heater circuitry from initialising. You will then need to find the error code. The ones that cause it to switch off never appear on screen, only viewable thru service mode. Push a straightened paper-clip into the hole below the right hand meter inside the front of the machine, press << and >> to get to *1* DISPLAY, find ERROR and let me know. Hope this helps...
Posted on Aug 29, 2007
KyoDoc
  • 38 Answers
SOURCE: Canon copier ir 3100 cn error code E000602 - 0202
the hard drive containing the software that drives the machine has an error. Corrective steps would be to contact to a Canon technician, who can first try to re-install the software, and if this doesn't work the hard drive has probably crashed, meaning that the drive will need to be replaced and the software re-installed
Posted on Jan 23, 2009
redzventures
  • 149 Answers
SOURCE: IR2270 copier displaied error code E000020-000
It's concerning the toner level in the dev unitor drum unit. Try entering service mode and selecting 'install' this will stir toner and try to feed toner through. Could be a dirty or faulty toner level sensor. Cuuld also be the drum life over - check drum life in the service mode. Check my other posts to see how to enter service mode
Posted on Jul 06, 2009
SOURCE: Canon NP 6030 Error code E010
chiudere sportello superiore destro
Posted on Oct 16, 2009
brett207
  • 231 Answers
SOURCE: canon NP6060 error code E210 Press Power Switch to
This error code, on older machines, means that the lens cannot get to its home position.
Lift up the top cover (or Document feeder) and look under the platen glass as you switch the power on.
Can you see the lens moving, trying to find its home position.?
If not, it is stuck on something, or the drive cables are loose...
Posted on Dec 08, 2009
Code error E002 for Canon NP6030
hi 1. cheq the fuser heater lamp & thermal fuse,
2. enter in the sim mod by pressing service swich located in side the front cove you can see the $ sing at the screen left upper corner then press *4* then scroll to find the error then ok macine will re start and hope your error will go
thanks
May 13, 2010 | Office Equipment & Supplies
its your fuser unit either a heater lamp is blown or themalfuse or thermistor is bad
Mar 22, 2010 | Canon Office Equipment & Supplies
Canon NP 6545 error e210
This code refer to expo unit.The home position sensor possble defected.To reset press the service mode switch sw850 and wait 3 sec,or opem close the front door.
Aug 12, 2009 | Canon NP 6545 Copier
Error code E210 any ideas
Error E210 means - there is a problem with the lens position.
Under the glass there is a lens that moves to enlarge and reduce the copies. At switch on this has to find a home position. the error code means it has failed to do so. If you look at it is is driven by a belt. The drive pull for this can be seen through the glass. This becomes miss placed and is not driven correctly. Have a look and you will see has has come out of place. You may be able to take it apart and clean it up if not you will need a new drive assembly.
Jul 08, 2009 | Canon NP 6050 Copier
Canon np6030
Most likely, you have a problem with the scanning lamp.... When you turn the copier on, will it turn right off? If so, try to hold the power switch "ON". The Display pannel will flash a Error Code... It may be a E0200 or E0220 or E000. Get the Error Code and get back to us... I think you have a heat or scanning lamp is shorting out... Good Luck
Mar 28, 2009 | Canon NP 6035 Copier
Message error E901:press the power switchto off then back to on
cassette feed unit motor or control board are faulty. or something is interfering with it.
Dec 27, 2008 | Canon imageRUNNER 5020 Copier
Canon np6030
I have downloaded service manuals, parts manuals, maintenance manuals, service mode, error codes from www.printcopy.info
Sep 15, 2008 | Canon imageCLASS D761 Copier
E210
Error 210 means that the printer scanner hasn't returned in its initial position.
You should see there http://en.allexperts.com/q/Repairing-Copiers-Faxes-1748/Danka-Copier-Canon-NP6551.htm , it may help you.
Feb 05, 2008 | Canon NP 6551 Black and White Copier
Canon NP6030
go to service mode then press *4* and clear ram and enter same values displayed in *3* (please note old values of your machine in *3*before clearing ram)
Jan 14, 2008 | Canon imageCLASS D761 Copier
532 people viewed this question
k24674
